Sony Unveils New Professional 4K Camcorder
New PXW-Z100 4K Handheld XDCAM Camcorder Uses XAVC Workflow to Give
Professionals More Production Flexibility and Creative Options
PARK RIDGE, N.J., Sept. 4, 2013 -– Sony is expanding its line of professional 4K technologies with the new PXW-Z100 4K handheld XDCAM camcorder. The new model broadens professional 4K capabilities to markets and applications beyond motion picture or high-end TV production – including houses of worship, education, corporate, and live events. The camcorder’s affordable price of less than $6,500 gives professionals even greater flexibility and more creative options for acquisition and production in HD, QFHD and 4K (4096×2160).
With a 1/2.3-inch Exmor® R CMOS sensor, the camcorder can create stunning 4K content (4096×2160) at 50p or 60p. The PXW-Z100 camcorder is based on the same shooting ergonomics as a conventional handheld professional camcorder, allowing users to record 4K content cost effectively.
“This new camcorder brings high-performance 4K capabilities to the entry-level of our 4K line,” said Takahiro Kagawa, Product Manager at Sony Electronics. “It’s perfect as a standalone content creation tool or as a complement to our large sensor, higher-end 4K cameras. Corporate and event producers can now deliver 4K images for a growing number of applications including large venue 4K projection and 4K monitors. Professionals now have access to the widest palette of 4K tools to tell their stories more effectively and creatively.”
The PXW-Z100 camcorder, together with the fixed 4K-compatible high-performance G Lens, weighs less than 7lbs. The PXW-Z100 uses Sony’s XAVC™* recording format first employed in Sony’s PMW-F55 CineAlta® 4K camera. MPEG-4 AVC/H.264 compression is used for HD (1920×1080), QFHD (3840×2016) and 4K (4096×2160) content. Image sampling is 4:2:2 10-bit, with an intra-frame system that compresses each frame individually at a maximum bit rate of 500 Mbps or 600 Mbps during 4K 50fps or 60fps recording, respectively, and 223 Mbps during HD 50fps or 60fps recording. The XAVC format is ideal for those looking to implement a high-quality, secure and worry-free workflow.
Users can select QFHD (3840×2160) and HD (1920×1080) resolutions, both of which are compatible with most 4K TV’s.
The camcorder provides extremely high sensitivity due to its back-illuminated Exmor® R CMOS sensor — even during 4K shooting. With more than 8.8 million effective pixels, the 1/2.3-inch sensor captures 4K images at 50p or 60p. The built-in high-performance G Lens offers maximum shooting flexibility, including a wide angle of 30 mm in 4096×2160 mode or 31.5mm in 3840×2160 and 1920×1080 modes and 20x powerful optical zoom (equivalent to 35mm).
The new camcorder uses state-of-the-art XQD solid-state memory cards, a format recently defined by several industry leading companies. XQD uses the ultra-fast PCI Express interface and Sony’s unique camera processor to enable stable video recording at 500Mbps or 600Mbps**. The PXW-Z100 camcorder features two XQD Memory card slots. Multiple cards can be used in various ways, such as for relay recording. When the first card becomes full, recording continues on the second card without a break.
The HDMI® interface on the PXW-Z100 camcorder can output 4K as a 50fps/60fps signal. When the PXW-Z100 is connected to a Sony PVM-X300 4K professional monitor or a 4K-compatible BRAVIA® TV, the recorded 4K image can be displayed in 4K 50fps/60fps quality. A future firmware upgrade is planned to provide compatibility with the new HDMI standard (referred to as HDMI 2.0) and enable 4K 50fps/60fps output to a wider range of devices. Other features include a 3G HD-SDI interface that supports output to an SDI of up to HD 60p. It also supports HD output during 4K recording***.
The camcorder’s paint function enables multiple image parameters to be adjusted including gamma curve, black level, skin tone detail and color. Together with other setting options, parameter settings can be recorded as a camera profile onto a memory card. The recorded camera profile can then be used to set the same parameters in another PXW-Z100 camcorder to match quality and image tones when using a multi-camera setup.
Users can remotely control focus, zoom, aperture settings and “record start/stop” using the browser function of a smartphone or tablet. Users just need to simply plug the supplied WiFi adaptor into the camcorder to enable the wireless feature.
The PXW-Z100 4K camcorder is planned to be available by the end of 2013 at a suggested price less than $6,500. For more information, visit www.sony.com/professional.
Notes:
* A firmware update is planned for the middle of 2014 to support the Long GOP mode for extended 4K recording time and to add support for AVCHD recording, a format that until now has been compatible with the playback environment of Blu-ray Discs.
** The use of new S Series XQD cards QD-S32E and QD-S64E which supports 180MB/s transfer speed are recommended.
***The PXW-Z100 is not capable of simultaneous 4K (HDMI) and HD (3G HD-SDI) output.
Sony Launches Professional PXW-Z100 4K XDCAM Camcorder (UK / Europe Press Release)
Camcorder uses Sony’s XAVC recording format and XQD media cards
Basingstoke, UK, Sept. 4, 2013 — Sony today announced the PXW-Z100, a professional 4K handheld XDCAM camcorder featuring a 1/2.33″ Exmor R CMOS sensor. The sensor has total of 16 million pixels and is able to acquire stunning 4K content (4096×2160) at 50p or 60p. The camcorder marks Sony’s latest step in expanding the 4K world to everyone, from high-end cinema to corporate and event productions.
