Will Adobe PPro CS3 work with Windows 7 64bit at DVinfo.net
Adobe Creative Suite
Old October 22nd, 2009, 03:28 PM   #1
Need Help. I have done a ton of searching in this forum but haven't found an answer yet. I am planning on upgrading from Windows XP Pro to Windows 7 64bit. I am using Premiere Pro CS3. The Question is..... will Adobe PremierePro CS3 work with Windows 7? I apologize if I did something wrong in my searches. I've been at it for about 3 weeks.
Thanks in advance.
Harry
Harry Lender is offline   Reply With Quote
Old October 22nd, 2009, 03:55 PM   #2
Can't say for sure since I haven't tried it myself, but if you have problems with software on Win 7, supposedly the XP Mode should allow you to use just about anything that ran on native XP (virtualization required).
Pete Bauer
Old October 22nd, 2009, 08:02 PM   #3
Premiere CS3 installs OK and seems to work fine in Win7 (64 bit). Presently some users including myself have had problems using CS3 in combination with Cineform - playback from the timeline of CFHD files has been malfunctioning.
Cineform posted a workaround for that problem today: see post #10 here http://www.dvinfo.net/forum/cineform...-playback.html
Because of this glitch I have not so far done any significant rendering-out from CS3 under Win7, so I can't comment on that aspect.
When I ran into the Cineform problems I tried Windows XP virtualization mode, as it did sound promising. Unfortunately it provided only very limited support for my Nvidia GTS250 ... while in virtual mode it installed its own generic graphics card drivers and I couldn't get it to replace those drivers with proper NVidia ones. YMMV on that.
Last edited by Graham Hickling; October 23rd, 2009 at 12:55 AM. Reason: Clarification: this post is referring to 64-bit Win7.
Old October 22nd, 2009, 08:22 PM   #4
I haven't tried it but I'm sure it will work. You can also right click on the program item, properties, then Compatibility to emulate running in Windows XP with SP3.
LA Color Pros Blog
Old October 22nd, 2009, 09:11 PM   #5
Thank you everyone for your responses. I am not using Cineform at this time. Maybe at a later time.
I will probably make the switch to Windows 7. Again thanks for all your help.
Harry
Old October 23rd, 2009, 12:36 AM   #6
Have you try setting the compatibility mode of the setup program? That might fix the installation issue.
LA Color Pros Blog
Old October 23rd, 2009, 12:36 AM   #7
Regarding 64bit versions of Windows 7, the truth is that I failed to install CS3 on it. Maybe in 32bit it works just fine, but on 64bit there is a problem with the installer (at least in my case). XP Mode may be the solution but this option doesn't come with every version of Windows 7.
Dimitris Mantalias is offline   Reply With Quote
Old October 23rd, 2009, 09:41 AM   #8
Another Question
I am using scenalyzerLive for capture now on WinXP Pro. My Question is: Will scLive work on Window 7Pro 64bit?
Thanks again for you help
Harry Lender
Old October 29th, 2009, 04:26 PM   #9
Yes, it works.
Old October 30th, 2009, 06:07 PM   #10
I'm running Windows 7 x64 and I have the whole Adobe Master Suite CS4 installed. Of course only Photoshop can run 64-bit, but the installation went smoothly and I haven't experienced any problems yet.
Steve Pond is offline   Reply With Quote
Old November 2nd, 2009, 02:08 PM   #11
Win 7 Home premium 64 bits with CS3 works!
Sony Z7U, Canon 5D Mark II, Canon 24-105 F4L, Canon 70-200 F2.8L, Canon 580 EXII, Zoom H2.
Jun Galinato is offline   Reply With Quote
Old April 12th, 2010, 10:16 PM   #12
CS3 Production Premium and Win 7 64 bit - no Premiere
I have CS3 Production Premium. It has worked just fine since I purchased it in 2008 on my AMD Athalon X2 dual core pc running Windows XP pro. I recently upgraded to Windows 7 Pro - 64 bit. By upgrade, I should say I did a clean "new" install on a new C; drive. My CS3 and all video editing software is on G: drive. I reinstalled CS3 from the original discs. All seemed to go okay, but in the All Programs list under "Adobe Creative Suite 3 Production Premium" there is no listings for Premiere, After Effects, Encore, or Photshop. I have Adobe Device Central, Extended Scripting, Flash, Illustrator, Soundbooth, etc., but not the main ones that I use. I tired the Adobe site, but couldn't find any helpful info there (its all pumped up on CS5). Anybody else having this problem, or found a solution? I'd sure appreciate hearing from you. Thanks - PK
Paul Kepen is offline   Reply With Quote
Old April 12th, 2010, 11:34 PM   #13
It should, according to Microsoft...
Windows 7 Compatibility for Adobe Creative Suite 3 Design Premium: Adobe. Drivers, Updates, Downloads
Ervin Farkas
www.AtlantaLegalVideo.com
Old April 13th, 2010, 09:07 AM   #14
I did just as you did with a clean install of Windows 7,etc and CS3. However I installed on my "c" drive with no problems. Everything operates great. Nothing missing. Hope this helps.
Harry
Old April 14th, 2010, 12:18 AM   #15
Thanks Harry and Ervin. I tried uninstalling the entire CS3 suite and reinstalling. Premier seemed to work, but Photoshop seems to hang up indefinitely while loading. See attached image. I don't know if just reinstalling photoshop again will work or not. I'll give that a try tomorrow night. It seems to hang at the "Starting-up Plug-ins...nik color effex Pro 2.0 Selective...."
Is it just that plug in? Is there away to disable it during start up?
Thanks again guys for your help - PK
