XL1 / XL1S various posts - Page 19 at DVinfo.net
Old May 2nd, 2002, 01:20 PM   #271
wa adapters
Hello all!
I have been kicking around the idea of purchasing a new lens for my xl-1. I like the idea of getting a 3x wide angle lens or an adapter with the manual 16x.
But the idea of not being able to use filters with the 16x/wide angle adapter worries me. Is this true? Is there anyway around this?
I like the idea of the manual 16x with an adapter otherwise. It seems like more for your buck.
Chet Hardin is offline   Reply With Quote
Old May 2nd, 2002, 01:27 PM   #272
thx!
thank you for info, will contact Canon and see what they can do.
Cheers-
Ford Minton is offline   Reply With Quote
Old May 2nd, 2002, 01:28 PM   #273
Retired DV Info Net Almunus
The 3x wide angle lens is a very handy tool which CAN accept filters. In fact, it has a 72mm thread which is the same diameter as that of the standard 16x auto lens. So you can interchange filters between the lenses.
All other factors being equal, given the choice between the 3x and the 16x manual lenses (assuming you already have a 16x auto lens) I would definitely choose the 3x lens first.
I can't speak for the wa adapter for the 16x lens. I can say that the Canon wa adapter for the GL1's lens does not accept a filter.
If you can swing it, I would highly recommend getting the 3x lens rather than a wa adapter.
Old May 2nd, 2002, 05:13 PM   #274
noise on XL1s
I`m quite happy with a new XL1s except when I crank up the dbs to 18....there is a lot of noise that looks like a very fine rain shower, making such footage useless for most commercial purposes...has anyone else found the same? No camera presets are being used(sharpness etc). I find that only up to db 6 can I rely one a clean image....so what is the use of the higher dbs feature on this unit versus the original XL1?
Peter Sheppard is offline   Reply With Quote
Old May 2nd, 2002, 08:47 PM   #275
dark corners on muted shots
has anyone else in here ever experienced this:
(and i guess this might not exactly be an xl-1 issue but since i shoot with the xl-1 with the standard 16x lens)
but when i first got the camera i got a few filters to go with it... uv and warming. while i was playing around with footage i had shot i noticed something dark in the bottom left hand corner of the screen, what i thought looked like a hair. it drove me bonkers for a couple of hours cause as far as i could tell every part of the lens and camera were clean, until i realized i had put the warming filter on top of the uv filter. so i took both off and the dark "hair" was gone. so i was satisfied that i had just extended the rim of the filter into the cameras view...
but now while editing a short i shot with only one filter attached i think i am noticing the same thing. not near as pronounced as before but still on certain shots, ones with light, muted tones filling in the bottom of the screen i seem to be noticing what looks like shadows.
what could be causing this? is something inside my camera causing this or how the lens attaches or, in the lens?
Old May 3rd, 2002, 02:07 AM   #276
RED Code Chef
Ofcourse this will happen. What you are doing is electronically
enhancing the signal. What you should be doing instead is to
give the chips a signal that does not need enhancing (open up
the lens, remove ND filter, lower the shutter or add more light).
A camera can not "magically" enhance the input it receives
without some down side. I always (at least try) to shoot at
preferably -3db and otherwise 0 db. The option exists for you
to rescue the shot if you truly have no other option. It is possible
to remove some noice in the post-process step but you'll never
get rid of them all without reducing quality.
Rob Lohman, visuar@iname.com
Old May 3rd, 2002, 08:33 AM   #277
This is quite normal for 18db gain, but what you must understand is that there are times when getting a noisy image is much, much better than getting no image at all. Look at all the reality shows on TV... Cops, etc. where there are grainy shots of the pursuit or whatever. Content is king. Content matters over all. And noisy, grainy content shot at 18db or higher will make money for you where no content at all doesn't mean a thing. Hope this helps,
Old May 3rd, 2002, 03:23 PM   #278
Wireless video tap for the XL1?
Looking for a good wireless video tap for use on my XL1. Any suggestions?
BTW- have looked at Super Circuits gear, but most of their units require you to have license to use it (legally that is).
Thx for any replies in advance.
Old May 4th, 2002, 01:38 AM   #279
DAT vs. Radio Mic
Hi all,
what is more advantageous when recording a soundtrack?
To record on a standalone DAT / other machine (other that is to the primary camcorder).
To use a Radio mic into camcorder and have the audio with the video.
Regards
Andrew
PAL XL-1, DV Raptor, Premiere
TOTAL AMATEUR - DOING IT FOR THE FUN
Andrew Leigh is offline   Reply With Quote
Old May 4th, 2002, 06:14 AM   #280
Andrew,
Both methods have pro's and con's. In my opinion it depends entirely on the location/situation you are shooting and also your budget.
A cheap radio mic(VHF) can be affected by interference from lights, etc, but a good one(UHF) can cost $1000's. You can use a cheap recordable MD and get great audio but you've got more work in post syncing. Ideally I'd have both setups available. I've ben looking at DAT's lately. Here in Japan you can get some good Sony ones for <$500.
Adrian Douglas is offline   Reply With Quote
Old May 6th, 2002, 08:45 AM   #281
filtering Wide angle adapters
the subject says it all...
are there wide angle adapters for the manual 16 that can be filtered? or, if i want to filter wide angle shots, do i have to go with the 3x?
thanks
Old May 6th, 2002, 08:52 AM   #282
Re: filtering Wide angle adapters
Check out: www.centuryoptics.com
Martin Munthe
VFX Supervisor/DP/Director
Martin Munthe is offline   Reply With Quote
Old May 6th, 2002, 09:28 AM   #283
cool martin m, thanks!
Old May 6th, 2002, 01:36 PM   #284
EV PL80 Microphone
Hi,
have just been rummaging through my old band gear and discovered my old EV PL80 mic. It is in pristine condition as I only used it for about 6 months. Nice surprise!!!
At the time it was a mid priced mic that was widely used here. Does anyone have experience of this on an XL-1 through the MA-100.
Regards
Andrew
Old May 7th, 2002, 01:40 PM   #285
How can I get rid of 60 Hz Hum on AC adapter?
I just have a quick question on anyone's experiences on getting rid of hum caused by connecting the XL1s to power through the AC adapter. I'm also tied into the house PA and somewhere in between I'm getting a pretty serious ground loop that gives me a ton of grief and noise!! If I run from batteries all is well but I have a couple of days worth of recording to do and this may pose itself to be a bit unpractical. I'm also using the high impedence input since that may make a difference.
I appreciate any help you all can provide.
Ryan Jilek is offline   Reply
