Vegas Video discussions from 2004 (Q1Q2) - Page 122 at DVinfo.net
Old May 29th, 2004, 10:13 PM   #1816
Sponsor: JET DV
The length of the photoshop file should have NOTHING to do with what can be shown. Just make sure you use Pan/Crop to move the image.
You can either use masking or chroma-key or render to an uncompressed AVI with Alpha-channel for your Graffiti method.
Edward Troxel is offline
Old May 30th, 2004, 07:14 AM   #1817
Thanks Edward
Hi Edward.
I'll have to revisit both those methods, as I couldn't get any of them to work how I wanted them to. My long winded work around achieved the right effect, just didn't look as good.
Will repost when I've had more time to try them out.
Andy
'This one goes to eleven'
Nigel Tufnell
Andy Shrimpton is offline
Old May 30th, 2004, 08:09 AM   #1818
RED Code Chef
I think you need to split up the footage to do such a thing. What
might do the trick is to have the first 10 seconds play before the
menu (first play) and have the rest as a motion menu with the
a graphic button overlaying your text. Something like that.
Which demo from Edward would that be? The one you could
download or one in real-life? If the former then just watch it again?
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old May 30th, 2004, 08:52 AM   #1819
RED Code Chef
Thanks!!
Old May 30th, 2004, 09:53 AM   #1820
Hello,
Thanks for responding.. umm, i was hoping that would not be the case.. one thing is i already have an opeing piece of video..
I guess i could split the second piece in half, and have it play into the third using end actions..??? ( have not yet tried it) I just wonder will it go to black between the two.. because i would really like to have them butted together..
By the way the demo with Edward was live about a week ago here in Orlando..
Mike
Mike Moncrief mikemoncrief@gmail.com
www.themikemoncrief.com
Mike Moncrief is offline
Old May 30th, 2004, 10:26 AM   #1821
RED Code Chef
You could also stick the first 10 seconds onto the end of the first
play movie.
Perhaps someone else has a better idea. I haven't looked too
good at DVD Architect yet.
Old May 30th, 2004, 10:30 AM   #1822
RED Code Chef
That sounds plausible. Different "effects" will yield different
results. Can you point to the exact technique you used (URL)?
I'm not familair with DSE's method.
Old May 30th, 2004, 10:57 AM   #1823
You can create an invisible button by pulling the alpha channel to full transparency. Position it to where your text appears on your video background.
Gary
Gary Kleiner is offline
Old May 30th, 2004, 11:00 AM   #1824
Vegas end encoding for web
Hello,
Another question(or questions), i have some video that needs to be encoded for the web from Vegas 5..Is there a size that is common to make the video for the web 320X240 ? or a different size?? And how are the codecs for rendering out Video from Vegas?? I see it has several, Windows Media, RealPlayer, Quicktime Mpeg..Do any one of these codecs in Vegas do a better job?? (Highest quality, smallest file size) Or should i look elsewhere for something to encode the files?
Mike Moncrief
Old May 30th, 2004, 11:11 AM   #1825
RED Code Chef
Vegas basically has all the tools you need. Which format you want
depends on what you like and what formats you want to support.
The two biggest are QuickTime and Windows Media Player. I would
not go with Real because a lot of people really dislike the client
and do not have it installed on their machines (me included and
I'm not going to install it whatever happens).
QuickTime seems to be the best served in the market at the
moment, but WMP seems to have a slightly better compression
scheme.
Most people swear by the Sorenson (3) codec under QuickTime.
Do some tests and see what you like! On our Lady X project
we used QuickTime with the previous version of the Sorenson
codec (check out the link in my signature).
Old May 30th, 2004, 12:46 PM   #1826
24p woes...
Rob, this is DSE's procedure for filmic look:
http://www.sundancemediagroup.com/tu...s/filmlook.htm
Actually, I've found the culprit!(and its accomplice--reading too fast and not following all directions) A part I glossed over, was disabling resampling on the video. At first, it didn't make a difference, but when I changed the deinterlacing method to interpolate frames---voila! No ugly motion trail!
It still looks like the bullet stuff has better resolution, I dunno.
Anything else I can do to get the best possible picture out of 24p and Vegas?
(By the way, loved the look of that Lady X episode! That thread on how you achieved the look was great help and guidance!)
Irbbins Biarrieta is offline
Old May 31st, 2004, 04:17 AM   #1827
RED Code Chef
I'm glad you found the source of your problem. I don't have much
experience with de-interlacing myself since I always shoot in
progressive (or semi progressive with the XL1S). It is not really
suprising that the magic bullet stuff seems higher resolution. That
product was specifically made for things like this. Vegas just
added it. But if it is close to the magic bullet stuff then I'd say it
is doing a pretty good job!
Thank you for your comments on my episode. Much appreciated
and I'm glad you enjoyed it and the thread about it. Thanks!
Old June 1st, 2004, 06:36 AM   #1828
I'm sure you've probably worked it out by now, but if not, you are missing the 'clip explorer' which you can reactivate from the drop down menu.
I figured it out (simple solution) a little while ago, but haven't been on the forum for some time.
Sunny Dhinsey
Director - www.filmlore.tv
Sunny Dhinsey is offline
Old June 1st, 2004, 10:42 AM   #1829
Slash Rules!
Yeah, I did figure it out. I don't know how I made it disappear in the first place.
Josh Bass is offline
Old June 1st, 2004, 01:59 PM   #1830
Sponsor: JET DV
Tsunami Update Available
Tsunami has been updated with the following corrections:
1. Extract Good Clips now works correctly when audio is selected.
NOTE: When extracting both audio and video, you will get TWO sub-clips placed in the media pool.
2. PIP tool now places the PIP in the proper location.
Send me an e-mail for details.
