High Definition with Elphel model 333 camera - Page 68 at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Alternative Imaging Methods > Apertus: Open Source Cinema Project
Old December 17th, 2008, 03:34 AM   #1006
Thanks for the feedback.
Automatic naming schemes are a great idea and also easy to implement.
You could work with camogmgui and camvc in 2 browser tabs, but I agree we need an user interface that does everything needed for filmmaking in a single application.
But in my opinion a website is in general not the primary choice for a filmmaker who is used to real time previews and that sort of stuff.
I recently tested some things in Java (real time histograms from the camera) and was quite happy with the results.
Java is nice because it's working on all platforms and can be run in a browser as applet or as a standalone app.
Maybe this could be a possible way to go for a realtime remote control application (with live video, not just image reloads).
Sebastian Pichelhofer is offline
Old December 17th, 2008, 09:09 AM   #1007
What about using USB input device channels to trigger specific events, such as image formats?
If someone were to hack a USB controller, such as multibutton mouse, so that a rotary switch were wired into the various switch circuits, we could use the mouse click on states to tell the software which mode the camera was in.
This would be a very high level modification. Other more graphical changes, such as luma and color settings, would likely need to be more dynamic, as the camera operator would need to be able to respond to the needs of the moment. Maybe a choice-based approach based on a SETUP command that let you set white and black points? I would think that we would want to leave any deep color decisions until post production.
Brandt Wilson is offline
Old December 17th, 2008, 12:10 PM   #1008
Originally Posted by Oscar Spier View Post
One other important thing to make the camera much more user friendly would be to integrate the necessary parts of the camvc to the camogmgui. As I understand... you need to set the camera up (exposure framesize color setting etc.) in the camvc before going to the camogmgui. (for people who don't know what I'm talking about: camvc and camogmgui )
Would this be possible? (maybe in frames if it makes things easier?)
We only need basic things: frame sizes (only video and film sizes I'd say) exposure - brightness or gain and color settings. Color setting can also be basic presets like: warm - cool - neutral - B/W etc. (maybe mimic some film types)
On the format tab we could use the compression quality setting.
Oscar,
I believe we'll improve/restore camvc - originally it had "DVR" capabilities with VCR like control buttons - we'll make something similar with the HDD. I spent some time recently on camvc in 8.0 software, it is now much more stable and the controls have ability to hide (screen shot shows live video through mozilla-plugin with the overlaid controls. I also made some cleanup there, split the code into more files to simplify future modifications.
Spectr is working now on improving the video streamer, including making it friendly to the camogm when used as preview tool - reduce its fps if the CPU resources needed fro continuous recording to HDD are running low. In the next plans fro the streamer - make it capable of streaming recorded files (providing timestamp-based search), so youi can watch them as on a camcorder (including FF play capability, play while recording).
The second screenshot shows development environment for the software - it is KDevelop
http://community.elphel.com/screensh...evelop_80.jpeg
Andrey Filippov is offline
Old December 27th, 2008, 01:03 PM   #1009
Hello Everyone.
I've been redesigning my 35mm adapter. Because the size got a bit bigger than I wanted, I'd like to keep the distance between the Elphel and the projected 35mm image as small as possible, like 20 mm from the front of a small lens. This should not decrease the quality of course..
How can we choose the right lens for this purpose? The Elphel uses a 1/2.5" sensor (correct me if I'm wrong)... but not all the sensor is used. So that leaves us with 4mm (?) width sensor. Using this example, I would come up with an FL= 23mm lens. (4mm sensor x 20mm distance / 35mm image)
Am I correct on this one?
Now what options do we have in this range of (small) c-mount lenses?
Oscar Spierenburg is offline
Old December 29th, 2008, 11:37 AM   #1010
My last post didn't seem to make much sense when I compare it to this page.
I'd get a FL 2.41 lens (or at 30mm distance a FL 4 lens)
I also remembered this post some time ago. So we should best be looking for an affordable machine vision prime.
Old December 30th, 2008, 12:58 PM   #1011
Oscar, I understand that that would increase the size but I would still recommend you to use a pair of lenses to translate image from the "ground glass" plane to the sensor. The one closest to the sensor is a good quality short focal length C-mount lens - you may even consider 12mm mount ones - they are small, high resolution but low power. The second lens - 35mm one turned backwards, with focal length proportionally (~ 5-6 times) longer that the one attached to the camera. That lens does not to be anything super - F-number used will be proportionally higher than that of the first lens (only center part will be used), so some simple lens with small number of components should do the job.
