Vegas Video discussions from 2005 (Q1Q2) - Page 55 at DVinfo.net
Old March 7th, 2005, 08:02 PM   #811
Volume problem with AC-3
Rendered my first project out using AC-3 tonight. I noticed it has a default "-25db dialog attenuation". I changed it to -10db thinking I could make it louder because I have heard others complain about ac-3 being too quite.
Well it is less than half of the original volume! I spent a great deal of time normalizing and adjusting all my audio levels while editng...it's a bit frusterating that the AC-3 encoder screws it all up!
My question is: 1) Shouldn't a lower attenuation # be louder? (ie changing the default -25 to -10)
and 2) If I change it to -0 would that yield the same volume levels I had in post?
Glen Elliott is offline
Old March 7th, 2005, 08:24 PM   #812
Use a Gaussian Blur and Keyframes to change the "focus"
Don
Don Bloom is offline
Old March 7th, 2005, 08:44 PM   #813
How to make a Vegas 5 script?
So,that is my question. And what is the tool for making?
Another question:
Film Looks by Magic Bullet are stored as .mbl, but when I create and save a new film look file with MB Editors via Vegas 5, then I can't see it as .mbl file. Why???
Plamen Petrov is offline
Old March 7th, 2005, 09:00 PM   #814
Sponsor: JET DV
Change the dialog normalization to -31
On the PreProcessing tab, change both the Line mode profile and RF mode profile to NONE.
Edward Troxel is offline
Old March 7th, 2005, 09:04 PM   #815
Sponsor: JET DV
A script is simply a text file (which you can make with notepad) that contains the proper code to perform the desired task. Any particular type of thing you are wanting to script? I have a lot of scripting info in my newsletters.
Old March 7th, 2005, 09:12 PM   #816
Thanks Edward- that did the trick!
Old March 7th, 2005, 09:31 PM   #817
What is a Keyframe?
Glenn Gipson is offline
Old March 7th, 2005, 09:48 PM   #818
Sponsor: JET DV
A keyframe is a set of values for the effect at any one point in time. So if the effect needs to change over time, you make a keyframe with the first setting, move down the timeline, and then make a second keyframe with the second setting.
I explain keyframes in vol 2 #8 of my newsletter.
Old March 7th, 2005, 10:46 PM   #819
Edward
Is there any sort of Script that would Increase the Brightness/Contrast ratio while paying attention to the 100 IRE and 0 IRE on the Videscopes?
Basically, an automatic adjsutment but NOT going over on highlights or under onthe 0 IRE?
John Hudson is offline
Old March 8th, 2005, 03:47 AM   #820
r u refering to a rack focus??
layer 2 tracks,
on the lower track run a slight gausian blur,
on the upper track, run a cookie cutter filter
voila instand rack focus
Peter Jefferson is offline
Old March 8th, 2005, 03:49 AM   #821
oops.. sorry..
another trick for a tunnel vision kinda effect is to run a radial blur.. this might be a lil more effective when conveying that feeling of blindness..
Old March 8th, 2005, 05:24 AM   #822
<<<-- Originally posted by Peter Jefferson : oops.. sorry..
another trick for a tunnel vision kinda effect is to run a radial blur.. this might be a lil more effective when conveying that feeling of blindness.. -->>>
Excuse my ignorance about Vegas, I know so little about it, but how do I do this cookie cutter effect? Where is it? Thanks.
Old March 8th, 2005, 06:29 AM   #823
cookie cutter is in the VIDEO FX tab, grab it place it on the event you want it on.
Let me suggest that you might want to read some of the Tips and Tricks Newletters written by Edward Troxel. He has Vegas broken down in a way that explains most everything there is to know about it. Print them out and use them as a resource.
Don
Old March 8th, 2005, 07:12 AM   #824
Vegas and 3 mics
I'm needing to go from 2 mic setup to 3 mics. Does Vegas & Sound Forge support a 3 or 4 mic setup? Never tried. Of course the 2 mic setup is easy. What are, if any problems with this setup?
Tony Sellars is offline
Old March 8th, 2005, 07:40 AM   #825
Broadcast Colors In Vegas 5
Hello,
How to use Broadcast Colors In Vegas 5 actually? I cannot see a difference when applying it. So? What is the purpose???
