Adobe Premiere & Premiere Pro discussions from 2004 - Page 35 at DVinfo.net
Adobe Creative Suite
Old May 26th, 2004, 02:44 AM   #511
Johnny,
Can you please explain what you are doing? I have never seen this problem. Could it be the compression type you are using on your footage. How are you previewing it? Does it happen if you import a title made in photoshop?
It could just be that after effects alpha is better or that its titles have a better engine?
Ed Smith
Hampshire, UK
Good things come to those who wait
My Skiing web www.Frostytour.co.uk
For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors
Ed Smith is offline
Old May 26th, 2004, 07:16 AM   #512
Okay if I capture the video in Pro and export it to a .mov then it keeps the black bars so I'd asume it would do that with the DVD to (I'll try it sometime) but I looked at the properties and it didn't say anything about it being 16:9. So I don't know but it did work when I exported it to a mov file but It didn't when I tried to expoet it to a window media video. So we'll see I'm shooting a short here and I want to do it in widescreen so I'm just making sure it will work.
Kyle Kauss is offline
Old May 26th, 2004, 09:34 AM   #513
Grain is pretty hard to get rid of in post. However most find that placing 2 instances of the clip, 1 in video track 1 and the other in track 2, then setting a 50% opacity on the clip in track 2 will reduce the problem. They need to be lined up identically. If you don't mind slighty blurred footage then apply a guassian blur, that should also reduce it.
Cheers,
Ed Smith
Hampshire, UK
Ed Smith is offline
Old May 26th, 2004, 10:24 AM   #514
Ed, thank you for helping out the little guys. Im new to pro, and still have alot to learn. Im playing around with it now, ill repost and let you know how it came out. Thanks again.
John DeLuca
John DeLuca is offline
Old May 26th, 2004, 04:50 PM   #515
black and white with a pinch of color
Anybody know how take black and white video (made by applying the filter) but say, color a small portion (like a Bride's bouquet in a wedding) using Adobe Pro?
Anita Hu is offline
Old May 26th, 2004, 07:08 PM   #516
5.1 pan/surround not showing in premiere
ok
i'm trying to do a pretty basic surround sound project in premiere pro.
i have a video of a performance where on the left channel i have the clean sound off of the sound board via wireless and on the right channel i have sound from a shotgun mic pointed at the audience.
i want to put the clean soundboard sound on the front speakers and the audience sound on the back speakers.
i can't even get started as in the mixer i can't get the pan thingie to even show up...
i have the balance button but not that rectangular box with the front/back/center speaker icons etc.
any suggestions on how to get this sucker t show up??
matthew
Matthew de Jongh is offline
Old May 27th, 2004, 02:40 AM   #517
Rather than explaining it step by step, take a look at wrigley videos Premiere tutorials.
Take a look here, Colour Pass effect:
http://www.wrigleyvideo.com/videotut...premiere60.htm
Although this is for P6 the same effects should still be in Pro.
Ed Smith
Hampshire, UK
Ed Smith is offline
Old May 27th, 2004, 08:17 AM   #518
Thanks! Exactly what I needed.
Anita Hu is offline
Old May 27th, 2004, 05:28 PM   #519
How do you sync audio in post?
If one uses an MD recorder to record audio, how easy/difficult is it to sync with the video in post? Generally speaking, how is it done in PPro?
Ming Dong is offline
Old May 27th, 2004, 07:05 PM   #520
Synching is usually done visually with a slate or some other visual clue (Light flash, hand clap, tapping the mike on camera...)
Richard Alvarez is offline
Old May 28th, 2004, 09:42 AM   #521
Ahhh. So that is the purpose of those "clap" boards used in filming. :)
What if you leave the MD recorder on for the whole session, for instance a 60min concert, but stop/restart video recording during the session?
Old May 28th, 2004, 09:53 AM   #522
...then you will have to trim your audio to match the video...
...what i do in circumstances like that is look for something that makes sound on the video. like looking at a drummer hit a cymbal or someone drop something or maybe even being able to read someone's lips. then, i find it in the audio and line it up. i have never used the clap boards as it hasn't seemed appropriate to have the band wait for me to clap my board...hope that helps...
I understand everything about nothing.
J. Clayton Stansberry is offline
Old May 28th, 2004, 12:14 PM   #523
Hi Matt,
I have never used the 5.1 features in pro but a drop down menu should appear below the fader for the channel. Then select the mix from the list. The box that allows you to set your speakers will then appear above the audio fader in that channel.
Hope that makes sense...
Ed Smith
Hampshire, UK
Ed Smith is offline
Old May 28th, 2004, 03:01 PM   #524
Main concept codec and Premiere 6.5 on WinXP
Hello
How to force premiere 6.5 to use main concept codec instead of microsoft?
I found some manual but it refers to win 2000 where some system operation needed (turning off one of system features) differs from xp.
Milosz Krzyzaniak is offline
Old May 29th, 2004, 06:11 AM   #525
Do you mean the MC stand-alone encoder? The MPEG decoder (to make DVDs) is supported and comes up when you export to Adobe MPEG Encoder.
I don't think the Main Concept stand-alone can be used directly from Premiere, but I may be wrong.
Ned Hamilton is offline
