FS4 / FS4 Pro HD various topics - Page 8 at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
Specifically for the FireStore DV Direct-To-Edit Disk Recording Solutions.
Old August 30th, 2005, 05:34 AM   #106
Todd,
What camera are you using?
Bruce S. Yarock
Bruce S. Yarock is offline   Reply With Quote
Old August 31st, 2005, 02:07 PM   #107
Originally Posted by Bruce S. Yarock
Todd,
Bruce S. Yarock
Sony HVR-Z1 , downconverting the output to DV.
Waiting for the HDV upgrade, but don't know when I'll be able to install the upgrade, since I keep having to send the unit in for repair.
Todd
Todd Mizomi
Photographer/Videographer/Editor/Computer Guy
Island Production Group
Maui, Hawaii
Todd Mizomi is offline   Reply With Quote
Old September 2nd, 2005, 03:00 AM   #108
FS-4 PRO Bugs
If anyone has any experience at all with the new FS-4 PRO and comment on this, it would be appreciated. My FS-4 will record sometimes and other times it will give almost every indication it is recording, but it really isn't. For example, when I set up with my XL2 the camera's viewfinder will say recording, the status light on the FS-4 is in record state, the LCD on the FS-4 says recording, but the counter on the LCD doesn't move. When I hit stop on the FS-4 it goes through the same motions it would if something had actually recorded. When I hook up the FS-4 to my Mac after no counter movement (to see if anything recorded) there is nothing. I know when there has been footage recorded to the FS-4 if the counter moves on the LCD. I've made sure I have upgraded the firmware on the FS-4 and my problem seems to arise randomly. By random I mean I could turn the FS-4 on and it will work fine, then after recording something hook it up to my Mac and get the footage. Then I could hook it back up to my camera and it won't work or soemtimes it does work fine. I've also turned the device on and got set up, then shut it off, and have experienced the device not working properly. It's been very frustrating, and Focus Enhancements hasn't been that helpful.
Tom Woodworth is offline   Reply With Quote
Old September 5th, 2005, 01:19 AM   #109
Contributor
Tom,
I don't think that you are alone with your problems. It appears that the FS-4, although more reliable than other D2D devices on the market at the moment, is not 100% reliable. As long as you use your FS-4 I would suggest that you look at the counter on the LCD as the absolute indication of wether the FS-4 is recording or not. If the numbers don't move, you are not recording. You might also consider returning the unit for a new one, maybe it is an issue with your specific unit (but I kind of doubt it, at this point).
Daniel Kohl
Frankenstein meets XL1
Daniel Kohl is offline   Reply With Quote
Old September 5th, 2005, 03:03 AM   #110
FS-4 PRO Bugs
I used my FS-4 last night to shoot a football game. All went well, although I did experience the FS-4 not working properly right away. What happens is that if I turn the FS-4 off then sometimes when I turn it back on it doesn't want to record. This is totally random so I'm not able to pinpoint what the problem is exactly. However, the fix seems to be this: I disconnect the FS-4 from my camera, go to the menu where I can select "hard drive" mode. I don't actually enable "hard drive" mode, but then I exit out and select "record" mode. This has proven to get my FS-4 working properly each time since I've started using this method. It's odd and quirky but so far it's all I got. I did record the entire game and all the clips came through just fine.
Old September 13th, 2005, 11:44 PM   #111
Focus Enhancements
"No disk detected" error
Hello,
when a "no disk detected" error occurs on a FS-4 unit, it means that the internal hard disk on the FS-4 is not detected by the firmware when the FS-4 is trying to complete a Power on Reset and boot from the software on the hard disk. This error does not have anything to do with whether a 4-pin or 6-pin firewire cable is connected to the unit. We use durable hard disks, but they still can be susceptible to shock damage during shipping or if dropped or handled in a way that causes g forces that the internal hard disk can't handle. Overall we don't have many problems with them, but the HD and the fan are the two mechanical assemblies that actually have to move correctly for the unit to work properly.
Hope this helps --
Jim at Focus
As Matt said, the FS-4 will function either with a 6-pin-to-4-pin cable installed, or a 6-pin-to-6-pin cable installed. The main requirement is that the Firewire port on the other end is also a DV IEEE1394-compatible Firewire port at 400Mbps.
Jim at Focus
Jim Olson is offline   Reply With Quote
Old September 23rd, 2005, 03:07 AM   #112
FS4 External Charger - Huge Disappointment
Just arrived from the UK suppliers is a letter telling me that the external charger for the FS4 will ship at the end of the month. It will consist of "an empty FS4 shell with the charging circuit left inside" and cost £140 incl tax (about $237 US). Er, excuse me? It seems the designers have taken the easy way out and given us an unnecessarily large charger which will still have to have a clunky cable and power supply to load down our gear bags. AND we have to pay a high price for a box full of fresh air.
