#1636 |
Can't you just drag the clip(s) into a new timeline and then copy/paste the audio tracks to your project?
#1637 |
Hi Pat,
I'm not sure if I understand you correctly. You mean drag the clips from the browser into a new timeline? This would work if the in and out points were still set for each clip, but they no longer are. Most of the clips are quite long, and I used several parts of each one, which means I set the in and out points many times.
Media Kobo Japan |
#1638 |
Solved it. Since FCP4.5HD accepted the video, I figured if I could somehow just extract the sound, I would then be able to sync it up in FCP.
Luckily, cleaner6 worked to extract the sound from the .mpg file into an .aiff sound file which I then synched up with the video. Worked well. Printed the whole thing to tape in DVCAM and handed it over to my client this morning. Done. Thanks Jeff!
Thomas |
#1639 |
That sounds right. You should be good to go.
8-Bit uncompressed. |
#1640 |
MPS Digital Studios
I don't have scsi drives, so I'm having to do it with my camera and do a conversion.
heath
My Final Cut Pro X blog |
#1641 |
I'm not sure if I understand... however all editing in FCP is "non destructive" so unless you actually went in with the Finder and deleted your files, then the audio you originally captured is still there.
On the timeline, place the playhead so that it snaps to the beginning of the clip you want to fix. Now double-click anywhere on the clip and it opens in the viewer. Note the timecode. Now move the playhead to the end of the clip in the timeline, doubleclick again and note the timeline in the viewer. You can then go back to the original clip that was used in your sequence, set the in and out points to match, then drag or paste the original to the timeline. Notice that when you open a clip by double clicking it from the timeline that the viewer window shows its in and out points right below the image. I'll bet there's an easier way, but I can't think of it right now ;-) |
#1642 |
I'm not sure if I understand... however all editing in FCP in "non destructive" so unless you actually went in with the Finder and deleted your files, then the audio you originally captured is still there.
#1643 |
Thanks for the suggestion. I thought there may be a quicker way (like a "restore audio" function), but this seems like it will work with a bit of effort.
Media Kobo Japan |
#1644 |
Posts: n/a
after effects render problem
I am having trouble rendering my after effects compositions (mostly ramped slow mo's and some color corrections) to use in FCP. everytime i choose "best settings and full quality" from the render queue i end up with a lot of noise and jumps in the video clip. also, these are only like 4 second clips so its not like i am taxing my powerbook and making it work super hard.
any ideas? |
#1645 |
Rob,
Click on the video clip in the timeline. Press "f". The original clip with in/out points set will show in the viewer. From there you can restore the audio, a number of ways -- depends on the target audio and video tracks, and if something is already there, etc. But, You can now see the original audio in the viewer. Not quite as nice as a "Restore" audio command...
Michael A Westphal |
#1646 |
Michael, thanks for your suggestion!
This does exactly what I need, with minimum effort. Thanks!
Media Kobo Japan |
#1647 |
RED Code Chef
It shouldn't be that much of a difference. Ofcourse if you can it is
always best to match the tutorial/book/video/etc. to your exact version to make sure it follows closely the program you have. Are you going to get this second-hand or buy this new? If new then just ask the company how well it works with 6.5? It is at least better to work with a 6.0 training for a 6.5 version since the basics should be the same, but I don't know that for sure (not used AE in a long time). I hope someone who has experience with both versions can give you a better insight into what is different!
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
#1648 |
Thanks Rob. I'm going to get it new but I don't think there are any 6.5 training videos thus my question. I'll definitely ask if they are close enough for me to use one for another :)
Dmitry |
#1649 |
Posts: n/a
nobody?
#1650 |
RED Code Chef
I don't think there are many Mac After Effects users, so it might
not be that anyone knows. Did you try asking the question on the Adobe forums?
