NLE Mac / Final Cut questions from 2002 - Page 37 at DVinfo.net
Final Cut Suite
Old August 12th, 2002, 05:52 PM   #541
DITTO...
B. Moore is offline   Reply With Quote
Old August 12th, 2002, 06:59 PM   #542
ChorizoSmells
try this site: http://www.macosx.org/
I've had OS X installed for a couple of months but haven't really used it, I should make the jump and switch all my work to it so I'm still learning myself. hope this link helps.
ChorizoSmells Video
Barrio Tamatsukuri, Osaka, JAPAN
Rik Sanchez is offline   Reply With Quote
Old August 12th, 2002, 07:57 PM   #543
<<<-- Originally posted by chorizosmells : try this site: http://www.macosx.org/
I've had OS X installed for a couple of months but haven't really used it, I should make the jump and switch all my work to it so I'm still learning myself. hope this link helps. -->>>
Rik,
Thank you for the assist. It appears that this site will go a long way towards helping me learn the OS. The other sites that I found have not come close to what this one offers.
Paul Sedillo
Image::Studio
http://www.image-studio.com
Houston, Texas
Paul Sedillo is offline   Reply With Quote
Old August 12th, 2002, 07:58 PM   #544
What I did when I made the switch from OS 9 to OSX was to spend a couple of hours at Borders reading OS X Bible (or some instructional book like that) I didn't think it was worth buying but just reading through the book at the bookshop, I was able to see what the OS was capable of, and made some mental notes about things to try out. I read it once and now I'm using the OS a lot more efficiently. A low/no cost tip, hope it helps.
Adrian
Adrian Seah is offline   Reply With Quote
Old August 12th, 2002, 08:00 PM   #545
DVD audio tested and compared
Well, I didn't have time to re-encode the AC-3 audio, but I did burn a test disc with both the Dolby Digital and PCM streams on it, and here's what I've found:
The difference in quality is less noticable on my surround sound system than what it was on my studio monitors. I image there would be no noticable difference when played back through standard television speakers.
The AC-3 audio was, however, noticeably lower in volume.
I suppose I'll just put both audio streams on the final disc and let the users decide which one to use; PCM for a better audio experience, or Dolby Digital for smoother playback on some systems.
Someday I'd like to try a 5.1 surround mix and compare that with the PCM stream.
Media Kobo
Japan
Rob Moreno is offline   Reply With Quote
Old August 12th, 2002, 08:11 PM   #546
The Maine Workshops
<<<-- Originally posted by Ken Tanaka : Welcome Daniel!
Interestingly, I was recently considering attending one of the workshops up in Maine (the 2 week documentary class). I think Charles Papert, one of our other moderators here, has also been an instructor up there in the woods. -->>>
Hi Ken,
The Maine Workshops is an excellent learning enviroment and community unto itself. The summer FCP classes have basically winded down now, but they will continue again next season and we will have a good time being there.
For those who want to know more, visit:
http://www.theworkshops.com
Happy filmmaking,
Dan
Daniel Berube
Apple Certified Trainer
Member, Apple Consultants Network
noisybrain. Productions
digital_storytelling/
www.noisybrain.com
(781)-740-5012 tel/fax
(617)-331-8991 cell
President/Apple Ambassador
Boston Final Cut Pro User Group - BOSFCPUG
http://www.bosfcpug.org
Email: dberube@bosfcpug.org
Daniel Berube is offline   Reply With Quote
Old August 12th, 2002, 08:24 PM   #547
Mac OS X Resource sites
For those who wish to learn more about the power of OS X, add these following sites to your favorites list:
Apple's OS X page: http://www.apple.com/macosx/
Apple's OS X Support page: http://www.info.apple.com/usen/macosx/
Mac OS X Hints: http://www.macosxhints.com
Mac OS X Resource Center: macos.about.com/library/blmacosx.htm
This is a good start!
Happy Filmmaking,
Daniel Bérubé • BOSFCPUG
Old August 12th, 2002, 08:34 PM   #548
TRY THIS...
<<<-- Originally posted by Simon Davies : Hi there.
I was inside a room filled with fluorescents and although there was no noticeable effect through the PD150 viewfinder or screen, when I got the footage back home and watched on my PAL Tv there is a distinctive flicker.-->>>
Simon,
Many people strive to get the film look and it looks like you did it without even trying!:)
You might wanna give the Flicker Filter in FCP 3 a try, although I cannot guarantee the results without having seen your footage. In FCP 3, go to the EFFECTS menu, select VIDEO FILTERS, then select VIDEO, and then select FLICKER FILTER.
Give it a try and experiment with the values pertaining to the filter. Let us know how it works out!
Old August 12th, 2002, 10:34 PM   #549
Well that should keep me busy!
Thank you all so much!
Jason Bagby is offline   Reply With Quote
Old August 12th, 2002, 10:47 PM   #550
no problems with firewire
I went most economical way i could with 80gb laCie drive @ 7200rpm
(they have a 120GB 7200rpm now)
has worked all but one time in 6 months of heavy use.
the time it didn't i was encoding a iDVD project to the drive using files that were also on that drive because mac HD was nearly full, and it froze up,
i had to do the 5 second power-down and it crashed my imac real hard,
had to boot up w/out extensions in 9 and then boot again in osX and then mac wanted to check and repair the disk,
so now i've taken to trying to work from mac HD and transfer video files i wasn't using to the 1394.
my buddy has western digital firewire drives strung around his suite like christmas lights on Clark Griswald's house, so he must think they're okay.
also I don't know if i'd settle for 5400 rpm's- video files are so picky and if you have a segment with a couple of audio tracks the read arm has to jump from the video to the audio to the other audio track, and 7200 will surely eliminate some dropped frames, but i have no proof.
Old August 13th, 2002, 08:15 AM   #551
Warden
New G4 Desktops
Apple has released new desktops today! http://www.apple.com/ Also, all the iMacs are available, including the new 17" LCD model.
Jeff
Old August 13th, 2002, 08:22 AM   #552
Amazing - I don't know if I should laugh or cry. Less than a month ago I bought a new G4 Dual.
Jeff - Now you have ruined my day! J/K
Paul Sedillo
Image::Studio
Houston, Texas
Old August 13th, 2002, 08:57 AM   #553
Warden
Actually I think your in pretty good shape Paul. You won't need to upgrade for 2 years and maybe not even then. In 2 years Apple will on to G5s or even G6s (or the rumored Intel chips). My lowly G4 dual 450 is starting to show it's age after 2 years. I'm waiting to see how Jaguar runs on it. If it's not up to my expectations I'll be selling it and getting a new dual 1GHz or maybe the 1.25. I have a feeling the next upgrade to FCP (4?) will require more umph than the dual 450 can provide. I think multiple streams of RT Effects are just around the corner. I think your machine should handle it without a problem. I'm faced with a new machine now and then in a year or so when the new processors come out.
Jeff
Old August 13th, 2002, 10:31 AM   #554
Retired DV Info Net Almunus
It seems like an odd time for Apple to introduce new desktops, doesn't it? Almost like they planned to do this at the recent MacWorld but were held-up by some glitch in their supply/manufacturing chain.
Old August 13th, 2002, 10:42 AM   #555
Warden
I would say that's a good possability. Motorola has had its problems lately and IBM isn't ready with their new chips yet.
Jeff
