Vegas Video discussions from 2005 (Q1Q2) - Page 46 at DVinfo.net
Old February 21st, 2005, 07:10 PM   #676
Found Transition
Never mind
Found a great Bouncing Ball Transition at:
http://mikecrash.wz.cz/
Peter Battaglia is offline
Old February 21st, 2005, 08:07 PM   #677
Sponsor: JET DV
Forgot about that one. I was thinking maybe Adorage but nothing in that package was really coming to mind.
Edward Troxel is offline
Old February 22nd, 2005, 04:32 AM   #678
not really zero.. more like anythign between 2 to 10ms..
to get the most out of ASIO, u realy do have to set a buffer within Vegas, not only that, but run a DX diagnostic and adjstu yoru settings as required..
im using an audigy a have a latency of about 2ms, mind you im using a virtual midi cable triggering my sequencer (Sonar) which in turn is controlling my synths..
so if i can get it this tight with all this gear while running Vegas as the master im sure with some tweaking u cna too :)
Peter Jefferson is offline
Old February 22nd, 2005, 09:46 AM   #679
I have an Audigy too. What is the procedure for this tweaking, and do I have to use additional software besides Vegas 5?
Emre Safak is offline
Old February 22nd, 2005, 07:26 PM   #680
just make sure u run the latest drivers from creative, make sure ASIO is selected and then open up the audio properties. you will be given a small box with a 3 digit number in tehre. thats your latency setting.
put this to 10ms
Old February 22nd, 2005, 08:12 PM   #681
Delivering HD on DVD/Frameserving
Part One of a comprehensive frameserving tutorial from Mark Dileo & VASST is available. Hope you find it of use. It's on how to get HD onto a DVD now.
Part II will be available later this week. http://www.sundancemediagroup.com/ar...frameserve.htm
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline
Old February 22nd, 2005, 09:02 PM   #682
Correct. Cineform (you want to use the version found on the Sony site) will create the DI that Vegas likes to use.
You don't have to use Cineform, you can use DVHS capture (free) but then you're editing M2T files and that's very painful.
Old February 23rd, 2005, 10:19 AM   #683
Cookie Cutters and transparency?
Is that even possible?
I'm successfully tracking a part of one source as it moves across it's frame using the cookie and keyframes and my idea is to transition this across another un-effected source.
The problem is I don't see any background transparency option. The only option is to give it color which is black by default. That works but it darkens the other stream a bit more than I'd like.
Do I need to reorder my clips or perhaps add some other FX in to accomplish this?
Kevin
Kevin Kimmell is offline
Old February 23rd, 2005, 10:51 AM   #684
Sponsor: JET DV
If you have video on tracks 1 and 2 and apply a cookie cutter to track 1, track 2 will automatically appear in what you are calling the "black" area. No need to do anything else.
Old February 23rd, 2005, 12:20 PM   #685
In this case it's track 8 and 10 with track 9's composite level set to zero....
But now I see. I had to cut a chunk out and move it below the effected track.
Great. Thanks!
-Kevin
p.s. I'm definitely going add a credit for these forums in this DVD.
Old February 23rd, 2005, 09:34 PM   #686
I had terrible times with Vegas crashing when I first had Vegas 4.0. Turns out my hard drives were overheating. I added a fan and haven't crashed in over a year. (knock on wood).
Overheated hard drives can cause all sorts of trouble so make sure they are well ventilated.
Steve
pdx10, EOS10D
Steve Roffler is offline
Old February 23rd, 2005, 09:56 PM   #687
Me too. Now when capturing or rendering I always run a strong external fan over all my external drives.
Tony Rockliff is offline
Old February 23rd, 2005, 10:24 PM   #688
I suggest you read an intro book such as:
The Little Digital Video Book by Michael Rubin.
This helped me a lot in such simple concepts as not moving my camera, not zooming all the time, covering a subject, and managing files. Also, simple editing suggestions are given. The quality of home movies can be greatly improved with just a little effort.
A sample of my first home video is here:
http://www.vanemery.com/~sroff/2004/satweb.wmv
It may give you some ideas.
Steve
pdx10, EOS10D
Old February 23rd, 2005, 10:39 PM   #689
My machine used to crash during some (about 20% of them) renders too, until I downclocked my CPU back to normal. Make sure you're not overclocking.
Also, 5 days of uptime on Windows is pushing it IMO.
Aaron
My Website
Meat Free Media
Aaron Koolen is offline
Old February 24th, 2005, 12:00 AM   #690
Changing DVDA Chapter Graphic
Question, when I create chapter points in V5 and import them into DVDA I'd like to be able to change the actual graphic that is displayed. Can this be done in DVDA or is it easier to take a screen shot in V5 and import the graphic as a thumbnail?
Brian Burns is offline
