#46 | |
also known as Ryan Wray
Re: The fader on my field recorder does not have numbers, does anyone know?
Oh okay, well even though I could use a library of gunshots, I still thought I should go out and record my own just for more options. As for mic choice I was thinking of using a shot gun mic. I thought about standing about a couple of feet away with the mic, pointed at the chamber area of the rifles.
A lot of online gunshots, they sound like they were recorded from too far away. I could turn them up of course, but then I am closer to the noise floor. But I can also keep looking for better ones. Quote:
I looked up the term modulation, and got some different definitions, but is this the one you mean? |
#47 |
In this context over modulation means when exceeding 0db the sound becomes distorted and clipped. This is why you always leave head room. Since gun shots are out of the norm and have a sudden burst of extreme loud sound, you will have to record a test to see how much head room you'll need.
#48 |
In this case and in the way people commonly use the term over modulation regarding audio, it's when you get clipping. This usually at 0dB on the scale of a peak audio meter, when you get distortion.
I don't think you'll have an issue with the noise floor if you're closer than 12 ft to a rifle, possibly even further than that, I gather that a small 22-caliber rifle can produce around 140 dB, while big-bore rifles and pistols can produce sound over 175 dB. I would be careful about getting too close at sound levels like that because you'll get distortion. |
#49 |
Oh okay thanks. Yes, I know what clipping is, that helps, explain it, thanks.
So when you say do not get too close because it will cause distortion, by distortion, do you mean clipping distortion, or a different kind of distortion? |
#50 |
The distortion that Brian is referring to results when getting too close to a loud sound source. The microphone itself has a limitation how much sound pressure it can handle before distorting. It would be similar to putting a condenser mic up to your mouth and shouting into it. Even if the mixer doesn't exceed 0db it will still sound distorted.
#51 |
Oh yes, I see what you mean. I can do tests then. When it comes to the F8 field recorder, or any other field recorder, are there any features that can tell you if you are too close or not? For example in cameras, they have features like focus peaking, that highlight what is in focus and what is not in focus, to help with focusing.
But is there anything like that for audio that can tell you if you are too close or too far away from a sound source? |
#52 |
I don't know why you don't think things out when you plan to do these things. Google is your friend and you'll get the answers far faster than in a forum. Here's how the experts do it:
https://www.asoundeffect.com/how-to-...y-loud-things/ |
#53 |
Oh okay I thought I was planning it out as best I could but never recorded something this loud before, so it's new territory for me. But I thought I was still planning it out.
Or at least my plan was to set the fader to the middle then turn the gain till the gun shots feel right, and test out different distances. |
#54 | |
#55 |
I wonder whether anyone in this forum has recorded gunshots. If not, as Brian points out (excellent article by the way, Brian!), Google might be a much better place to start looking. There is a ton of stuff there about gunshot SPL, recording gunshots, gunshot sound effects, etc. That is a much more specific place to look.
If nobody here offers specific advice based on personal experience, then Ryan, if you really want to record your own (rather than use pre-recorded SFX) then I second Brian's suggestion: head on over to Google. Last edited by Greg Miller; July 22nd, 2020 at 01:48 PM. |
#56 |
Oh okay thanks I will do that, thanks. As for SPL, is that why a lot of gunshots sound effecst, sound like they are recorded from far away, because the mic needs to be far away to prevent distortion?
#57 |
I use dynamic mics when recording L O U D sources. Inherently, dynamic mics can handle higher SPLs than condensers. An SM57/58, Sennheiser 421 are popular choices The Shure SM11 dynamic lavaliere is good in limited space areas like engine compartments.
#58 |
You don't record sound effects by changing distance for SPL reasons, you do it to match the picture. If you are standing next to the shooter, you need to record a close perspective, so you use pads - if you record from a distance your picture needs to show the gun at the same distance.
Did we not do gunshot recording a couple of years back? |
#59 |
Oh if we did, I didn't get to do those recordings back then. But yes, the plan was to get close gunshots, because all of the stock sounds of gunshots I can find online, do not sound close enough, so I want to get close.
#60 |
I found free gun shot fx that were recorded close and at various distances in online libraries. I'm not sure what you expect these guns to sound like in a recording, the reality can be very different to what you imagine them to sound.
