Vegas Video discussions from 2005 (Q1Q2) - Page 81 at DVinfo.net
Old April 15th, 2005, 01:31 PM   #1201
Once video clips all the detail is lost and there's nothing you can do about it.
If it's not quite overexposed, there will be detail in the knee that you can rescue.
If the footage has clipped, there are still some things you can do.
A- Add the color corrector and pull down the gain so the video ends up in the legal range.
B- Make the overexposure look intentional/artistic.
C- Before the colors hit clipping, they may have a color shift. You may be able to use the secondary color corrector to bring down the saturation of those colors.
2- The Xl1s should have zebras, manual exposure, and autoexposure shift. If you know how to use these features you can easily avoid overexposure.
For stage productions, set the AE shift to make the image darker as stage productions usually use high contrast lighting. Auto-exposure will try to expose for the average (both shadows and highlights), which means highlights get blown out.
You can also set exposure manually, which can avoid this problem too.
When shooting, make sure the zebras don't appear over important detail.
The GL2 footage is nice apart from the fact the lighting guy didn't remove coloured gels on some of the lights.
You shouldn't be asking him to do that?
Glenn Chan is offline
Old April 15th, 2005, 01:50 PM   #1202
Images: 10
sometimes, using a compositing child duplicate track set to "multilply" mode, really brings out highlight detail that you thought was lost.
Bill Ravens is offline
Old April 15th, 2005, 03:45 PM   #1203
<<<-- Originally posted by Jim Lafferty : Not to derail the thread, but I see you're in Baton Rouge -- ever heard of a guy named Kevin Kuperman ("kup")? -->>>
I do not.
Should I? Am always looking to meet ppl w. similar interests.
Back to the monitors:
One thing I noticed is that when I went from 2k to XP, the dual screens has been problematic. The spanning used to be controled by ATI's Hydravision app, which is installed on my XP box also, but the spanning is now done by XP's display properties instead of ATI. And if I tell it to span my desktop to both monitors it will do it, but the task bar only runs the length of the primary monitor, and the 2ndary is just blank background until I put something on that screen. When ATI did it with 2k, the taskbar spanned both monitors. So, I dunno. Prolly go back to 2k anyway.
Chris Trainor is offline
Old April 15th, 2005, 04:12 PM   #1204
He was until recently a DJ from around there - an old friend, too.
About HydraVision -- nVidia's cards have a similar app that run dual monitors -- I'd suggest re-installing your vidcard's setup utilities and fool around with them before jumping back to 2k. There's no way the control panel in XP will be as versatile as the apps associated with the card...
- jim
Realism, anyway, is never exactly the same as reality, and in the cinema it is of necessity faked. -- J-L G
Jim Lafferty is offline
Old April 15th, 2005, 06:08 PM   #1205
Sony's DVD Architect
/Not really about Vegas, but...
I really like Vegas's ability to work within Sound Forge, especially with the AUDIO TAKE options.
After spending about a week in Architect, I cant seem to find that seemless intergration.
I am probably missing something, but there seems that there has to be a way to adjust the volume for the menus in DVDA. But I cant seem to find it. So I am opening soundforge, lowering the volume, then replacing the audio.
Where's the shortcut??
image:
http://bouncebooking.com/temp/dvda.jpg
Old April 15th, 2005, 06:15 PM   #1206
To the best of my knowledge thats the only way to adjust the DVDA volume BUT with DVDA3 coming out in about a week and since nobody in the know is talking about whats new in it you might want to wait until DVDA3 comes out to see if they've changed that.
Don
Don Bloom is offline
Old April 15th, 2005, 06:33 PM   #1207
Editing XL2 footage
I am going to be using an XL2 for the first time in 2 weeks and have a question about the editing of it all. First of all, I am simply recording an indoor play. What frame rate should I shoot at? 60i, 30p, or 24p. Then, having determined that, how do I edit it. Do I have to change my project properties to accomodate it? If you could help me out with that, that would be fantastic.
MITCH
Mitch Buss is offline
Old April 15th, 2005, 06:57 PM   #1208
If you want to make life easy for yourself, shoot 60i or 30p. 30p arguably gives film-like motion, without strobiness and is easy to edit.
You don't have to change any project properties to edit it. If you encode the footage, be sure to 'tell' the encoder your footage is progressive (many encoders assume your footage is progressive and work best with progressive footage).
Old April 15th, 2005, 08:06 PM   #1209
Sponsor: JET DV
You do all of your editing in VEGAS. You adjust the volume level in Vegas. You then render to the appropriate files and load those into DVDA already adjusted. DVDA builds the DVD, Vegas edits the video and audio.
Edward Troxel is offline
Old April 15th, 2005, 08:27 PM   #1210
<<<-- Originally posted by Edward Troxel : You do all of your editing in VEGAS. You adjust the volume level in Vegas. You then render to the appropriate files and load those into DVDA already adjusted. DVDA builds the DVD, Vegas edits the video and audio. -->>>
Yea.
Just some of the stuff is just a static menu. A background, a link and audio...
Old April 15th, 2005, 09:45 PM   #1211
Better Processor for Vegas 6- AMD or Intel
Intel 660 3.8ghz
or
AMD Athlon FX-55
According to Tom's Hardware tests for the Main Concept Encoder the 3.8 is the way to go. However- Vegas 6 might have new optimizations to take advantage of the AMD.
Glen Elliott is offline
Old April 16th, 2005, 04:24 AM   #1212
Wait for the dual cores...
Old April 16th, 2005, 11:12 AM   #1213
The rendertest.veg results show that Intel has a slight lead. They run neck to neck though.
You can find rendertest.veg results if you search hard enough at the Sony Sony Vegas forums (at the Sony site). Keep in mind, Intel released the Prescott-core Pentiums which are ~6% faster than Canterwood-core (old) Pentiums, so the newest results are the most relevant.
I would expect Vegas 6 is give Intel a boost since Vegas 6 boasts better multi-processor support. Vegas never took advantage of dual processors and hyperthreading well... it should with Vegas 6. Rendertest.veg was also slightly stacked in AMD's favor by a few percent because of that (less complex renders would see more benefit from hyperthreading).
It would seem the best performing system now is a dual Xeon (with the equivalent Prescott-core Xeon... I forget what's it's called... Norcona or something). With Vegas 6, it should be a good deal faster than a single processor system.
If that's too expensive, get a moderately-priced single processor system to string you along (i.e. 3.4ghz). Keep in mind, dual cores may be expensive when they first come out.
As always, it's a good idea to buy a few steps down from top of the line as the bleeding edge is ridiculously overpriced and computer speed doubles about every 2 years (or 18 months). It's also a good idea not to wait for the next best thing because then the next next best thing will be just around the corner...
Old April 16th, 2005, 12:02 PM   #1214
without gettin into trouble a dual xeon config with a raid HDD array and at least 2gb of ram would be more than enough to edit HDV
now with the dual core cpus coming out, i feel that the new 955 chipset would be worth waiting for if only for the price factor alone..
not everyone can afford a 6000k workstation...
personally id rather pay a lil less for cpu power (or pay less for a single cpu altogether), get a Mobo which has 1066fsb, increase the ram as high as i could, and that in turn would increase my pagefile... so i then i know that my rendering will have enough bandwidth and grunt to be processed quickly...
Peter Jefferson is offline
Old April 16th, 2005, 03:11 PM   #1215
Neither. Go for dual processors or dual core, esp. considering that the next version of Vegas is going to be multi-threaded.
Van Lam is offline
