HDLink -- various questions - Page 10 at DVinfo.net
CineForm Software Showcase
Old August 19th, 2007, 10:41 AM   #136
CTO, CineForm Inc.
There is no difference in the M2T handling for Prospect HD and Aspect HD, so more likely there was an install issue. I just tested my PHD M2T conversion, and its working fine. Uninstall Prospect HD, and re-install again. If the problem continues, work with support tomorrow -- file a trouble ticket today.
Old August 19th, 2007, 01:25 PM   #137
Thank you David,
I will do that.
Marc Colemont is offline   Reply With Quote
Old September 8th, 2007, 04:48 PM   #138
HDLink File conversion
Easy question, when converting .m2t, avi files etc using HDLink does the process convert them from 8 bit to 10/12 bit Cineform avi files or do you have to render them out within AE or PPro to increase the bit depth?
I've searched the forum and can't find a definitive answer.
Dean Gough is offline   Reply With Quote
Old September 8th, 2007, 10:45 PM   #139
CTO, CineForm Inc.
YUV 4:2:2 is always stored with 10-bit precision (even for 8-bit sources.)
RGB 4:4:4 and RGBA 4:4:4:4 is always stored with 12-bit precision.
Old September 8th, 2007, 11:23 PM   #140
Thanks for the answer David.
Just to be absolutely clear, this is for both live captured and manually converted files?
Within HDLink there doesn't seem to be a facility to choose to convert YUV material to 4:4:4. Does it choose the output bit depth based on the colour space of the incoming video file?
I'm using the demo at the moment and I've converted a few files. When I bring them back into AE7 they only show up as "millions of colours" which Iwould presume is only an 8 bit depth. The demo Viper footage all imports with "trillions of colours"
Old September 9th, 2007, 10:09 AM   #141
CTO, CineForm Inc.
In AE7 are use the CineForm importer or the default AVI importer? The AE AVI importer is only 8-bit.
For 4:4:4:(4) file creation you will need to use AE or PPro, HDLink link needs some upgrades for DPX file input.
Old September 9th, 2007, 04:21 PM   #142
I assume it uses the Cineform importer as the demo Viper footage interprets as "trillions of colours". When footage is rendered out in AE7 as 444 and then reimported it also displays the high bit depth.
Just to be sure it is not the AE importer I will force the Cineform importer with the Shift/Ctrl key and post the results.
Thanks for your help.
Old September 10th, 2007, 12:57 AM   #143
Forcing the Cineform importer seemed to cure the problem. Files converted by HDlink appear as "trillions of colours".
Highly likely we would convert all files to 444 anyway for compositing. So guess we have to run through AE anyway.
Interestingly these show up correctly even when Cineform importer is not forced.
Thanks for the help.
Old September 13th, 2007, 10:36 AM   #144
Missing HDLink in build 91
I just installed Aspect HD build 91 and it doesn't install HDLink. In Start>Programs>Cineform there is only the Tools folder, no Aspect folder.
And while on the topic of Tools, what is the Register Components script for?
Bruce Findleton
Land's End Productions
Pleasanton, CA
http://www.landsendproductions.com
Bruce Findleton is offline   Reply With Quote
Old September 13th, 2007, 11:15 AM   #145
CTO, CineForm Inc.
It should be there, and no other reports of is missing. un-install and re-install.
"Register Components" -- used under tech support directive if certain errors occur -- can fix installation issues.
Old September 13th, 2007, 11:55 AM   #146
Uninstalling manually instead of letting the installer do it did the trick. Thanks.
Bruce Findleton
Pleasanton, CA
Old October 10th, 2007, 12:07 PM   #147
HDLink m2t converting problems
I recently purchased Neo2k to see it would improve my workflow with the V1u, DR-60 and FCP (on a dual 2.66 MacPro). But I haven't been successful yet in converting an m2t file into the cineform intermediate codec. I'm trying to run HDLink in parallels, but I get an error message in the log and nothing happens.
Log:
pSinkFilter->SetFileName(T2CW(pOutputFilename), NULL) (0x80004005 - Unspecified error) in (ConvertGraph.cpp at 2099)
Anyone seen anything similar?
-Nick
Nick Williams is offline   Reply With Quote
Old October 10th, 2007, 12:25 PM   #148
CTO, CineForm Inc.
Would I repeat myself and say try support, however it this case I know what it is, and it is funny one. You haven't installed QuickTime on the XP side of you Mac, a tad ironic, and you are trying to create an MOV file under XP which requires QuickTime.
Old October 10th, 2007, 04:33 PM   #149
Hi David, thanks for the response. I'm a little windows challenged, that makes total sense. I'll try it out! thanks!
Old October 10th, 2007, 06:54 PM   #150
Nick, it is counter-intuitive until it sinks in. In fact when we installed Parallels the first time we scratched our head on the same issue until we had the "Doh!" realization....
David Taylor is offline   Reply