Such two-lens configuration is normally used when you need high quality image translation without a special lens.
Old December 30th, 2008, 07:23 PM   #1012
Ah, now I remember you mentioned this before. I'll experiment with this tomorrow!
I've made a lot of progress lately (actually been working every day on the camera this month)
The rods support has now a mount for the netbook. This is the first step to make this whole thing portable. Tomorrow I'll post some pictures.
Old December 31st, 2008, 04:03 PM   #1013
Here are two pics of the rods with the tablet PC mount and the 35mm adapter.
It's not a designed thing... just a rough setup.
Andrey, I've done some experimenting, but I can't really figure out what you mean with the 35mm lens turned backwards. Is there an example of this setup somewhere on the web?
High Definition with Elphel model 333 camera-cam-tabletpc-front.jpg   High Definition with Elphel model 333 camera-cam-tabletpc-back.jpg
Old January 1st, 2009, 05:48 AM   #1014
Wow that's a decent piece of equipment!
How exactly does the new 35mm adapter work compared to the old microwax static groundglass one?
Old January 2nd, 2009, 09:47 AM   #1015
Sebastian, the 35mm adapter is adapted from a photo-enlarger. It has a focusing mechanism on the side like a follow focus. Much too imprecise to be really usable, but I can easily put some gears in between the original and a new focusing knob to make it work like a FF.
Originally Posted by Andrey Filippov View Post
....The one closest to the sensor is a good quality short focal length C-mount lens - you may even consider 12mm mount ones -
Does anyone have experience with the quality of machine vision lenses? How about this one?
Old January 3rd, 2009, 01:04 AM   #1016
M12 lenses
Oscar, I meant M12 lenses like these:
Miniature CCD/CMOS lens for 1/2" or larger format imager
1/2” Megapixel Fixed Lenses
TECHSPEC Megapixel Finite Conjugate µ-Video Imaging Lenses - Edmund Optics
or just
http://www.google.com/search?q=M12+megapixel+1%2F2"+lens
Old January 12th, 2009, 06:38 AM   #1017
Hi everyone,
For those who don't know; the camogm2 camera software can record audio ( see wiki )
One audio USB device I came across that I'm considering to buy is this USB Dual Pre.
It doesn't need additional drivers and I've read that it runs perfectly on Linux. It has direct monitoring headphone output and two XLR mic inputs with phantom power option.
Any thoughts?
Old January 22nd, 2009, 07:46 PM   #1018
Tascam US-122 is a classic, very good quality for the value.
I personally own the next model, the US-122L which is very nice & 24bits/96Khz but with poor drivers, and definitely no linux drivers :/ (Hope ?)
You should look for Class Audio Usb device as they are part of the usb standard and as such, supported by linux.
Steven Mingam is offline
Old January 23rd, 2009, 05:31 AM   #1019
Mic prea-amp with linux
Digigram UAX220Mic professional USB Audio interface for broadcast and other demanding pro audio applications featuring 2/2 balanced analog high-quality I/Os
please take a look, maybe a bit $$$$ but it works smooth with Linux.
I 'm digging for a cheaper alternative, there should be one
maybe even a kit
Ha found it in the disk nirvana on my Linux companion
Waoooooh
have a look, that looks cool, and is what we need
small and idiot proof in the field
no drivers no hassle
Plug XLR Mics Direct to USB - Kompoz.com
enjoy and good recording
ah and maybe the best one
BEHRINGER: UCA202
has A/D has SPDIF out, works with audacity, should be fine with Linux
a firewire version is also available
Régine Weinberg is offline
Old January 23rd, 2009, 08:01 AM   #1020
I'll receive the ART dual pre next week. I've chosen this one because it's exactly what we need (and not more than we need): a mic pre amp with phantom power and direct monitoring output. It's a lot like the Tascam US-122, but smaller.
Of course it doesn't really matter what it looks like, but I think it would integrate very nice on the camera. Could be made detachable when you're using a sound operator.
I'll let you people know when I have it and if it works as good on linux as I've read.
  You are here: DV Info Net > Special Interest Areas > Alternative Imaging Methods > Apertus: Open Source Cinema Project
