Vegas Video discussions from 2005 (Q1Q2) - Page 45 at DVinfo.net
Old February 20th, 2005, 03:41 PM   #661
Sponsor: JET DV
Vegas 5 allows saving up to 10 different screen layouts and easily recall them. ALT-D, 1 simply "recalls" the first layout. Glad that it worked to reset your screen.
Edward Troxel is offline
Old February 20th, 2005, 04:35 PM   #662
Simple ?: Stopping cursor at end of clip
So i get to the end of my video clips and theres no more video frames yet the cursor keeps on going, having a good ole time. Is there a button or setting so vegas will stop the cursor at the last frame of video, without me having to highlight the clip?
THanks
Tim Kay is offline
Old February 20th, 2005, 05:13 PM   #663
I just had to do something similar yesterday to solve a slight visual jitter problem occuring in just one section of a 90 minute project that was occuring whenever I used the MainConcept encoder, even at 2 pass encoding (it occured after fading in after a mid-title section).
So I frameserved to the TMPGEnc encoder (which is known to be slower then the MainConcept one) and that solved the jitter problem.
The MainConcept encoder encoded at 1.33:1 and the TMPGEnc encoder encoded at 2:1 (both using 1 pass as it was a draft review copy). It was worth the extra time to get the problem fixed.
Tony Rockliff is offline
Old February 20th, 2005, 05:47 PM   #664
Importing a veg file
How can I import one project into another project? I was looking to edit and save each of my scenes for my movie individually, so that I can assemble them together later. Can this be done? Thanks.
Glenn Gipson is offline
Old February 20th, 2005, 06:23 PM   #665
Open two instances of Vegas and copy from one, then paste into the other. You could also render each segment and assemble those in another project.
Gary
Gary Kleiner is offline
Old February 20th, 2005, 06:35 PM   #666
Thanks, that worked like a charm.
Old February 20th, 2005, 07:41 PM   #667
Sponsor: JET DV
In most cases, playback will stop a few seconds after the last clip on the timeline. However, I have seen cases where it just keeps on going. You can always just press the space bar or enter to stop the playback.
Old February 20th, 2005, 08:32 PM   #668
Nope, this one doesn't stop it just keeps on going like the energizer bunny. I guess i could "just" press the space bar but i'm trying to be really lazy/efficent and see if the cursor would stop automaticly so it doesn't keep moving the time line to a new screen
<<<-- Originally posted by Edward Troxel : In most cases, playback will stop a few seconds after the last clip on the timeline. However, I have seen cases where it just keeps on going. You can always just press the space bar or enter to stop the playback. -->>>
Tim Kay is offline
Old February 20th, 2005, 08:35 PM   #669
Sponsor: JET DV
Here's a hint: Start playback, click somewhere on the timeline or just slightly move the timeline. Now the timeline will continue to play but the screen will never be updated until you pause playback!
Old February 21st, 2005, 12:12 AM   #670
Thanks Glenn, very subtle work.
I liked the highlight across the drummer's shirt , creating contrast between the subject and background using cool vs warm, and enhancing the lighting. Excellent.
Scott
Scott Brickert is offline
Old February 21st, 2005, 10:22 AM   #671
My video lags on the time line
When I play my clips in the Trimmer Bin, they play fine, but when I play SOME of my clips on the time line, they have this ghostly lagging effect to them. By the way, I shot in 24pA mode with the DVX100A. What could I be doing wrong here? Why are some clips playing smoothly, and som aren't?
Old February 21st, 2005, 10:24 AM   #672
Hmmm...now the problem is gone...but why could this be happening SOMETIMES?
Old February 21st, 2005, 11:15 AM   #673
Pip Bouncing Ball Transition
I've created a basketball video with stills that fly in and out as the video plays. My question. Is there an easy to use transition to make the still picture bounce in and bounce out. I have tried the "Wax Bouncing Ball" transition but having alot of problem getting it to work eg. crashes Vegas. Any other transitions out there where I can do this or is it easier to work within the track motion and manually produce this?
Thanks in advance.
Peter Battaglia is offline
Old February 21st, 2005, 01:55 PM   #674
Latency of Creative's ASIO drivers
Why does my audio surge ahead noticably when using these drivers, compared with DirectShow? I thought the idea was to achieve zero latency.
Emre Safak is offline
Old February 21st, 2005, 02:01 PM   #675
It could be the preview quality. If it is set too high, the computer might not be able to keep up. I always edit in "Draft" mode.
