Awesome news for canon users - Page 14 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
Including the HVR-MRC1K CF Card Recorder, HVR-DR60 Hard Disk Recorder and others.
Old December 7th, 2008, 11:17 AM   #196
Does the Sony work with Canon's proprietary 30p and 24p frame rates? BTW I am not trying to promote the Firestore but simply am trying to compare the two devices. The Firestore FSC does work with 30, 24p.
Guy Shaddock is offline   Reply With Quote
Old December 7th, 2008, 11:22 AM   #197
Yes it works flawlessly. No problems at all.
Monday Isa is offline   Reply With Quote
Old December 7th, 2008, 01:46 PM   #198
They're not really proprietary as much as the correct and best way to store progressive frames within MPEG2. Sony's newest cams use the exact same progressive method to store 24P footage now, so they didn't make any special effert per se to support Canon. You could say they caught up :)
www.philipwilliams.com
Philip Williams is offline   Reply With Quote
Old December 7th, 2008, 03:45 PM   #199
Interesting
Is there a Sony deck like the Walkman that will play back Canon now?
Old December 8th, 2008, 12:21 AM   #200
Not sure how many products are compatable, but at least one of Sony's recent professional decks plays back 24P, including Canon's. Maybe someone else can remember the model? It was definitely a pro deck though, nothing like a Walkman.
Old December 8th, 2008, 12:39 AM   #201
It's the Sony HVR-M35, their most recent HDV VTR. Hope this helps,
Old December 9th, 2008, 07:59 AM   #202
So, is nobody using the Sony HVRMRC1 with XH-A1 at 25F? Would be great to get confirmation that the recorder supports this mode before buying one. So far haven't seen any indication whether it works or not.
Richard
Richard Hunter is offline   Reply With Quote
Old December 15th, 2008, 02:40 PM   #203
playback
Can the MRC1's playback be viewed on the A1's LCD and on a monitor attached to the A1?
Thanks.
Jim Schweer is offline   Reply With Quote
Old December 16th, 2008, 08:43 AM   #204
Richard
if you look 5 posts further up you will find the answer :)
Old December 16th, 2008, 09:13 AM   #205
Thanks.
It can be played back on the LCD. Haven't tested it with a monitor.
Tiffany McMichael is offline   Reply With Quote
Old December 18th, 2008, 01:24 AM   #206
Richard
Yes it does the previous post talk about 24p and 30p but I have checked and UK online stores sell it which would mean it would need to record at 25p/50i otherwise not much point selling it in UK.
and to prove it further here is the Australian manual that comes when you buy the z7p and go to page 28 stating it accepts all formats http://www.metroscreen.org.au/pdf/Ma...Z7P Manual.pdf
So no more questions about it.. man I want one. especially that it has interval recording as well which the A1 itself doesn't :)
Peter Szilveszter is offline   Reply With Quote
Old December 18th, 2008, 02:22 AM   #207
I suspect this feature is for the Sony camera rather than the A1
Old December 18th, 2008, 02:58 AM   #208
It doesn't mention anything about it in the Manual except that its only in DVCAM/DV mode which is a shame.
Old December 18th, 2008, 07:26 AM   #209
I ordered one. I notice is stores SD video in AVI or "RAW DV". What file format is the latter? Is it supported by FCS 1? TIA
Old December 19th, 2008, 03:04 AM   #210
Has anybody tried the interval timer recording mode. Does it work ok
Mick Jenner is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Sony Hard Drive and Memory Card Recorders
