24p questions - Page 27 at DVinfo.net
Old December 10th, 2003, 11:05 PM   #391
Barry Wan Kenobi
People transfer to film all the time.
NOBODY TRANSFERS THAT BACK TO VIDEO.
That's the point you're missing. I mean, sure, someone could give you a videotape, and they could cut out a frame from their film transfer and send it to you, but would that be a useful comparison?
Like others have said, I also have never heard of anyone transferring their video up to film and then telecine'ing that back down to video. It just isn't done.
Old December 11th, 2003, 06:55 AM   #392
i just want to see what is looks like transfered to film COMPARED (NOT BROUGHT BACK) to video. ONE clip of a clip brought to film and the OTHER CLIP OF WHAT IS LOOKED LIKE BEFORE IT WAS BROUGHT TO FILM. NOT BROUGHT BACK TO DV.
Mike Zorger is offline   Reply With Quote
Old December 11th, 2003, 07:18 AM   #393
Warden
Mike, what everyone is trying to tell you, is that no one incurs the expense of transferring film back to video. They can't send you a few minutes of film. In order to post it to the net, it needs to be video in order to make a QuickTime etc. If you want to see film go to a movie theatre, then watch the video or DVD.
Please do not use all caps, it is considered yelling and very rude. Thanks for your cooperation.
Jeff Donald
Carpe Diem
Old December 11th, 2003, 08:47 AM   #394
Wasn't there a clip like that online just recently with someone doing a massage? It might have been 24p standard, but its pretty much the same (considering you'd be converting to 24p native if you were using advanced). I'll see if I can find it.
Chris Mueller is offline   Reply With Quote
Old December 11th, 2003, 10:23 AM   #395
Barry Wan Kenobi
The massage clip was mine. That was film transferred to video, compared to the same footage shot straight on the DVX. Which is not what Mike's asking.
Mike, unless we're not understanding what you're asking, the only way you're going to see DVX footage that's been transferred to film is in a theater. And DuArt is one of the few places where that can be done, where they have transferred DVX footage.
How else do you propose to see footage that's been transferred to film, except on film?
I think Fotokem in L.A. also has some test screenings.
As for what you're asking, in a month or two I should have my test completed. I have a variety of things shot on the DVX that will be transferred to film, and the film print will be made available to anyone who wants to order a copy for a nominal charge, so they can project DVX100 footage themselves and see what it looks like.
You could also then look at the original footage on video. I assume that's what you're looking for?
Old December 11th, 2003, 01:16 PM   #396
YES!
Old December 11th, 2003, 09:39 PM   #397
Barry Wan Kenobi
Okay, well, like I said, it'll be about a month or so before the footage is ready.
The lab will make dupe prints available for interested parties, at a nominal charge.
You'd have to order a print from them, and then you'll also have to make arrangements with a local movie house to project the footage for you.
The footage on the test includes indoor & outdoor, primarily anamorphic adapter/24PA/thin line detail, but with some shots from the mini35 as well.
Old December 31st, 2003, 11:35 AM   #398
24p in slow motion
Ok I shot the best 24p EVER a few days ago. Like no one can tops my shit yo. But I put the speed down to 60% in premier pro and it looks kind of funky, what should i do to make the picture more clear/smooth?????
Old December 31st, 2003, 11:43 AM   #399
Space Hipster
Shoot 30p for slow mo. If you must slo mo, check the field settings (I don't have Premier Pro, used to use Premiere 5 some time ago). Premiere Pro may have issue when slow mo on 2:3 pulldown material.
stephen v2
www.insaturnsrings.com
Stephen van Vuuren is offline   Reply With Quote
Old January 1st, 2004, 10:47 AM   #400
Specially for weddings. I made a big mastake and used 24p for weddings. Looks pretty good. But come time to slow it down, it's very gittery. If there does come time when you have to do it. Slow the 24p clips down to 75% with frame blending turned on. Then save/render the clip, re-open it and then type in 75% again if you need to slow it down even more. Either that or apply maximium de-flicker filtering on the rendered clip. Final Cut Pro has a great filter for this.
Best Regards,
Mark T. Monciardini
Riverlight Studios
www.riverlightstudios.com
DVX100/Final Cut Pro 4/Mac G5 Dual 1.8
Mark Monciardini is offline   Reply With Quote
Old January 1st, 2004, 11:25 AM   #401
I may be labeled a heretic for suggesting this, but wouldn't 60i be better (assuming you use a motion sensing app, as I do in AE, to separate and interpolate fields)? You'd have twice as much motion info (albeit at half the resolution, but with smart interpolation that reduction in resolution becomes less of a factor). Maybe I'm wrong....
DVX100A/AT4071a/Vegas/After Effects
Dual 2GHz Xeon PC
Stuart Kupinsky is offline   Reply With Quote
Old January 1st, 2004, 11:34 AM   #402
Space Hipster
That's a good point Stuart - what's the relative loss between shooting 30p and 60i for slow mo. One has twice the temporal sampling, other twice the resolution (for slow mo) - guess some testing might reveal which gives better results. My guess is that 30p with Twixtor would work the best, albeit expensive and slower while 60i might be best for Premier and othe NLE's that are designed to edit pulldown footage.
FCP and Vegas might be different as they both have different engines for handle speed changes.
stephen v2
Old January 1st, 2004, 03:13 PM   #403
Barry Wan Kenobi
I spent quite a bit of time testing this to determine what would be the best. All testing was done with the idea that the main project would be a 24P timeline. Here's what I found:
By far the best results come from shooting 30P and importing directly into the 24P timeline for a 20% slow-mo. The only problem is you only get a slight 20% slow-mo effect -- but if that's all you need, 30P is the way to go.
Next, shoot 60i. The motion information is what you need, and 60i gives it to you. 60i brought into a 24P timeline, and played at 40% speed, gives an exquisite dramatic slow-motion effect. Yes there is a slight softening in the vertical direction, but nowhere near as noticeable as the jitter from slowing down progressive footage.
Next, if you find the vertical softening objectionable (and test it, you won't find it objectionable) you can sort of get away with 30P slowed down to 40%. It's sharper vertically but stuttery compared to 60i slow-mo'd.
Last, last, last resort: 24P slowed down. It just doesn't work well, there's not enough motion information available. Try it if you must, but recognize that it's going to stutter. Warning: do not try to slow down 24P footage in a 60i timeline: the pulldown will be present and will give you very stuttery results. Only try slowing down 24P in a 24P timeline.
One option I never explored: Twixtor on 24P footage. I haven't gotten satisfactory results from twixtor yet, but others swear by it. If it works for you, twixtor'd 24P might be the answer for some.
Old January 2nd, 2004, 12:28 PM   #404
Just as a tangential...
On the special features for the Matrix II (whichever that was) where they did the crazy freeway crashes they said they had muliple cameras running at 120fps. Boy, that would help, eh?
Barry Gribble is offline   Reply With Quote
Old January 2nd, 2004, 12:32 PM   #405
what about if i shot a time laps in 24p and set the speed to about 4000. Would that turn out smooth, or should i still shot in 30.??
thanks
