Adobe Premiere & Premiere Pro discussions from 2004 - Page 36 at DVinfo.net
Adobe Creative Suite
Old May 29th, 2004, 07:55 AM   #526
It is possible, but it needs a little work. Have a look at this site:
http://www.abcdv.com/article/articleview/10/1/79/
The MainConcept codec is very good. I use it with Avid, but if I need to work with Premiere on the same machine, I have to disable it. I've just never got around to following the advice on the above link ;-)
Robin
Robin Davies-Rollinson is offline
Old May 29th, 2004, 08:10 PM   #527
Editing problem
Hi fellas, I have a little question with capturing video. I capture using premier 6.5 and I have a GL2. I just noticed today that my avi file is not at 100% on full screen and it loses it's quality. Does anyone have any Idea if I could capture a better image somehow? Can I tweak the options?
Thank you
Dmitry Yun is offline
Old May 29th, 2004, 10:33 PM   #528
I have a Sager P4 (3.2 Ghz, 1GB RAM) with the neat 17x14 screen. Works exceptionally well with Premier 6.5 and lots of other apps. It's only drawback is the relatively small HD (60 gB - jeez, I can't believe I'm saying that it's "small"). An important feature to look for is built in firewire - you can always get a PCMCIA card solution, but the built in is really slick. Just plug the camera in and go....
So I do a lot of editing on this machine and then download the files to a bigger, slower desktop with tons of harddrive space. If you don't have a bigger machine, the external drive that Shane describes is a good idea, although I would try for a firewire drive if at all possible.
The only big drawback of the laptop compared to a desktop machine is the lack of a dual headed video card. I've come to love the dual monitor setup on my desktop. Since Premiere has a rather cluttered interface, the extra visual real estate makes workflow smoother.
And, as Shane has mentioned, high end laptops are still quite a bit more expensive than an equivelently functional desktop.
Can't have everything....
Roger Golub is offline
Old May 29th, 2004, 11:19 PM   #529
I don't think you 'need' to go particularly high end these days - 2.4/512 would probably be fine. The big internal laptop hard disks are expensive compared to 120 gig desktop drives. You can buy one of those desktop drives and stick it into a 3 1/2 inch external firewire unit. There are even fancy units that will do RAID (more than one drive) but I don't know the details on that.
David Hargreaves is offline
Old May 29th, 2004, 11:42 PM   #530
AVI is just a "wrapper" for digital video. You need to check your codec. As I recall, the Microsoft DV codec is lossless, i.e. no compression (other than that which is already done as part of the DV25 standard).
Paul Tauger is offline
Old May 30th, 2004, 08:15 AM   #531
Dmitry
Interlaced video typically looks somewhat poor on a computer monitor. Try sending the video from the Premiere timeline back out to a television and see how it looks on the TV.
John Britt is offline
Old May 30th, 2004, 09:12 AM   #532
thanks guys
Old May 30th, 2004, 09:20 AM   #533
RED Code Chef
I'm not fully understanding your "my avi file is not at 100% on
full screen" part?
How are you determining it is of less quality than... compared to
what?
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old May 30th, 2004, 07:43 PM   #534
Is Wrigley alone?
I have been enjoying the tutorials put together by WRIGLEY VIDEO PRODUCTIONS. Are there other free sites offering similar tutorials out there?
Mike Mellis is offline
Old May 31st, 2004, 01:45 PM   #535
Wrigley is the only one doing video tutorials for Premiere Pro. There are others doing Photoshop and After Effects.
The problem is that there is a serious cost to the bandwidth. The sites that offer unlimited bandwidth are not really telling the entire truth. So Curt Wrigley pays a lot of money monthly. I think he uses around 15G of bandwidth daily. That is huge.
Steven Gotz is offline
Old May 31st, 2004, 05:56 PM   #536
Well when I view my captured avi file in say WMP and I click full screen, I have a noticable loss in quality. But when I have it at 100% not at full screen mode it's as clear as ever. Is there a way I can make Premier Pro capture my avi file at "full screen size" rather than the default 100% that's about 1/4 of my screen's size.
Old May 31st, 2004, 06:03 PM   #537
Dmitry
DV resolution is 720x480. That's "full screen" for DV. Try to make it fill 1024x768 (or another monitor resolution) and it's going to have a loss in quality. Add to that what I said before about interlaced video looking worse on a computer monitor (it will look better in a smaller viewing window, though).
Interlaced DV is ultimately meant to be best viewed on a TV. It simply will not look as clear on a computer monitor.
Old June 1st, 2004, 07:50 AM   #538
I was looking at another thread and I found a file that converts 16:9 to a 4:3 with the bars. That helps me out a ton so I'm happy I think I'm gonna start filming (as long as I can get my script finished by next week.)
Kyle Kauss is offline
Old June 1st, 2004, 12:46 PM   #539
Hi Kyle,
Glad you managed to find a work around. Its a strange issue as it works for me... Anyway, good luck with your script, let us know how you get on.
All the best,
Ed Smith
Hampshire, UK
Good things come to those who wait
My Skiing web www.Frostytour.co.uk
For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors
Ed Smith is offline
Old June 1st, 2004, 03:02 PM   #540
I use a Toshiba P25 Satelitte notebook 2.8Ghz upgraded to 1meg RAM 80 Gig HD with the Maxtor 250Gig external firewire and the Firestore FS1.
I have Premiere Pro, After Effects 6, Audition, Particle Illusion and Boris Red
I used this setup to capture and edit video when I'm on the Seagram's Gin Live Tour.
26 cities in 38 days and this system has performed without a flaw.
I've done multi camera edits, effects, titling, composting all while traveling on a tour bus and I this system never crashed once.
Stephen Jackson
RoaDDoggZ productions
www.roaddoggz.com
Stephen Jackson is offline
