24p questions - Page 21 at DVinfo.net
Old October 22nd, 2003, 12:49 PM   #301
Space Hipster
Search around some older threads - it's been discussed it pretty heavy detail over the last couple of months.
stephen v2
www.insaturnsrings.com
Stephen van Vuuren is offline   Reply With Quote
Old October 23rd, 2003, 09:04 AM   #302
24p Advanced/24p
So I shouldn't use 24p Advanced unless I'm putting it on film? Also, when i put it in 24p the exposure seems to be a tad darker, i usually raise it back up. Should I not do that, and leave it darker i guess to give it more of a FILM LOOK? or should i make it brighter? Does it make a difference.??
Mike Zorger is offline   Reply With Quote
Old October 23rd, 2003, 10:27 AM   #303
24pA isn't only for film. It's the only way to edit 24p without generation loss. It also allows you to put ~20% more onto a DVD when authored correctly.
The 24p modes set auto iris to -2 because of cinegamma. This is because it's a lot easier to get blown highlights in cinegamma mode since there's no roll off. Turn on your zebra stripes to see where highlights are blowing. It has nothing to do with "film look'', but has to do with preserving data at the higher levels. When highlights are blown, there's nothing you can do in post to get that information back, however, it's relatively easy to adjust levels back up in post.
Sean R Allen is offline   Reply With Quote
Old October 23rd, 2003, 07:53 PM   #304
Give the footage to someone who has a Mac and Cinema Tools. Or I think some program called DVMaker or something like that for Windows will remove the pulldown and give you 24p.
Ted Springer is offline   Reply With Quote
Old October 23rd, 2003, 08:01 PM   #305
Space Hipster
For the 60i, use Magic Bullet to get 24fps.
stephen v2
Old October 24th, 2003, 01:50 PM   #306
I heard and have seen that 24pA is actually more a "film look" than the standard 24p. Can anyone else confirm?
Nick Medrano is offline   Reply With Quote
Old October 24th, 2003, 05:23 PM   #307
Barry Wan Kenobi
Definitely not. The look is identical, when edited as 24P. When edited as 60i, the 24PA is actually a little more stuttery, the 24PN is a bit smoother. 24PN motion looks exactly like film that's been transferred to video.
Old October 29th, 2003, 09:56 AM   #308
Editing with 24p footage
I'm kind of a newbie to this stuff, so I'll try to make it sound some what intelligent.
If you took footage with a 24p camera like the DVX-100 could you edit it in any NLE program and not one of the more expensive programs like Vegas or Avid and still be able to produce an outputted video with a film look?
What would be the noticeable difference in editing 24p footage in a non 24p timeline? Would some frames be missing from the final product?
j
Jay T. Turnure is offline   Reply With Quote
Old October 29th, 2003, 11:28 AM   #309
DVX 24p footy tranfer to film
Ok well i'm pretty new to all of this. But how much does it cost to transfer 24p footage to 35mm, and do they put it back on a mini dv tape for you after they trasfer it?
Old October 29th, 2003, 12:12 PM   #310
Hawaiian Shirt Mogul
24p to 35mm $350 - 750 per minute
they should be up rezzing your DV to HD data files
for $ they can make you a mini Dv copy of the transfer
Don Donatello is offline   Reply With Quote
Old October 29th, 2003, 12:23 PM   #311
if the final output is video - IMO you will not see any difference if you edit 24fps or 29.97 fps ..
because in the final render the 24fps would have to be converted to 29.97 so the pull down would be restored ..
it's not the editor that gives it the film look .. when you shoot 24p and it's shown on TV ( 29.97) it does have the same "flow " as when film is transfered to tape ( 24fps plus pull down = 29.97)
even 24fps DVD's the pull down is added by the player/digital projector or TV ( SD tv's cannot play 24fps they need 29.97 .. many HD plasma's can play 24fps)
you would have to choose 24p or 24pA as to which pull down you prefer ...
Old October 29th, 2003, 12:36 PM   #312
how does it go from 350-750??? Like I'll do it for 350 but never 750.
Old October 29th, 2003, 01:03 PM   #313
Retired DV Info Net Almunus
Mike,
You'll get the best information by directly contacting a film transfer shop. The rates are probably determined in part by the amount of color correction required, the format of the source material, etc.
Old October 29th, 2003, 01:21 PM   #314
Check out www.dvfilm.com
They have a rate calculator for dv to 16 & 35mm transfer.
Example: A 60 min film transfer is $16,200 or $270/min
They also have details on using the dvx100, specifically, in their faq.
Jed Williamson is offline   Reply With Quote
Old October 29th, 2003, 01:31 PM   #315
Barry Wan Kenobi
Depends on the lab.
If you join indieclub.com and become a "sponsor member" ($24/year), one of the benefits is a 10% discount from dvfilm.com. That puts you down around $270/minute.
You really have to shop around to find which labs do work that you like, which ones work with your camera (for example, Swiss Effects doesn't seem to care too much for the DVX100, they prefer the PAL PD150 -- so if you're shooting DVX footage, I wouldn't send it to Swiss Effects). Other labs prefer 24P footage, dvfilm.com can work with direct 24P footage from the DVX.
