SDHC substitute for SxS cards - Page 61 at DVinfo.net
Old November 15th, 2008, 12:08 AM   #901
It MIGHT work - if the listed specs are accurate. It only needs to be able to write at 5MB/s so support EX1/3 in HQ modes.
Sony EX3, Vegas 9.0 64bit, Windows 7(64), Core i7, 12GB, RAID1 & 0, HotSwap SATA, 30" LCD(2560x1600)-GTX285 & 24" LCD(1360x768)-7800GT
Ted OMalley is offline   Reply With Quote
Old November 15th, 2008, 12:32 AM   #902
Images: 3
Does this Sandisk reader do the job? I don't see it mentioned among the posts (but there are a lot of them!): Sandisk SDAD-109R? I can't see the Kensington at B&H.
Old November 15th, 2008, 01:59 AM   #903
Originally Posted by Greg Penetrante View Post
I just came across the Transcend Express/34 SSD units.
Does anyone think these even have a chance of working?
Transcend 32GB (MLC) Express Card/34 Solid State Disk SSD Transcend SSD 32GB (MLC) Express Card/34 Solid State Disk Detail Page
-Greg
If that works and the door closes on the EX1 ... wow.
Wayne
Wayne Zebzda
LookLookTV.com
Wayne Zebzda is offline   Reply With Quote
Old November 15th, 2008, 08:08 AM   #904
I have to admit...
Is there somewhere ... please ...
a complete explanation about all these bits and bytes and MB and Mbit per second
and so forth??? Where can a read that a card matches the required specs or better said
is read and write speed in MB/s bites or Bytes, is the datarate in HQ 35 MBits or MBytes?
I am confused (and never was good at maths, I must admit).
Someone please enlighten me. Thanks.
Peter Kraft is offline   Reply With Quote
Old November 15th, 2008, 09:18 AM   #905
all video rates are usually in bits (little b=little bit big B=big Byte).
1 Byte= 8 bits.
so 35Mbits/s= 4.375 MBytes/sec
Usually, capacity (size) of a device is expressed in Bytes.
so a sandisk card is 16GBytes running at 15Mbit/sec or 4.375MBytes/sec.
You still have to guess if the unit is described using 1000 or 1024 multiplier.....
anyway, even if you know all of this, it stay useless since experience shows that card rated at good values are still unable to function properly.
It is a bit like "lumens" or "watts" when applied to consumer electronics.
Marketing B.S is very creative at using science....
Old November 15th, 2008, 10:08 AM   #906
Peter,
You really couldn't find this information in this thread? It's been detailed two or three times in the past NINE HUNDRED POSTS! AAARRGGHHH!!
Seriously, though, this has become a cumbersome and even daunting thread for those stumbling across it to find out information. I suspect we'll need to answer many of of the same questions over and over.
Old November 15th, 2008, 10:30 AM   #907
I know this question has been posted before but I still have not seen the true
answer... ( have seen workarounds)
The question is " has anyone found a card holder or case that is specific to these cards "
Old November 15th, 2008, 11:31 AM   #908
1 Byte= 8 bits.
Ah, les suisses. Ils savent comment expliquer une chose compliquee
en deux phrases. Merci Francois.
And for all those non-fracophonians: Appreciate such simple explanations and come
back for further explanations if necessary ;-) P.
Old November 15th, 2008, 11:39 AM   #909
1 Byte= 8 bits.
Giroud you can't have it both ways.
You say
35Mbits/s= 4.375 MB/sec
then you say
15Mbits/s= 4.375 MB/sec
Which is it?
Ronn Kilby is offline   Reply With Quote
Old November 15th, 2008, 11:44 AM   #910
Originally Posted by Ronn Kilby View Post
Which is it?
Ronn I think this is a typo and should read 35 MBytes in both cases.
Nothing else makes sense to me.
Old November 15th, 2008, 11:44 AM   #911
-Greg
Greg - hey my friend I didn't know you had an EX1. Good to know if I need a 2nd - and vice versa. My contact info is at kilby-dot-tv .
As for this transcend 32GB card - why don't you buy one and let us know? :)
Old November 15th, 2008, 11:54 AM   #912
That cards write speed is 8MB a second. Considering real performance is usually around 2/3rds of what's stated (the sandisk 15MB a sec are found to be what, 9?), that leaves no headroom whatsoever for HQ recording.
Jon Sands is offline   Reply With Quote
Old November 15th, 2008, 11:57 AM   #913
Good one Greg!
-Greg
According to the specs, it can write at "up to" 8MB/s (and reading at 18MB/s) - I think the SDHC cards we're all using are writing around 6MB/s - so it sounds to me like it might work.
Old November 15th, 2008, 11:59 AM   #914
Good point Jon - guess we'll have to see.
Old November 15th, 2008, 03:08 PM   #915
Are the Transcend 32 Gb cards faster than the Lexar SSD Express 8 Gb?
JB
Jose Bucaro is offline   Reply
