Vegas Video discussions from 2003 - Page 113 at DVinfo.net
Old December 9th, 2003, 08:21 AM   #1681
Sponsor: JET DV
Take a look at Issue #12 of my newsletter http://www.jetdv.com/tts
I put the blur on the BOTTOM track and use the cookie cutter to cut a hole in the top track. One advantage of doing it this way is that you can apply multiple cookie cutters to blur multiple areas.
Edward Troxel is offline
Old December 9th, 2003, 10:23 AM   #1682
If you are using blur, then the track being above or below is a matter of preference. I prefer to use pixelation, which works better on the top layer. If you cookie cut after the pixelization, you get a perfectly cut section, which looks strange. So you want to cookie cut before you apply the pixelization. This makes the edges get the same effect and obscures the division between the two layers.
Joe Sacher is offline
Old December 9th, 2003, 06:05 PM   #1683
Play After Function to Link MPEG's in DVD Architect?
Hi, I'm a newbie to DVD Architect.
Here's what I want to do. I have a dance concert with multiple pieces which so far have been rendered as individual MPEG's. I want a DVD that either allows a selection of individual pieces or plays the entire concert from start to finish including start and end credits.
Does DVD Architect have a play after function to link the mpeg's, or do I have to generate a humongous 80 minute single MPEG with markers for the individual pieces that I do scene selections for?
I looked for linking but didn't find it, which appears to put DVD Architect one down on Dazzle DVD Complete!!
Related question: Is there any quality hit from re-rendering an MPEG file if the bit rates, etc are unchanged? I will use my previous renders to make my humongous MPEG if needed. This is also useful to avoid a complete re-render if you correct a mispelled a name in the closing credits, etc.
-Tom-
Tom Voigt is offline
Old December 9th, 2003, 09:48 PM   #1684
Sponsor: JET DV
Right now, you MUST create a single MPG file consisting of the entire program. That is the only way to play the entire program straight through.
However, within that program you can specify chapters that have starting and ending points meaning you can create buttons that play an individual segment.
Old December 9th, 2003, 11:08 PM   #1685
Please help editing 16:9
What are the settings people use in Vegas to edit 16:9 shot with the anamorphic converter? How to print to tape letterboxed (I get heavy smearing). Thanks for your help!
Fernando Vidal is offline
Old December 10th, 2003, 01:06 AM   #1686
Oops!
Thanks. I am in the midst of building that big mpeg now.
So DVD Architect doesn't have a feature that I took for granted in Movie Factory 2 and Dazzle DVD Complete? But then neither of them have widescreen or AC3 sound......
Old December 10th, 2003, 08:17 AM   #1687
Sponsor: JET DV
No. DVDA does NOT have end actions. I look for this to be remedied in the next version but have no guarantees that will happen.
As Sony posted a while back: They would rather release a solid product that doesn't crash instead of trying to cram in all kinds of features without the time to make those features solid. As Vegas has increased in power with each release, I would expect the same with DVDA.
Old December 10th, 2003, 08:53 AM   #1688
RED Code Chef
To the best of my knowledge your project aspect settings should
match your output aspect settings. So if you output for 16:9
set project to 16:9 as well (you can change this while in the middle
of a project).
The aspect ratio on the footage is to let Vegas know what aspect
the footage is IN. Not what it should go to. Pictures have an
aspect of 1.0.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old December 10th, 2003, 11:38 AM   #1689
Here are some examples.
http://supersorteos.com/b.htm
Old December 10th, 2003, 03:20 PM   #1690
RED Code Chef
Did you shoot the footage in interlaced or progressive? What
project and output settings are you using? I'm pretty sure you
have either of these two wrong and they are definitely not using
the same settings. If your footage is progressive you should
have the project and export settings as progressive as well!
Old December 10th, 2003, 03:43 PM   #1691
It looks like an interlacing issue to me as well. Make sure that you right-click on the media in Vegas and tell it that the aspect ratio is widescreen (1.2121). If it was shot with an adaptor, Vegas most likely thinks it is 4:3. Then you need to make sure it deinterlaces when converting to 4:3 letterboxed. It looks like the project settings are set to no deinterlacing when rendering.
Old December 10th, 2003, 04:11 PM   #1692
Thanks for your replies. All the settings are set to progressive: in the project properties, in the clip on the timeline and in the output.
I have tried, with rendering with and without the pulldown, widescreen and all the settings, but always leaving the progressive on...I also changed the deinterlacing to the three available options, and the same results...
I don't know what else to do at this point...thanks again
Old December 10th, 2003, 04:14 PM   #1693
RED Code Chef
And you also did shoot progressive? With what camera?
Old December 10th, 2003, 04:15 PM   #1694
With the dvx100, 24 progressive advanced
Old December 10th, 2003, 04:39 PM   #1695
Rob, I think the mistery is resolved...I was shooting using the scene file F5 which is were I have storaged 24 progressive. But I have just realized that when I access the settings, it does not show the setting for the F5, but for the F1 which is interlaced! So I shot everything interlaced although the setting was set in F5! which still has the progressive mode...anyway, thanks so much for making me sure that I was shooting progressive!
