Vegas Video discussions from 2004 (Q3Q4) - Page 3 at DVinfo.net
Old July 4th, 2004, 04:11 PM   #31
i don't have vegas5 yet but on a related note,
if you buy ONE copy of vegas5 that comes with 2 MORE nodes of network render, does that mean that you can install vegas5 on total of 3 computers and edit on all 3 computers at the same time regardless of render? i'm guessing that this only applies to the render nodes and not the editing software itself. it's sorta like microsoft windows xp. if you buy one copy you can only install it on one computer, correct?
bow wow wow
Yi Fong Yu is offline
Old July 4th, 2004, 10:08 PM   #32
Sponsor: JET DV
You can buy one copy of Vegas and install it on three computers. You can then network render with those other two computers.
You CANNOT legal edit on all three computers AT THE SAME TIME.
Edward Troxel is offline
Old July 4th, 2004, 10:10 PM   #33
Sponsor: JET DV
When you capture from minidv, you don't set any properties - you just capture. Over firewire it's like copying a file from the tape to the hard drive.
Frame mode is still 29.97.
Old July 4th, 2004, 10:45 PM   #34
is there a equivalent of adobe premiere's razor tool in vegas?
i like to cut the clips in half but i've yet to find th equivalent. anyone?
bow wow wow
Old July 4th, 2004, 10:47 PM   #35
i notice that. but since it is 29.97, then does this mean that all of the rest my steps should be in 29.97 and nothing else?
step1:
this is now understood to be fixed depending on your camera/tape. if you have a 24p capture then your dv tape will have 24p here, is this correct?
what about the rest of the steps? how do i do steps2 through 4?
bow wow wow
Old July 4th, 2004, 11:43 PM   #36
Space Hipster
XL1s frame mode is 29.97p - that means each field in the 60 interlaced fields per second signal is progressive.
Capture is just 29.97 standard mini-DV. For project properties, choose 29.97, set to progressive and deinterlacing to "none". That's all.
stephen v2
www.insaturnsrings.com
Stephen van Vuuren is offline
Old July 4th, 2004, 11:45 PM   #37
Space Hipster
"Split" (hit the "s" on keyboard and highlight clip with be cut in at cursor point).
stephen v2
Old July 4th, 2004, 11:46 PM   #38
Space Hipster
External Control Surfaces Anyone
The mackie universal control surface is a cool $1000. Anyone tried any less (much less) expensive alternatives with the generic driver?
stephen v2
Old July 5th, 2004, 03:25 AM   #39
go get urself a Phatboy, or a kenton midi station :)
these are midi controller devices for audio, btu worl fine with V5.
I use my Yamaha RS7000 workstation :)
Peter Jefferson is offline
Old July 5th, 2004, 03:27 AM   #40
ARGH!!!!!!!!!!!!! :(
Old July 5th, 2004, 04:05 AM   #41
RED Code Chef
I'm gonna be a bit harsh here, sorry <g> There is a sticky thread
on top of this forum called:
Quick reference: Vegas shortcuts and mouse gestures 1.0b
It links to a PDF that contains all these nice little keyboard
shortcuts and other much used tricks in Vegas to complement
the manual (in which you could also have found the split option).
Please take the time to view and read the PDF in the link above!
Thanks.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old July 5th, 2004, 07:54 AM   #42
Sponsor: JET DV
This has to be one of the most asked questions from people coming from Premiere. Fortunately, in Vegas you don't need a "tool" that you have to select to simply split clips into multiple pieces. As Rob said, there's LOTS of keypresses that can help speed your workflow.
Old July 5th, 2004, 09:54 AM   #43
ok ,great thanks!!! =).
bow wow wow
Old July 5th, 2004, 10:00 AM   #44
thx for the links.
bow wow wow
Old July 5th, 2004, 10:36 AM   #45
16:9 and Vegas
Hi. I just discovered my rinky-dink Canon ZR20 has a squished 16:9 widescreen function. I'm using Vegas 5, and I had some quick questions that I'm trying to figure out.
1) The widescreen format looks fine in Vegas. The source media file is NTSC Widescreen. The veg project file is NTSC Widescreen. However, when I render to NTSC DV Widescreen format, the resulting file still appears squished in Quicktime or Windows Media player. Is this normal? I'm assuming that it is -- and that it will only look "correct" on a proper monitor/TV or if I render to a widescreen DVD.
2) Since I primarily make avi's, wmv's, and mov files, I'd like the widescreen look without the black bars. Is there anyway I can do this -- getting rid of the bars -- in Vegas? When I just try to crop the footage or when I try to change the actual render video size, I either get black bars or more squish. It seems rather bone-headed of me not to figure it out, but I can't quite figure this out.
Thanks.
Robert Kirkpatrick is offline
