Vegas Video discussions from 2005 (Q1Q2) - Page 71 at DVinfo.net
Old March 27th, 2005, 11:28 PM   #1051
How to Increase bass only (Audio)
Hello,
In Vegas5, is there a way to increase the bass only for audio music?
Thank you in advance.
Kevin Kwak is offline
Old March 27th, 2005, 11:33 PM   #1052
Serious help needed!
Hey guys... I am on a deadline with this weekly tv show I am producing.. Our first show is coming up on air... SOON!
And I am having stupid -shit-ass-trouble!
I am using connectHD to capture to m2t
then converting to the .avi form to work with
its alot faster and more responsive that way... (in the big file .avi)
I am editing using Vegas5.d
The video and audio are becoming out of sync...
Can anyone give me any ideas on how to fix this???
Time is of an essence!
thanks for taking YOUR time to help me.
Shooting in HDV with Sony Hdr-FX1
Editing on Dell Poweredge 400sc with 2 gigs ram
2 terrabytes of storage
Brent Marks is offline
Old March 28th, 2005, 12:02 AM   #1053
Use the track EQ.
In the left hand column, click on the track effects button (it's green and looks like a rectangle in a chain.)
You should see track EQ in the top of the menu that comes up.
Click on the 1 and drag it up a little until it reads 3dB or so.
2- Make sure you are monitoring on something accurate. On poor equipment that cannot reproduce the low-end well you may be tempted to boost the bass too much. It may also have exaggerated bass and treble. In the deepest frequencies your speakers may be very quiet (possibly with distortion or lack of detail), the frequencies above them will be exaggerated (too loud), then you have the mids, and you should be able to figure out the rest.
Glenn Chan is offline
Old March 28th, 2005, 12:20 PM   #1054
REPLY
I just have the basic Quicktime that came with the computer. Do you have to have Quicktime's authoring features to be able to save a Quicktime file from Vegas 5 to your hard drive?
G. Lee Gordon is offline
Old March 28th, 2005, 12:58 PM   #1055
Sponsor: JET DV
Vegas requires the authoring components to properly use QT, Tiff, and some other formats. Just install QT again and install everything listed under "custom".
Edward Troxel is offline
Old March 28th, 2005, 01:31 PM   #1056
Integrating M-Audio firewire 410
I know someone having problems integrating the M-Audio 410 into Vegas. They can't seem to get each track assigned correctly for surround sound editing. Has anyone here had experience setting it up and using it?
Thanks in advance
btw, I'm assuming ASIO would be the preferred interface?
Joe Carney is offline
Old March 28th, 2005, 03:49 PM   #1057
Multi-phase editing workflow
I just want to check my thought process. I am already working on this project, but if anyone can point out easier/better, I will appreciate it (for now or next time).
I have some interview footage with 2-3 camera clips and 1 long audio clip from my iRiver/AT897. About 30 different interviews and 25 minutes of total footage. I was interviewing guests at the dinner table during a party. Before I start editing, I need to merge the two.
1. Add audio and video to timeline, sync up the two audio tracks, mute the camera audio, and render as an AVI (uncompressed default) file to lock audio to video.
2. Use that file as input for next stage, where I need to apply FX (mostly brightness and contrast), a bit of framing (I didn't test wide angle with MKE300 mic attached), and then chop it up into short clips. I will create subclips out of this.
3. Assemble the subclips.
Wonder if anyone would do it differently or use different settings for intermediate AVI file ??
Most all of the cubclips will need the same brightness adjustment. Would you do that before the intermediate render or will I lose info by doing it too early?
Bob Costa is offline
Old March 28th, 2005, 04:21 PM   #1058
Sponsor: JET DV
Adding and syncing fine. Rendering is really not necessary but you can do that. However, if you DO render, there's no need to render as uncompressed. Since you're starting with DV, render to DV (i.e. NTSC DV or PAL DV)
This is fine. You'll be slightly better off applying the FX AFTER the first render (which really copies since you're not changing anything). While the intermediate render is not strictly necessary, I can see how it can help you with the organization of your project.
Old March 28th, 2005, 06:56 PM   #1059
Thanks ed. The problem I think I have is that after combining the iRiver audio, I will be chopping up and shuffling the interviews quite a bit. It seemed like this was the only way to do it. Trying to manage grouping of an alternate audio track looks hard. Or is there a way to lock teh audio so that trimming cutting keeps everything in sync?
And thanks for the heads up about rendering DV format.
Old March 28th, 2005, 07:59 PM   #1060
This might work better:
Throw all three cams and the iriver audio onto timeline. Sync them up. (Slating at the shoot helps.)
Right click the audio (in timeline), select "create subclip".
Right click the audio, select show in media pool.
Right click the audio clip IN THE MEDIA POOL, DRAG and hover over the VIDEO clip. Select audio --> add as takes.
The audio should now be 'embedded' in the video clip with synced audio.
Rinse and repeat for the other two cameras.
2- Right click the video track and select "Media FX". You can apply exposure correction this way, and it will affect all clips based off that media.
3- If the MKE330/wide angle is an issue, you can drop cookie cutter onto Media FX too. Or if you want to render it out, include the color correction. When bringing the footage back in, add it as a take to existing video.
Old March 28th, 2005, 11:44 PM   #1061
REPLY
I downloded QT again. Does it have to be QT PRO or are the authoring features available on the regular free version of QT?
Old March 29th, 2005, 08:19 AM   #1062
Sponsor: JET DV
You do NOT need QT Pro. Just install the STANDARD QT, choose "Custom" as the install type, and pick everything.
Old March 29th, 2005, 10:11 AM   #1063
THANKS!
Hey, I purchased Quicktime Pro & problem solved. Thanks for all the help.
Old March 29th, 2005, 01:14 PM   #1064
Color Correction
I had a plug-in for auto color correction, I believe it was Mike Crash or something like that, but I just had to format my computer and lost it. Can anyone direct me to the link to get that particular plug-in or something similar to it? Thanks again.
MITCH
Mitch Buss is offline
Old March 29th, 2005, 01:28 PM   #1065
Sponsor: JET DV
The Mike Crash tools can be found here: http://mikecrash.wz.cz/
There's also the 6cc (six vector color corrector) tool here: http://www.moosehill.se/vegas/
I'm not sure which one you're referring to.
