High Definition with Elphel model 333 camera - Page 51 at DVinfo.net
Go Back   DV Info Net > Special Interest Areas > Alternative Imaging Methods > Apertus: Open Source Cinema Project
Old July 29th, 2007, 09:58 AM   #751
It seems Hanvision's only working with Foveon sensors now. I just mailed them. Let's see what they can offer.
Any other Altasens distributor? You're right, maybe we can get small amounts that way.
Jose A. Garcia is offline
Old July 29th, 2007, 10:54 AM   #752
I think Toshiba has an camera, but slow and costly, have link on my technical thread. But wait, they have announced they are working on things, so it should turn up further into the year. I think there was another company linked from the Foveon, or the hanvision site before (complicated to find some links on these sites).
Wayne Morellini is offline
Old August 1st, 2007, 07:49 AM   #753
Reading the Red digital cinema site ( http://www.red.com/index.php ) I've found that people that have tryed it is amazed by the dynamic range of the camera that is 66dB so I've downloaded (once again) the data sheet of the micron 5mp sensor ( http://download.micron.com/pdf/flyers/mt9p001.pdf ) and I found that elphel have 70dB cool ...isn't it!?!
Matteo Pozzi is offline
Old August 1st, 2007, 08:23 AM   #754
Hi Mateo,
If you take a look at the New DIY HD Cinema Camera thread you can download clips captured with that sensor.
Old August 3rd, 2007, 11:23 AM   #755
I am very dubious of dynamic range claims. There is an document I saw an long time ago over at Dalsa, I think, that explains how these figures are not as good as they make out.
I used to think this dynamic range was basically reflective of the bit depth than actually latitude, but people seem to be saying differently. But all the time the db matches bit depth. Another thing is, what binning is the max being measured. I suppose somebody like Andrey would be able to clarify these things, what are they really meaning here by 70db. The 5mp shot I saw looked no better than an Sanyo HD1 camera in latitude, an lot of burn out. Of course, we expect better from binning.
With latitude I tend to look at well capacity (ceiling), noise factors (floor), QE/fillfactor, and any latitude extensions schemes first, to get an idea of what it might turn out.
Old August 3rd, 2007, 02:19 PM   #756
I think you're right Wayne I've seen a document that combine bit depth only to dB latitude not othe spec of the sensor ! but I hope that the final result will be better than a Sanyo ....reading the Jose's thread I've found that rolling shutter issue is minimal if the sensor is set to 96MHz but looking at the image on the elphel wiki in particular this one: http://wiki.elphel.com/index.php?tit...sample_01.jpeg you can notice the problem looking at every car ...hope that the sensor was set at a lower refrash rate ?48MHz?
Old August 4th, 2007, 08:37 AM   #757
Yeah, those cars do look more sporty than usual, but not too bad.
The larger version has more definition in the highlight detail.
That is more the contrast I would be looking for (you can brighten and stretch post color correction) not to much detail lost in the shadows, and not too much lost in the top end. Problem is that sun is shining through an cloud, so you have an big density filter over it. Look at the blue car down the bottom and you can see it's reflection. Car looks nice, can see inside of it and out, under somewhat and ther disk break mechanism, natural enough. Something bright/reflective next to the drain is burnt out. So it is probably dealing with half the stops of what it seems to be, then again, what aperture was used. Looks better than the 3 micron sensor from an few years back, but I will take an guess, is it 8 stops?
There is still the lowish SN, but if it could deal with harsh tropical midday, mid summer sun like that, it would be great to use.
Old August 17th, 2007, 03:36 PM   #758
My presentation at Google
http://video.google.com/videoplay?do...arch&plindex=0
That was (and still is) keeping me really busy
Andrey Filippov is offline
Old August 18th, 2007, 05:20 AM   #759
THE camera...
Thanks for posting that Link Andrey!
It was real cool to see and hear the guy who made elphel! :)
Is there any news on internal camera harddrive support? Just curious!!
//O.
Odd Nydren is offline
Old August 18th, 2007, 09:47 AM   #760
//O.
We just received some (factory built) 10349 boards while in California but the first one has some hardware problems I could not resolve while in a trip. I do not think it is serious as the prototypes worked. Actually our developers have 2 prototype hard boards with hard drive for several months, so some software is already developed.
Old August 19th, 2007, 09:07 AM   #761
Andrey, Micron sensor MT9P401I12STC can be used ?
Product Flyer PDF
Serge Victorovich is offline
Old August 19th, 2007, 07:55 PM   #762
Probably yes, but from the brief look over the "Product Flyer" I do not see differences from the MT9P001 we are using now. Maybe they have some bug fixes (we noticed in MT9P001)
Old August 21st, 2007, 08:09 AM   #763
Price wil be the same around $150-200 in volume?
This sensor is only one marked as HD and for HD camcorder.
Old August 21st, 2007, 01:45 PM   #764
ah! Interesting!!
I really look forward to hear any details on their progress!!
thanks for the update!
//O.
Old August 25th, 2007, 09:05 AM   #765
hey everyone!
i've just spent the last 4 hours reading all i can about this camera. it sounds awesome!!
Andrey, when do you think the hard drive/CF module will be ready?
and will the camera still need a computer to be setup and adjusted, or will it have a control module as well?
if you're planning on separating it from a computer entirely, will there be a video-out of some sort?
thanks
patrick
Patrick Jennings is offline
  You are here: DV Info Net > Special Interest Areas > Alternative Imaging Methods > Apertus: Open Source Cinema Project
