Vegas Video discussions from 2005 (Q1Q2) - Page 32 at DVinfo.net
Old February 6th, 2005, 09:32 PM   #466
.wmv is a video file, whereas .wma is an audio file.
EDIT : and thus the problems of posting at the same time, are discovered! ;-D
Curtis Rhoads is offline
Old February 6th, 2005, 09:37 PM   #467
Images: 32
thanks for your reply anyway
Michael Wisniewski is offline
Old February 7th, 2005, 05:17 AM   #468
yes its identical as it uses the same codec.
Its the codec that gives it that quality..
the canopus codec IS a little softer, but it does offer a nicer rounded contour.. hard to describe, but colour accuracy is a lil more pronounced.
Canopus have a hardware device which connects through USB and encodes mpg1 and mpg2 in realtime. Saves alot of time and does a nice job
http://www.canopus-aust.com/AU/products/MPEGPRO_EMR/pm_MPEGPRO_EMR.asp
The main concept codec is also a very good one (standard with vegas) i also find that its alot faster than procoder. the results arent all that noticable until you get to the lower end of the bandwidth, which by that time Procoder beats it quite easily.
I wouldnt encode anyhin less than 4200CBR anyway..
Peter Jefferson is offline
Old February 7th, 2005, 05:34 AM   #469
im still curious as to why people use boris..
i mean i bought boris red for 3grand hre in aus as a standalone, and i cant see what it can do that Vegas and a myriad of other apps can do...
I mean Bluff Titler, is easier and faster to use as a titler.. as is titlemotin pro... Vegas does excellent keying as does Edius Pro3, Particle Illusion does awsome particle effects, Xara 3d, also does some really nice static titles, Spicemaster does some really awesome displacements and filters, After effects.. well its after effects, what more needs to be said?
Combined, theyre alot easier to use, faster to render, and its a hellofalot cheaper..
one reason i didnt like Boris was the interface.. i couldnt flow with it for some reason.. could be me.. but for everything i do, Boris was just a waste of money.. :( Lucky that i found a buyer for it, but Im still to see something boris can do that any of the mentioned apps ive listed cant.. could be me.. i might be blind..
Old February 7th, 2005, 05:44 AM   #470
Hi Peter.
Yeah the interface is a bit clunky but so far just by doing the tutorials I found the program to surpass Vegas when it comes to create dazzling titles.
Mind you I had it cheap.... well free. One of my buddy switched career and was doing computer designs and happen to have a copy. He just gave it to me so my expectations weren't as high as yours.
Reading threads and reviews I quickly realise that there are a lot of programs out there who do exactly the same things ,you just pick one blindly and chances are you will end up being able to accomplish the same things with the same results. It boils down to personnal choices and preferences I guess.
Phil
Still lost in Vice city
My website: www.production24fps.com/english.php
Philippe Gosselin is offline
Old February 7th, 2005, 05:48 AM   #471
thanks for the replies.
my first attempt was to create an mpeg. i managed to get it down to the desired size, but then my client replied emailing me a wmv file of about the same duration (2:40 minutes). he was saying that he doesn't understand why the wmv file he sent me, being about the same length and size, looks and sounds better. i took a look and told him that he's absolutely right and that i'll make him a new and better compressed file.
so is wmv the way to go? and Tony, if i understand what you're saying, i shouldn't be creating the compressed file in vegas. right? i just take the .avi PAL DV file (575MB) made in vegas and then use other software (procoder, quicktime?) to bring it down to 7-8 MB?
(i might need a little help later with the settings and parameters)
adi
Adi Head is offline
Old February 7th, 2005, 08:11 AM   #472
It's not necessarily the case that you can't get equally good results in Vegas. I was in a hurry and just found that the default settings in Vegas didn't produce as good a result as those in Procoder so I used the Procoder settings as my base to juggle its parameters until I got what I wanted.
Given a bit more time it's entirely possible that similar results could be produced in the Vegas .wmv implementation. You might try that first since it would save you an extra rendering step or a frameserving step and the purchase of additional software.
Tony
Tony Rockliff is offline
Old February 7th, 2005, 10:20 AM   #473
Skyonic New York
there are a lot of major (to me) diff between the two...
the major difference is pce (procoder express) does not have master quality encoding option, which to me is the only reason to use procoder
pce also has no way of saving settings for future encodes, like changing frame rates, combining avi and mpeg encodes n so forth
pro coder also has a lot of little things that add to its value, best place to get a clear concise list is call canopus or visit their forum...
Robert Mann Z. is offline
Old February 7th, 2005, 03:55 PM   #474
Is Vegas the best way to go Tape 2 tape?
So i'm going to make a tape dub and wanted to know if Vegas is the best way to do that ? I have 2 Dv cameras and wondered if that was the easiest?
If i use 2 Dv's, what are the steps neccesary to make it record?
Thanks for the input
Tim Kay is offline
Old February 7th, 2005, 04:30 PM   #475
>Connect the cams via firewire.
>Put both into VTR mode.
>Press play on the source.
>Press record on the other.
Gary
Gary Kleiner is offline
Old February 7th, 2005, 04:33 PM   #476
Sponsor: JET DV
As Gary said, bypass the computer altogether. You don't NEED to go through the computer when the cameras can talk to each other just fine.
Edward Troxel is offline
Old February 7th, 2005, 04:37 PM   #477
thanks;
its nice when technology is easy and simple to use.
Hopefully DVD architect will be there soon!
Tim Kay is offline
Old February 7th, 2005, 04:40 PM   #478
>Hopefully DVD architect will be there soon!<
Be where?
Gary
Old February 7th, 2005, 05:07 PM   #479
Vol 2 Issue 9 (Oct 04) for anyone else that's interested.
Thanks Edward. It's not exactly what I'm after but I can think of a few other uses for that technique.
Actually, what I'm doing is more like using "digital puppets" for a kind of hybrid stop motion/cut out animation. Each character is sliced up (in Photoshop) into limbs, torso, head etc then the various parts are moved around and keyframed in Vegas to give the appearance of fluid motion.
As I mentioned before, I know there are more appropriate packages for animation (After Effects, even Flash is now widely used) but Vegas is all I got! I'm having some good success with my trials but at the moment the majority of the pre-production effort is going into the artwork.
Thanks again for your great newsletters.
Ian Stark is offline
Old February 7th, 2005, 06:39 PM   #480
adi, microsoft offers free downloads of their wmv encoder, if you want to take a look at some other alternatives... i think that they should all be pretty similar, tho, if you use the same encoder settings... one thing to look for is two-pass encoding, it makes a big difference, also use vbr to save a bit on the file size.
Dan Euritt is offline
