Adobe Premiere discussions from 2002 - Page 12 at DVinfo.net
Adobe Creative Suite
Old July 30th, 2002, 08:23 AM   #166
Jim Steffel is offline
Old July 30th, 2002, 08:28 PM   #167
nbpjaroch7
Posts: n/a
re: Help! Sound probs with Microsoft DV and Premiere 6
I'm using a standard (generic) 1394 Card, using the latest Microsoft DV codec in Premiere 6 on the "DV Playback" setting, and I'm getting what sounds to be bad compression artifacting in my audio.
The settings are the DV 4800khz, 16bit stereo setting, standard 720x480. Playback from my 1394 card to a Panasonic AG DV1000 Mini-DV Deck works great except for the audio. Playback from the 1394 card to my Canon XL1-S yeilds the same results.
I have the identical setup in two other editing systems...they all produce the same artifacting audio.
When I choose a setting for non-DV NTSC or other non-DV Video For Windows options, the audio is perfect. Any ideas?
I think it is either Premiere's processing of DV, or Microsoft's DV codec....thanks for your input! - Justin
p.s. I have tried Premiere 6.0, 6.1 and 6.2 Beta
Old August 1st, 2002, 12:25 AM   #168
nbpjaroch7
Posts: n/a
Found the answer...kicking myself for how obvious. The sound files I was using were 44.1 Khz 16 bit (standard CD quality). My project file was 48khz...the compression sound was the poor sampling that Premiere was applying to bring the CD quality to Dat quality. ^_^ A quick resample in SoundForge brought the music to 48khz and everything was smooth from there on.
Thanks for your help! - Justin
Old August 7th, 2002, 11:36 AM   #169
Adobe Premiere 6.5
Anyone have any input on the changes made? I am sure with this crowd someone has already been testing it.
Best,
Big James
James Rulison is offline
Old August 8th, 2002, 08:11 AM   #170
A friend of mine was testing it and I spent a few minutes looking at it. The interface looks exactly the same. The realtime preview seems to be one of the initial settings that you choose when setting up your project. The Mpeg2 Encoder uses Main Concept's codec and comes with tons of different presets for DVD, SVCD, and VCD.
It has both CBR and VBR, but the documentation doesn't say anything about how many passes the VBR does and I didn't have a chance to test it out.
The realtime preview worked pretty well. But then I didn't anything other than 3 AVI clips with a simple cross dissolve and a additive dissolve.
Ted Jan is offline
Old August 8th, 2002, 03:13 PM   #171
I found deep on their page that they will support Windows XP, but the hardware supported page doesn't seem to be updated from version 6.0
Any idea if they are going to support the XL1s or the GL2?
Best,
Big James
Old August 9th, 2002, 02:04 PM   #172
sorry...don't have any idea...the documentation was still 6.0 only the mpeg encoder had current documentation.
Ted Jan is offline
Old August 12th, 2002, 11:58 AM   #173
I found out a friend of mine who is mainly a Apple guy has been beta testing Adobe 6.5. He was explaining that some of the features are not fully implemented that I should wait until the products full release before making any decisions.
Just wanted to point that out just incase some of you get your hands on a beta.
Best,
Big James
Old August 18th, 2002, 08:44 PM   #174
Parkingtigers
Posts: n/a
Why can't I capture frame mode with premiere?
Hi there.
So my XL1-s finally arrived, I took some test shots and tried to capture it with premiere 6.0
The normal mode was picked up and saved normally. All fine and groovy, but when I tried to capture the footage that was filmed in frame mode (the main reason I bought the camera) I started having problems. In the preview window, it shows the footage start, and the frame capture begins. It reaches a limit of 48 frames captured and then the picture freezes while the sound continues. Playback of these clips looks more like 2 frames have been captured than 48.
I'm sure there is a really obvious solution to this, but as an absolute newcomer to this I can't see what it might be.
Your help would be greatly apprechiated.
For the record I'm running:
Pal XL1-s.
Windows XP.
P4 1.7mhz.
512 meg ram.
80 gig hard drive.
Premiere 6.0
Cheap and cheerful firewire card.
All of this was fine for capturing normal mode, it's the frame mode that just won't work.
Adrian
Edited to add:
After reading about half the posts on here, I think that the fact that I changed the audio settings too may have affected it. The normal footage was in 12 bit, and captured fine, and the frame mode was 16 bit audio. Thing is, I'm trying to capture from the start of the frame section, so you'd think it wouldn't matter.
Frustrating.
Old August 19th, 2002, 12:26 AM   #175
Adobe Premiere 6.5 or Pinnacle Pro-ONE?
I have a Canon XLS-1 camera.
Which editing program is better between these two:
--Adobe Premiere 6.5
OR
-- Pinnacle Pro-ONE
I would appreciate to know the pros and cons of each one and which one would be the overall best choice.
Some of my questions are : Can you turn your footage into black and white, need to know if either one has the option of scrolling titles for credits at the end of a movie, can either one give your footage slow-motion effect, etc.
Thank you all for your time.
Todd Dilley is offline
Old August 19th, 2002, 02:05 AM   #176
If i'm correct the Pro One hardware comes bundled w/Premiere.
Jason Wood is offline
Old August 19th, 2002, 09:27 AM   #177
RED Code Chef
I should have it shortly and am going to take a look at it.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old August 19th, 2002, 10:15 AM   #178
RED Code Chef
I have the following:
PAL XL1-S
Windows 2000 Professional SP3
P3 900 MHz
256 mb ram
Premiere 6.0
Capture works fine with both frame mode and
interlaced. What preset are you choosing when
Premiere starts?
Old August 19th, 2002, 03:46 PM   #179
Parkingtigers
Posts: n/a
I've been using DV pal, standard, 48 khz. I also tried some custom variations too, but still it only wants interlaced footage.
Adrian
Old August 19th, 2002, 05:13 PM   #180
Yes, the Pinnacle Pro-ONE system includes Premiere 6.0. (I'm not sure if Pinnacle plans to offer Version 6.5 with the Pro-ONE anytime soon.)
Premiere and the Pro-ONE can definitely do all the things you mentioned. It's a great combination of hardware and software for the money. I've been using it for about six months.
The best advice I can give you, if you have not yet purchased it: Make sure that you start with a computer system which is specifically supported by the Pro-ONE. It is very sensitive to compatibility issues. I ended up building a system from scratch, literally around the Pro-ONE board, and it works like a dream. But you will go through hell if you try to install it on an incompatible or untested system. Take it from me. ;-)
Buck Wyndham
Skyward Media
www.SkywardMedia.com
Buck Wyndham is offline