The PXW-Z100, together with the fixed 4K-compatible high-performance G Lens, weighs less than 3kg. It uses the XAVC recording format first used in the PMW-F55 CineAlta camera. As with the F55, 4K (4096 x 2160, 50p or 60p, 4:2:2, Intra-frame, 10-bit recording in MXF file format) is possible at a high-bit rate of 500Mbps or 600Mbps. QFHD (3840×2160) and HD (1920×1080) resolutions can also be selected, both of which are compatible with most 4K TV’s.
Since the PXW-Z100 is based on the same shooting ergonomics as a conventional handheld professional camcorder, it is possible to record 4K content without extra equipment. In addition, during editing, downscaling from 4K to HD provides new possibilities for HD content production. “This incredible new camcorder is capable of capturing stunning 4K content, making 4K acquisition accessible to a wider range of professional users than ever before,” said Bill Drummond, Strategic Marketing Manager Entry Level Production. “Corporate and Event camera operators can deliver 4K today for distribution via an emerging number of 4K platforms including online, digital signage and large venue projection applications, and will be able take advantage of the greater flexibility in post-production that 4K acquisition offers when delivering in HD”. The PXW-Z100 will be available from November and comes packaged with a two year PrimeSupport contract via authorised Sony Professional Solutions Specialist dealers.
Sony has also announced the new FDR-AX1 Handycam at IFA 2013. The FDR-AX1 has a similar specification to the PXW-Z100 but is only capable of QFHD (3840 x 2160) recording with the XAVC S format. The FDR-AX1 uses 4:2:0, Long GOP and MP4 file format.
Key features
  1. 4K (4096×2160) 50p or 60p shooting
    The camcorder provides extremely high sensitivity due to the back-illuminated Exmor R CMOS sensor. With 8 million effective pixels, the 1/2.33″ sensor captures 4K images at 50p or 60p. The inbuilt high-performance G Lens offers maximum shooting flexibility, including a wide angle of 29.5mm (equivalent to 35mm) and 20x powerful optical zoom.
  2. XAVC recording format at 4K 50p/60p, 4:2:2 10-bit at 500/600Mbps, HD at up to 223Mbps
    The PXW-Z100 uses Sony’s XAVC recording format first employed in the PMW-F55 CineAlta 4K camera. MPEG-4 AVC/H.264 compression is used for HD (1920×1080), QFHD (3840×2016) and 4K (4096×2160) content. Image sampling is 4:2:2 10-bit, with an intra-frame system that compresses each frame individually at a maximum bit rate of 500Mbps or 600Mbps during 4K 50p or 60p recording respectively and 223Mbps during HD 50p or 60p recording. The XAVC format is ideal for those looking to implement a high-quality, secure and worry-free workflow.
    A non-chargeable firmware update is planned for the middle of 2014 to support the Long GOP mode for extended 4K recording time and to add support for AVCHD recording.
  3. XQD Memory Card recording
    The XQD Memory Card is a new standard of solid state memory, which was recently defined by several industry leading companies. XQD uses the ultra-fast PCI Express interface and Sony’s unique camera processor to enable stable video recording at 500Mbps or 600Mbps. The PXW-Z100 features two XQD Memory Card slots. Multiple cards can be used in various ways, such as for relay recording. When the first card becomes full, recording continues on the second card without a break.
    * The use of new S Series XQD cards (QD-S32E or QD-S64E which supports 180MB/s transfer speed) is recommended.
  4. HDMI interface for 4K output and 3G HD-SDI interface for HD output
    The HDMI interface on the PXW-Z100 can output 4K as a 50p/60p signal. When the PXW-Z100 is connected to a Sony 4K-compatible BRAVIA TV, the recorded 4K image can be displayed in 4K 50p/60p quality. A future firmware upgrade is planned to provide compatibility with the new HDMI 2.0 standard and enable 4K 50p/60p output to a wider range of devices. Other features include a 3G HD-SDI interface that supports output up to HD 60p. It also supports HD output during 4K recording.
  5. Paint function for more creative freedom
    The PXW-Z100’s paint function enables multiple image parameters to be adjusted including gamma curve, black level, skin detail and colour. The range of settings is similar to those available in the PMW-F55. Together with other setting options, parameter settings can be recorded as a camera profile onto a memory card. The recorded camera profile can then be used to set the same parameters in another PXW-Z100 to enable the matching of quality and image tones when using a multi-camera setup.
  6. Remote control with WiFi
    Focus, zoom, aperture settings and ‘record start/stop’ can be remote controlled using the browser function of a smartphone or tablet.
Sony Professional PXW-Z100 4K XDCAM Camcorder Product Images
Share.
About The Author
DVi News
