Various GL1 / XM1 questions - Page 28 at DVinfo.net
Old May 21st, 2005, 06:23 AM   #406
Fred Retread
I'd place my bet on vibration. There are a lot of ways that mechanical resonance can bite. Can you soften the mount at all to see if there is improvment?
BTW, Jeff are you in CT by any chance?
"Nothing in the world can take the place of persistence..." - Calvin Coolidge
"My brain is wired to want to know how other things are wired." - Me
David Ennis is offline   Reply With Quote
Old June 14th, 2005, 04:19 PM   #407
GL1 Quaility vs Vx1000 Quality
I have a GL1 and I know that the GL1 has 270,000 pixels per ccd and the VX1000 has 410,000 pixels per ccd. I was just wondering if pixels play a big role in quility and if the GL1 can produce an image as good as the VX1000.
Andrew Mills is offline   Reply With Quote
Old June 14th, 2005, 04:39 PM   #408
Personal preference...
VX = cooler color/ sharper image
GL = warmer color / softer image
Sharper does NOT mean better, just sharper =o)
ash =o)
Ash Greyson is offline   Reply With Quote
Old June 15th, 2005, 03:12 AM   #409
Ash is right, it's more a preference (hope that's spelled right).
I think it depends on what you want to make. Maybe (and this is still your own choice) the GL1 is better for moviemaking because it has a more 'filmic' image, via the warm colours and the some softer image, but the VX1000 is maybe the best for weddings, scate boarding movies,...
And also remember, what feels right in your hands.
I have an XL1s but for an event I played with the Sony PD170, but I preferred the Canon much more because where buttons are placed etcetera, and the menus, it was much easier, although the PD170 is image quality - wise, much better for event videography (better low light, much less noise).
But other people may find the Sony easier to work with.
So, if you have the chance, pick both up (or maybe in stores a VX2100 and a GL2 as they are easier to find and have a lot in common with their precedors) and look what you like the best.
Mathieu Ghekiere is offline   Reply With Quote
Old July 31st, 2005, 05:35 AM   #410
Hi what do you want to do. Do you want to set up a internet tv channel or do want to use it as a web cam. if you want to set up a internet tv channel you will need severs. if you want to use it as a web cam you just select the camera in the msn messenger video/audio options. i use it all the time in msn messenger. it works great.
Nathaniel McInnes is offline   Reply With Quote
Old July 31st, 2005, 05:36 AM   #411
Can i just say something. the NSTC version of the camcorder is called the GL1 and the pal version is called the XM2
Old August 2nd, 2005, 07:52 AM   #412
Manual for GL1
I just bought my first prosumer camera, the gl1. My problem is that it did not come with the manuel. Does anyone know if the manuel can be downloaded from any sites or maybe someone has a manuel that they are not in need of anymore? Any help would be great.
Jesse Parsh is offline   Reply With Quote
Old August 2nd, 2005, 08:06 AM   #413
Fred Retread
All the major camcorder manufacturers are now very good about this. Here you go:
http://alpha02.c-wss.com/inc/ApplSer...nu=MA&TRF=MAIN
If you have any trouble with the link, let me know and I'll email you the .PDF file myself
Old August 2nd, 2005, 09:50 AM   #414
Retired DV Info Net Almunus
The GL1's manual is also available from the Canon site:
http://consumer.usa.canon.com/ir/con...6&modelid=7376
Old August 2nd, 2005, 10:09 AM   #415
Fred Retread
Right. It's ultimately the same link.
Old August 2nd, 2005, 03:11 PM   #416
You guys rock! I'm so glad I found this site.
Old August 2nd, 2005, 03:13 PM   #417
Old Boot
. .and we are glad you found it too!
Have fun . .. Grazie
Old August 4th, 2005, 05:46 PM   #418
Simpler way
Oops, covered nicely.
Jeremiah Rickert is offline   Reply With Quote
Old August 4th, 2005, 06:02 PM   #419
Air China Pilot
Yes, you can run it live using Firewire. I've done it a few times on XL1s. I assume it would work using GL1 through Firewire.
Visit http://www.KeithLoh.com | stuff about living in Vancouver | My Flickr photo gallery
Keith Loh is offline   Reply With Quote
Old August 5th, 2005, 05:36 AM   #420
Yep thats what i do is use it in msn messenger through firewire except you dont fit as much in
