Vegas Video discussions from 2005 (Q1Q2) - Page 75 at DVinfo.net
Old April 1st, 2005, 09:37 PM   #1111
Sponsor: JET DV
What happens if you turn on supersampling?
Edward Troxel is offline
Old April 1st, 2005, 10:34 PM   #1112
Are you going through firewire to your video camera and then from your camera to the second monitor via s-video or composite? I believe that is the correct setup for previewing Vegas on an external monitor.
Steve
pdx10, EOS10D
Steve Roffler is offline
Old April 1st, 2005, 10:36 PM   #1113
I have got cookie cut images to move totally offscreen by setting the z values to -600 or -700 in the 3D track motion.
Steve
pdx10, EOS10D
Old April 2nd, 2005, 03:56 AM   #1114
<<<-- Originally posted by Edward Troxel : What happens if you turn on supersampling? -->>>
Whats supersampling? Sorry but I'm a newbie.
Fred Foronda is offline
Old April 2nd, 2005, 06:26 AM   #1115
Sponsor: JET DV
search for "Supersample" in the help file. That will give you all the info you need to turn it on and explain what it does. However, it will drastically increase your render time.
Old April 2nd, 2005, 01:19 PM   #1116
Steve, yes as far as previewing on an external monitor but I'm referring to having the Vegas layout across two computer monitors. Thanks
Michael Best is offline
Old April 3rd, 2005, 02:39 AM   #1117
fix it. its not vegas its the gx7 recorder's settings...changed it from SP to HQ looks good now. Thanks!!
Old April 3rd, 2005, 03:36 AM   #1118
RED Code Chef
I have a letterbox calculator and matte downloads available:
www.visuar.com/letterbox/calc.htm
I have no idea what could cause that white line you are describing.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old April 3rd, 2005, 04:10 AM   #1119
RED Code Chef
Did this problem not happen when testing the workflow?
I would switch to work on the original source files. Yes it may be
a lot slower, but you should not have that problem at least!
Old April 3rd, 2005, 04:19 AM   #1120
RED Code Chef
Did you try to use any other interfaces? I have had my share of
(driver) problem with the m-audio sonica USB audio device. The
newer drivers never seemed to work (with digital out), the old
one that came with the CD did. You may want to play around with
driver versions etc.
Old April 3rd, 2005, 05:22 AM   #1121
RED Code Chef
Actually, the codecs do NOT need to respect aspect ratio (other
than to store the correct aspect ratio). The players need to
respect it. Windows Media Player doesn't even play DV in the
right aspect ratio (also with SVCD MPEG for example).
If you output to any other codec than DV AVI or MPEG-2 for DVD
then output at 1.0 pixel aspect ratio at the correct resolution.
Multiply the project PA with the horizontal resolution to get the
correct horizontal resolution.
MPEG-2 for DVD *DOES* need the correct pixel aspect, as does
DV AVI. Everything else, including all other AVI codecs, QuickTime,
Windows Media (HD) etc. should get a 1.0 PA.
Old April 4th, 2005, 04:54 AM   #1122
Old Boot
Sony VEgas Site Down?
Is it down?
Grazie
Graham Bernard is offline
Old April 4th, 2005, 04:57 AM   #1123
Is for me yeah! Cool, guess that means they're updating it for the new Vegas 6 :)
Aaron
My Website
Meat Free Media
Aaron Koolen is offline
Old April 4th, 2005, 05:03 AM   #1124
Old Boot
Hiyah Aaron! Howzit hanging?
So you can'r get on either?
Oh yes Vegas 6 . . tick tock . . tick tock . . tick tock . .
Grazie
Old April 4th, 2005, 05:36 AM   #1125
Sponsor: JET DV
It appears to be giving a SQL Server error message. I'm sure they will get it back soon.
