SDHC substitute for SxS cards - Page 56 at DVinfo.net
Old November 6th, 2008, 06:15 AM   #826
Ross,
please email me the link to the working card.
You will have to send a private message since ebay links are not allowed.
thanks
Old November 6th, 2008, 08:13 AM   #827
initial format errors
My Kensington 7-in-1 Expresscard 34 arrived today (my Sandisk 16GB Ultra II SDHC card arrived at the weekend).
Put it all in slot 1 of my EX3, closed the door .... :-) and then turned the EX3 on. So far so good.
Then I got a message asking me to format the card so I did. Then I got a "media error, cannot format" type error.... :-(
Turned it off, unplugged everything, re-mounted everything and after 3 unsuccessful goes at this it finally formatted successfully. EX3 now shows 58mins available in slot 1 ...back to :-) !!!!
Recorded a few quick clips and everything now seems to be OK. I'll certainly put it through it's paces before I'll trust it with an hours worth of important clips though.
Did anyone else get a worrying introduction to using SDHC like this?
Old November 6th, 2008, 08:51 AM   #828
Hope all goes well for you Andy. Why did you chose Sandisk, I thought Kensington 7-in-1 and Transcend was the working combination.
Anthony McErlean is offline   Reply With Quote
Old November 6th, 2008, 08:52 AM   #829
Mine went flawlessly - formatted successfully and perfect ever since.
Sony EX3, Vegas 9.0 64bit, Windows 7(64), Core i7, 12GB, RAID1 & 0, HotSwap SATA, 30" LCD(2560x1600)-GTX285 & 24" LCD(1360x768)-7800GT
Ted OMalley is offline   Reply With Quote
Old November 6th, 2008, 09:05 AM   #830
Ted, what combination did you use.
Old November 6th, 2008, 09:13 AM   #831
I've only used the Kensington reader.
I've used both the SanDisk Extreme III 16GB card and the SanDisk Ultra II 16GB card.
I'm waiting to receive shipment on the SanDisk VideoHD 16GB card and the Transcend 16GB card.
Old November 6th, 2008, 09:15 AM   #832
Ross - How large is the Hong Kong-made adapter? Does it allow for EX1 door to be closed?
If link is not allowed (??) then please provide a search phrase to find the item.
Alex Raskin is offline   Reply With Quote
Old November 6th, 2008, 09:20 AM   #833
Thanks Ted, wonder why Andys EX3 gave those messages.
Old November 6th, 2008, 09:35 AM   #834
Just received my Kensington 7-in-1 from Amazon.de,
made in China, waiting for Transcend and Sandisk SDHCs. Will report if any errors occur.
Peter Kraft is offline   Reply With Quote
Old November 6th, 2008, 10:12 AM   #835
Again, the Kensington+Transcend combo has worked flawlessly for me so far. You can't beat the price!
Jay Gladwell is offline   Reply With Quote
Old November 6th, 2008, 11:00 AM   #836
With a fresh un-formatted SD card you need to switch the camera on then insert the adapter with the card already in it into the camera and then format it. I think the camera gets a little confused when you power it up with an unformatted SD card already in it.
Be sure you buy your SD cards from reputable sources as there are an awful lot of fakes out there. They might appear to work but could prove un-reliable later.
Old November 6th, 2008, 01:07 PM   #837
OFFLOADING the SDHC cards in the field - solutions
I thought this would warrant a separate thread:
http://www.dvinfo.net/conf/sony-xdca...ing-field.html
Old November 6th, 2008, 02:15 PM   #838
I've got 2 SDHC combos with the Sandisk Ultra II 16GB cards and 2 Kensingtons. (Amazon UK)
One works brilliantly, even with overcranking at 50 fps(is it meant to?), and the other is a little bit tempermental - about 3 times now has given me the needs to restore message. Swapped around the cards and Kensingtons and it seems to be the card not the reader. Will keep testing as obviously don't trust it yet.
Gary Barr is offline   Reply With Quote
Old November 6th, 2008, 04:02 PM   #839
My two Transcend cards arrived today. They are performing well. Each one asked to be formatted, then was ready in two seconds.
Old November 6th, 2008, 07:19 PM   #840
Sponsor: eFilms (MxR)
Express card readers
Hi Alex,
It sticks out as well, sorry about that.
I found mine on Australia's ebay, add ".au" on the end of the US one, then search for expresscard readers, mine came from the Philippines, if that helps you find it.
Ross Herewini - E-films
Makers of the new MxR Extreme
Ross Herewini is offline   Reply
