The gigantic "which camera should I buy" thread! - Page 22 at DVinfo.net
Open DV Discussion
Old March 21st, 2004, 03:47 PM   #316
Contributor
Go to www.bhphotovideo.com and you can find the specs.
You might also look to see if they still are selling the VX2000. The VX2100 is out, but several stores still have the VX2000 in stock, and it's the best deal on the market, in my opinion, for quality and price.
Old March 21st, 2004, 03:49 PM   #317
Outer Circle
If cost is a worry, look at the Panasonic MX500. The price should be down because it's going to be replaced with the GS400 in a few weeks. But if you can afford it, the TRV950 is a slightly better choice, if widescreen isn't one of your needs. An even better choice would be the PDX10, for widescreen and XLRs. Canon's GL2 in another good choice---I can't recall what the PAL version is called.
For a quick spec check of these cams, go here:
http://www.grandeye.com.hk/etx/900/index.html
Old March 21st, 2004, 04:06 PM   #318
Thanks guys...
How is the Panasonic 3CCD NVGS120B for 699 pounds? It has a low lux level as well... Is it a good cam? Has everything I need.
Is it better to have a large inch CCD or not? The Panasonic has 3 1/6 inch's and the Sony TRV950 has 1/4.7. Is this Panasonic a good choie?
You see, price is a big thing because I'm also aiming on getting a $1300 PC
to make up for my:
Celeron 1.7GHZ
256 Megs Ram
20 Gig HD
Windows 98
If I got a bigger HD, would this PC be sufficient for video editing?
I was aiming for a
P4 3.2GHZ
Gig Ram
500GB HHD
Geforce FX5950 Ultra for high end gaming and editing.
Aviv Hallale is offline   Reply With Quote
Old March 21st, 2004, 04:17 PM   #319
Outer Circle
I would get that Panasonic MX500, then. I can't answer your other questions. I suggest posting that on the PC editing forum.
Old March 21st, 2004, 04:21 PM   #320
Contributor
If I were you I would try to get along with S-VHS and rent if you need digital for the next few months, because *everything* is about to change with HDV.
Ignacio Rodríguez in the third world. @micronauta on Twitter. Main hardware: brain, eyes, hands.
Ignacio Rodriguez is offline   Reply With Quote
Old March 21st, 2004, 04:33 PM   #321
I need a PAL cam, and on the panasonic.co.uk page, there's no MX models, only the NVGS120B which is 3CCD and the info seems to be growing on me, seems as good as the TRV950 for much cheaper... Please refer to my second, edited post.
Old March 21st, 2004, 05:22 PM   #322
Outer Circle
It would be called the NV-MX500E
It's still being sold - last year's model. It's a 3-chip, with frame mode and a Leica lens. It also has good widescreen. Check here for info and further informative links:
http://www.dvfreak.com/pana_mx5.htm
Old March 21st, 2004, 05:50 PM   #323
I'm going to need something available in a shop so my brother can pick it up in a few days... Is the NVGS120B good or also, contrived consumer rubbish?
Old March 21st, 2004, 05:51 PM   #324
P4 3.2GHZ
Gig Ram
500GB HHD
You could get a pretty comparable Dell for very cheap when they have a hot deal going. I remember a while back you could get:
P3.0"C"
512MB RAM
hard drive
ATI 9800pro
cheap CRT monitor
for $900
You could probably get some sort of Dell which has something like:
Pentium 3.0C (800FSB, hyperthreading)
1024MB RAM - (if they don't have quadruple memory, ebay off the sticks and get a new pair from crucial.com or newegg.com)
ATI 9800pro (slightly better than the GeForces, especially for next generation games like HL2)
no monitor hopefully (makes it a better deal)
throw in your own hard drives (wait for hot deals) - Dells are limited to 2 internals though, so you'll have to go firewire or jury rig something for more. 250GB may be enough?
check hot deals sites like gotapex.com, xpbargains.com, etc. A barebones Dell can be cheaper than whatever DIY system you can build.
Camera
You might want to go for a camera with XLR inputs if you can afford it, like the Panasonic DVC80 or Sony PD100a (old model, newer one is PDX10). If you want good sound all the good equipment uses XLR connectors and getting good quality sound will take a few hundred extra. Those cameras will have good circuitry too (technically better, better S/N ratio and frequency response). But you may not need that if going for TV/video. Those cameras are a lot more expensive though!
Old March 21st, 2004, 05:55 PM   #325
Outer Circle
The NVGS120B? It's a newer version of the GS70. There's some first impressions by Allan about this cam on the MX Forum. The MX500 is way better, but then it will cost a tad more.
Old March 21st, 2004, 06:02 PM   #326
Yeah... Like 600 pounds more :)
I'm 16 years old, doing some freelance work to raise a budget for NeverDead Productions (www.never-dead.cjb.net) movies.
I don't need such a great camera, DV, mic-in, 3CCD should be good enough.
I'm eventually aiming for a VX2100. The TRV950 would also be nice, but that's too expensive and this panasonic is 3CCD so it should be decent?
Is there a difference in quality between different CCDs all do all 3CCD cams look the same quality wise? (and do all 1CCD Cams look the same?)
Old March 21st, 2004, 06:29 PM   #327
Aha... Sorry for the double post :P
the NVGS120 as the same as the PVGS120, not the GS70... The 120 is 699 pounds/dollars and the GS200 is 999 pounds/dollars, and the GS70 (I can only find it on the US website) is also 999 dollars, but I assusme it's 999 pounds as well...
Do any of you know of major differences between the GS70, 120 and 200? on the Panasonic Comparison, most of the differences between he 120 and 200
are No Vs N/A
never No for one and Yes for the other.
Old March 21st, 2004, 06:30 PM   #328
They all don't look the same. To my eyes anyways.
http://babelfish.altavista.com/babel....html&lp=ja_en
see a whole bunch of frame grabs from various cameras in the japanese market (they have different model numbers sometimes).
Old March 21st, 2004, 08:06 PM   #329
Outer Circle
The GS120 and GS200 look very similar and very similar to the older GS70. If you go to that "grandeye" link I provided, you will see pictures and specs of all of these 3 cams.
Old March 28th, 2004, 03:46 AM   #330
Which is the best single CCD camera under 750$ range?
It should have very good picture quality. Will not be shooting in very low lights. But mostly indoor during day time too. Will not be using tripod.
Devang Shah is offline   Reply
