Vegas Video discussions from 2003 - Page 98 at DVinfo.net
Old November 7th, 2003, 06:17 PM   #1456
Hello,
i have been using the single track method, (becuase I did not know you could do and A/B type in Vegas) and getting kind of used to it..I find it hard in a situation where you want to place a piece of footage in a gap, and you are not sure it will fit..But now that I can switch to and A/B mode(even temorarily) it helps in this situation.
Thanks again
Mike
Mike Moncrief mikemoncrief@gmail.com
www.themikemoncrief.com
Mike Moncrief is offline
Old November 7th, 2003, 07:53 PM   #1457
Yes, I did do a clean install. I formatted the main 13GB drive, then installed the OS.
I will check device manager for DMA tonight after work.
Could there be a driver issue with my video HDD?
Matt McConnell is offline
Old November 8th, 2003, 07:29 AM   #1458
Old Boot
Newly Created V4 Project Won't Open?
Project created 5 hours ago. Saved and closed. Shut down pc.
Go to reopen project:"An Error occurred while loading the project file myfile.veg. The file could not be created. Another file with that name exsists" - what on Earth does this mean then!?! I tried changing the name of the V4 Project file and even put it in another direcotry AND I put the media into a differnt directoy . . . .
I spent 3 hours making Bins and shuffling about clips . . nothing new here . . what's happening? More to the point how do I get my Project back . . this is very scary.
Please help!
Grazie
Graham Bernard is offline
Old November 8th, 2003, 10:26 AM   #1459
Did you try opening it by double clicking directly on the VEG file?
Glen Elliott is offline
Old November 8th, 2003, 12:19 PM   #1460
Old Boot
Yes . . .
1 - Double clicked - No
2 - Copied VEG - No
3 - Moved to other Diretory - No
4 - Renamed VEGGIE - No
Grazie
Old November 8th, 2003, 08:15 PM   #1461
Sponsor: JET DV
The A/B mode is there for when you need it or if you need the view to feel more comfortable. However, it takes a ton more space on the screen. I recommend leaving it OFF unless absolutely needed for special circumstances. You'll get used to the single track and then wonder why you ever needed the A/B view.
Edward Troxel is offline
Old November 8th, 2003, 08:20 PM   #1462
Hey, I loved the whole preview concept -- the credits, the video, everything. Well done, comes off very professional.
How did you create the music? Is that you, Acid, purchased, or, um, borrowed?
DVX100A/AT4071a/Vegas/After Effects
Dual 2GHz Xeon PC
Stuart Kupinsky is offline
Old November 9th, 2003, 12:23 AM   #1463
Old Boot
Excellent!!
Mark - TOOOOooo Good!! Excellent, really. Pace, drama, humour and suspense. The music was spot on and the images where, well . . spectacular. Now I can see where the advice I gave came into to play . . . How about a Credit to the "Tewchnical Advisors" - only joking ;-)
Great Stuff! - Grazie
Old November 9th, 2003, 09:57 AM   #1464
Hmm sounds like you pretty much tried it all. Sounds like your VEG file got corrupted somehow. Unless the resident guru (Edward) has any advice you might be at a loss.
The only other thing I can think of is check to see if you have "automatically backup project files" selected. If so you'll find a myfile.bak, rename it to myfile.veg and you should be good to go.
Old November 9th, 2003, 10:11 AM   #1465
Mark you mind if I pick your brain with a few hundred questions. Mostly regarding DVX and wedding videography.
Old November 9th, 2003, 11:51 AM   #1466
The same thing happened to me the other day. Somehow I was allowed to save two different projects under the same name. I don't remember what it was that I did, I may have even started over.
Try going back and finding all of the duplicate file names, rename the older ones (the ones you don't want) see if it will only then find the one you want, and not be confused.
"DOH"!!!
Harry Settle is offline
Old November 9th, 2003, 12:34 PM   #1467
Old Boot
Glen - Nope.
Found the BAK, renamed it as "D3.veg" - no quotes - same Error message . . . blast!
Grazie
Old November 9th, 2003, 07:38 PM   #1468
would it accidently be in two different files, in two different places? Mine save as veg files in one place, but, I "save as" in my prerendered file.
I also just re-read your last post. Look for dup veg files, not bak file.
"DOH"!!!
Old November 9th, 2003, 09:25 PM   #1469
Glitch or Intentional?
Why is it that once you use the media generator to create a title/text (and it defaults to 10 seconds in duration), and then on the track you change the duration of the event, and subsequently edit the title in the media generator window, the window displays the duration as the original default value, not the new duration (even though everything reders properly at the new duration, etc.)?
I have that "Edward will point out why it's right" feeling, but can't figure it out.
Dual 2GHz Xeon PC
Old November 10th, 2003, 05:05 AM   #1470
Old Boot
Harry - Done this - Nope, no Dupes! I even created a duplicate WITH the same name to try and "fox-it". The New same-name openned fine. But not the original . . . .
. . . . anything else?
Grazie
