HDLink -- various questions - Page 7 at DVinfo.net
CineForm Software Showcase
Old November 26th, 2006, 11:03 AM   #91
CTO, CineForm Inc.
We only need the last few entries, where the error is reported. Long pages don't help us.
Old December 8th, 2006, 01:34 PM   #92
Buffer Overrun in HDLink
Looking at the log, I'm getting an issue with Buffer Overrun. Is Defragging the only solution for this?
Also, once I start capture, the video will stop automatically after about 7 min worth of footage...
Brian Panelo is offline   Reply With Quote
Old December 8th, 2006, 02:09 PM   #93
CTO, CineForm Inc.
It means your disk is running slower than data coming of the the tape (write speeds of 3.5MBytes/s i.e. not much.) Extreme disk fragementation may be the cause, a or drive/controller failure, or other. Try capturing to a different disk, and if that works investigate what might be wrong with the original disk.
Old December 8th, 2006, 03:13 PM   #94
Thanks David for the quick response. FYI, I'm running Raid 0 and not really sure where to start, but I'll defrag and let you know the results.
Old December 8th, 2006, 03:40 PM   #95
CTO, CineForm Inc.
For a quick test, see if the same issue occurs when capturing to your system drive.
Old December 8th, 2006, 04:09 PM   #96
ok, i think the defrag worked, but now i'm getting the following error in the log:
-"No valid transport stream header"
-"Error: hr (0x80004004 - Operation aborted) in (RTCaptureConvert.cpp at 1315)"
Also, I noticed that the HDLink version that starts is 1.5
I am currently running Aspect v4.2.4 Build 72
Any suggestions?
Old December 8th, 2006, 04:53 PM   #97
CTO, CineForm Inc.
It seems that you aren't get valid M2T data from your camera. Verify by capturing just the M2T then converting that to an AVI. If that works, but RT capture/convert still doesn't, contact support through www.cineform.com/support
Old January 6th, 2007, 02:37 PM   #98
hdlink capture settings...
still playing with the capture settings on my hdlink to capture hd footage from my sony hc3. I've found that if i change the HD file size to large and not on medium It runs so much better. why is this?
Mark Leonard is offline   Reply With Quote
Old January 6th, 2007, 03:36 PM   #99
CTO, CineForm Inc.
Large is higher quality and uses slightly more CPU, otherwise no idea.
Old January 6th, 2007, 03:52 PM   #100
well damn, I was gonna try out this on my dedicated "cature" machine but my 2 weeks have expired, w/o reinstalling windows is there a way I can get another week on that machine's trial period to see if it'll capture with this large setting?
Old January 6th, 2007, 04:11 PM   #101
Originally Posted by Mark Leonard
... is there a way I can get another week on that machine's trial period ...
Contact Cineform technical support.
Best,
Christopher
Christopher Glaeser is offline   Reply With Quote
Old January 6th, 2007, 05:34 PM   #102
Mark, it'll be Monday....
David Taylor is offline   Reply With Quote
Old February 17th, 2007, 01:58 PM   #103
Consistent HDLink 4.3.0 Build 75 Errors
Just upgraded to HDLink 4.3 and the first time I've used it I'm consistently getting the following errors from HDLink.
See http://www.alandmills.co.uk/HDLINK_Errors.jpg for details of the errors I'm consistently seeing
Capturing from my Sony7 FX1E (PAL), what I've found is the following...
I can capture to m2t files ok - or at least I get no errors. Even this is a bit hit and miss though.
Capture and convert (my normal) gives the two errors 2/3rds way down the log consistently everytime I hit the 'start' recoding button.
Any attempt to convert one of the captured m2t files produces the final error.
What do these errors mean?
Is it a coincedence that a few weeks ago because I had some analogue tapes to transfer to DVD I re-installed my Matrox RT.X100 card to make that task easier?
Would the two compete for any resources or anything?
Any help appreciated.
Alan
Alan Mills is offline   Reply With Quote
Old February 17th, 2007, 02:44 PM   #104
OK, Apologies to all, problem solved.
Did a check of everything and seems I had a badly seated firewire capture card. Removed that, leaving just the Matrox card and things are ok now though. Captures seem ok.
Regards.
Alan
Old February 17th, 2007, 03:11 PM   #105
Glad your problem was easily resolved.
Sounds like you're using AspectHD 4.3.0, build 75? There was an audio playback bug in that build of AspectHD, and it has been replaced by version 4.3.1, build 76 which is available for download at Cineform's web site.
Pete Bauer
Pete Bauer is offline   Reply
