Odyssey7 & Odyssey7Q Firmware 2.11.110 Released
convdeslogo-dvi2Today Convergent Design releases a firmware update for the Odyssey7 and Odyssey7Q. This release adds features, improves current functions and fixes some previous issues. Highlights of the new firmware include:
  • Higher Frame Rates For Apple ProRes 422(HQ) In 1080p
    Apple ProRes 422(HQ) recording is now enabled in 1080p50 and 1080p59.94.
  • Integrated Deck Control And Scrubbing in Play Mode
    Scrubbing through clips is now available both while the file is playing as well as when it is paused.
  • Selectable Pixel Zoom Drag Orientation
    When using the finger drag function to select the section of the image visible in Pixel Zoom function, the drag orientation can be set to follow the finger move (drag the image) or oppose the finger move (drag the window).
New Features — Recording Options (Odyssey7Q Only)
  • New POV RAW Record Option Available For Purchase or Rent
    The POV RAW Record Option is for various special function cameras with RAW output. The RAW data is captured as Cinema DNG files. The POV RAW Record Option is $1495 to purchase or $99/day to rent through the Convergent Design website.
The cameras currently supported include the IO Industries Flare 2KSDI and the Indiecam indieGS2K. Supported RAW formats for these cameras are as follows:
IO Industries Flare 2KSDI 2048×1080 23.98 – 60p 10-bit RAW
IO Industries Flare 2KSDI 1920×1080 23.98 – 60p 10-bit RAW
Indiecam indieGS2K 2048×1080 23.98 – 60p 10-bit RAW
Indiecam indieGS2K 1920×1080 23.98 – 120p 10-bit RAW
Indiecam indieGS2K 1920×1080 23.98 – 60p 12-bit RAW
image002Canon C500 High Speed RAW Support — Canon Cinema RAW “4K Half RAW” mode 4096×1080 is supported at 50p/60p and 100p/120p. The Odyssey7Q currently supports the original full frame height version of the Canon 4K half RAW, not the “4Kx1K” cropped mode. Only the highest frame rates in the Slow & Fast modes are currently supported.
Sony FS700 4K2HD Recording Up To 60p — FS700 4K RAW to HD Apple ProRes 422(HQ) is now available up to 60p (59.94). 50p is also available.
Fixes and Improvements
  • FIXED Time of Day timecode issue
  • FIXED Backward file compatibility during firmware updates
  • FIXED “Ticking” audio after 720p file recovery
  • FIXED Black dots in live image when overexposing or white-clipping
  • FIXED False-triggering when Odyssey set to camera trigger
  • FIXED Timecode triggering in 720p
  • FIXED False “Warranty Void” notice on some units from previous firmware
  • FIXED 1080psf audio sync issue in Playback
  • FIXED Pixel Zoom mode distorting of image on OLED
  • IMPROVED Touchscreen response
  • IMPROVED Touchscreen recalibrates by engaging F1 Lock button
Go to www.convergent-design.com/firmware-downloads.html to download the latest firmware, update instructions, firmware release notes, quick-start guides, and the latest Odyssey7 and Odyssey7Q manuals.
An Odyssey SSD or Odyssey Utility Drive is required to perform the update.
Share.
About The Author
DVi News
