Vegas Video discussions from 2005 (Q1Q2) - Page 68 at DVinfo.net
Old March 23rd, 2005, 03:23 AM   #1006
Probably not. 64 bit just means bigger numbers. Right now the biggest numbers used in video is 32-bit floating point for rendering. Acquisition is 8bit for DV, and 10bit for uncompressed and 12-bit for some film formats. I might be wrong, but I don't envision video programs use 64-bit numbers for rendering as the extra precision would be totally unnecessary and add to rendering time.
Glenn Chan is offline
Old March 23rd, 2005, 06:37 AM   #1007
hang back for v6 ....
from what ive heard, its going to change the way ppl see sw based editors......... put it this way, irrespective of whether ur lookin at 32 or 64 bit. if u have a HT processor u can expect some major MAJOR changes..
Peter Jefferson is offline
Old March 23rd, 2005, 08:04 AM   #1008
Sponsor: JET DV
Just a reminder that nothing has yet been announced concerning Vegas 6 or what it may contain.
Edward Troxel is offline
Old March 23rd, 2005, 11:03 AM   #1009
interval time quirk
Hey all,
This might not be an XL2 issue but a Vegas 5 issue - but I'll work backwards here.
Was messing around with the interval time function then running the tape off into Vegas 5 (build b).
The oddest thing happened in that Vegas completely ignored the section of the tape where I recorded a sequence set at a .5 second capture at 30 second intervals. Vegas grabbed everything else off the tape except this 30 second section. Went back a few times to try and recapture that section but nada. Very odd.
Anyone else come across this?
Dan
nyc
Dan Barnhill is offline
Old March 23rd, 2005, 12:43 PM   #1010
oops - looks like I was moved. sorry about that.
so to clear it up a bit - it's the canon xl2 going into vegas 5 (build b) that i'm working with.
sorry for the misspost.
db
Old March 23rd, 2005, 01:31 PM   #1011
Sponsor: JET DV
You may have "Minimum Clip Length" turned on and it is ignoring the .5 second clips because they were "mistakes" (i.e. accidentally starting and quickly stopping the camera - or so it thinks.) Turn off that option and see if it will capture that section.
Old March 23rd, 2005, 04:41 PM   #1012
Voila! That did it. So many little things in Vegas I haven't found yet...
Thanks a bunch Edward.
Dan
Old March 23rd, 2005, 09:54 PM   #1013
Sponsor: JET DV
Glad to hear it all worked out.
Old March 23rd, 2005, 11:10 PM   #1014
true very true.. NAB should unveil the surprise ;)
Old March 24th, 2005, 01:01 AM   #1015
I also have to check off "Enable DV Scene Detection" when capturing because else it creates one DV file for each intervall recording ...
Frank
Frank Aalbers is offline
Old March 24th, 2005, 01:12 AM   #1016
frank thanks for that tip because if this wasn't just a test, the large bulk of .5 sec files i have sitting in a file would be a bit upsetting....
dan
Old March 24th, 2005, 02:53 AM   #1017
Putting letterbox to ALL events
Hello,
I had about 50 events in the timeline. After the editing was complete, I made the letterbox for the first event.
But I did not know how to put the letterbox to all events rather than clicking Even Pan/Crop button for each events.
How do you put the letterbox to all events simultaneously?
Kevin Kwak is offline
Old March 24th, 2005, 03:06 AM   #1018
Apply a Mask on a Video Track above your project. get the file here:
http://www.visuar.com/letterbox/calc.htm
and stretch teh file the length of your video...then render it out.
simple.
- ShannonRawls.com
Shannon Rawls is offline
Old March 24th, 2005, 03:35 AM   #1019
Thanks Shannon,
but I like to stick with Event Pan/Mask tool. Trying to find out on how to apply the letterbox on all events simultaneously, and not individually (which takes a long time).
Old March 24th, 2005, 03:55 AM   #1020
Here's an honest articel about 64bit computing.
http://www.techreport.com/reviews/20...s/index.x?pg=1
Glenn Gipson is offline