Surely it should be a wall-wart with a battery connector that can be strapped on with velcro? Small and neat (and cheaper) - that's what we need.
What a shame
Ray Liffen is offline   Reply With Quote
Old September 23rd, 2005, 04:28 PM   #113
Focus Enhancements
Sending to Focus product management
Hello,
I forwarded your comment to give feedback to Focus product management. An external charger is certainly needed. I think this was the quickest, if perhaps not the most elegantly engineered, solution that we could offer.
Jim at Focus
Old September 24th, 2005, 03:12 AM   #114
Jim
Thanks for your comment.
Have to say, though, that my mobile phone has an Lithium Ion battery, charges from a wall-wart (included in the price) and cost me £15 brand new ($25).
OK, the phone is 4v and the FS4 is 12v but that shouldn't make a charger on its own cost ten times as much.
If Nokia can charge my phone from a wall-wart then I'm sure Focus can manage it for the FS-4.
When you talk to the Focus management can you check if this present charger is just a stop-gap? If it is I'll wait for the real thing (even a deluxe wall-wart shouldn't be more than $50).
Ray Liffen
Old September 24th, 2005, 08:32 AM   #115
Using FS-4 while Changing Tape
I now have an FS-4 that works. What setup and procedure works best from experience for continous recording of an event with a FS-4/tape combination without stopping the recording on the FS-4 to change tapes in the XL2?
Jeff Milligan is offline   Reply With Quote
Old September 24th, 2005, 09:58 AM   #116
From my experience with the PD170 you have to put the FS4 into manual mode (ie start the recording on the fs4 by pressing the record key twice(once puts it in record pause I think).
That way if you change tapes on the camera the fs4 will carry on recording, however you will need to be careful of camera noise picked up by the camera whilst you are chaging tapes. I used this method during the church service of weddings which can tend to be longer than a tapes worth.
Regards
Mark
Mark Geiser is offline   Reply With Quote
Old September 24th, 2005, 11:32 PM   #117
FS4 and dropped frames
Hi, a fellow videographer had me do some editing on my g5 from an FS4, my first opportunity. Final Cut hd express... It was his first try using the fs4. I was shocked he would use this drive without testing it first. I ran it through the paces, the unit wouldn't work without a battery attached and the files all had to be rendered and were in pieces; short cuts. We had to export each audio track separtely or the video would drop frames. We had to reimport the audio and if we did not follow this proceedure we dropped frames. Also save didn't work and we lost all our changes (we cleared prefs to get video to output to camera). We have accounted this (not saving correctly and audio problems) to the weird format that FS4 put the files in. I think we had a DV download format. Working with Mac systems perhaps we should have gone with Quickstream?
Gregory Hoose is offline   Reply With Quote
Old September 25th, 2005, 01:02 AM   #118
Thanks Mark for your advice. I usually record from off camera mic sources or a feed from a house sound mixer board to avoid noise around the camera (like audience noise) but your point is good about tape changing noise (like the sound the transport makes when it ejects the tape.
Regards also, JeffM
Old September 25th, 2005, 01:16 AM   #119
What file type did he set the FS-4 to record?
What do you mean the files were in pieces? Each shot should be in a separate file until the FAT32 limit is reached, then a new file continues the existing shot.
I don't understand what "DV download format" is?
I fail to see how the NLE not saving can have anything to do with the FS-4 or its files. Did you copy all the files off to your A/V drives or were you trying to edit on the FS-4?
The FS-4 doesn't use weird file types, it is compatible with macs & pc's, that's why it uses FAT32 but you must set the type according to what edit system you will be using. Check that the FS-4 is set to .mov.
I'm not familiar with Macs so I'm sorry I can't be any more help than this, but if you provide a bit more specific information I'm sure some FCP experts will be able to help you.
MW
Mark Whittle is offline   Reply With Quote
Old September 25th, 2005, 09:49 AM   #120
FS4 thanks
I am sorry I don't have more info on this. I did not record the footage and did not set the fs4 myself. I was only the recipient of improper settings it seems. Perhaps the breaking up of the video was due to an improper setting. Whatever the error in settings was, it played havoc with our attempts to edit and save.
Thank you very much for your comments, I will relay them to my friend and see if they help!
  You are here: DV Info Net > The Tools of DV and HD Production > External Video Recording Solutions > Focus Enhancements FireStore
