24p questions - Page 29 at DVinfo.net
Old February 3rd, 2006, 09:44 AM   #421
Oh, and...
When working in 24p (basic), you are actually editing in 29.97fps. Your 30p graphis should look fine in this timeline. You can output from aftereffects in 29.97 too, instead of 30fps, if you don't like the look.
Joe Winchester is offline   Reply With Quote
Old February 3rd, 2006, 11:30 AM   #422
Originally Posted by Jonathan Reynolds
Is there a way to add 3:2 pull down to 24p renders coming out of after effects?
Yes it's one of the options in the render queue.
Should I just go ahead and shoot 24pa, edit in 24p timeline and do all my graphics in 24p then out-put to a 24p DVD? This sounds the best, but I have never done it and this is a one time event (kind of. It would be not as ideal to do it some other time), and I don't want to end up with footage that’s jerky, strobey etc...
24PA would be best as it keeps all your footage 24p and allows your DVD to add 3:2 pull down on output to standard TV. It also means you're working with 6 less frames per second which means faster renders.
If you don't want to use this project to learn about it, then I would say shoot standard 24P which lays 3:2 pull down with it to the tape, and do your graphics 24P and render with pull down, editing in a 29.97 timeline.
Or... shoot 30P and do your graphics in 30P, editing in a standard timeline. It'll look about the same with no need to interlace or add pull down.
Just my 2 cents.
To live a creative life, we must first lose our fear of being wrong.
- Joseph Chilton Pearce
Paul Cuoco is offline   Reply With Quote
Old February 6th, 2006, 01:45 AM   #423
Thanks for the advice guys, I went ahead and shot in 24pa. This camera is really neat. Although unfortunately I still have to adjust to the settings on the camera. I may have had the white balance off or something, the colors look off, too sturated or something, but its useable. The whole setup was rushed as the stage had to be used for an event. I used cine gamma, maybe cine colors too. Gain was at 0, and shutter was at 1/48. Iris was some where around F2ish.
Here is a screen capture:
http://www.geocities.com/unklejman/angieLaurye.jpg
Jonathan Reynolds is offline   Reply With Quote
Old February 23rd, 2006, 12:55 AM   #424
XL2 24P VS 30P there is interlacing on 24p
how come when you capture video at 24p (either in 2:3 or 2:3:3:2) you see mass interlaceing crap, when you look at the raw video on your pc. but if you look at the 30p footage there is none, its clean
Dave Morgan is offline   Reply With Quote
Old February 23rd, 2006, 01:28 AM   #425
The 24p is still wrapped in the 60i stream... you need remove the pulldown frames when you capture 2:3:3:2. In 2:3 you will have the 24P inside the 60i. In 30P there are no extra frames, hence no interlace artifacts.
ash =o)
Ash Greyson is offline   Reply With Quote
Old February 27th, 2006, 02:27 PM   #426
ash =o)
so...is there a reason to use the 23:32 or 2:3 pulldown at all? Or should I just use the 30P? I don't quite understand the whole deal with 23:32 or 2:3 pulldown and what it does for me.
If I shoot in 2:3 Pulldown (which I have been doing for my last three features) then I edit the footage for output via idvd will there be a difference if I would instead shoot in 30P? What is the best option to get the best "film like" look?
Eugene Weaver is offline   Reply With Quote
Old February 27th, 2006, 03:38 PM   #427
When you view raw footage on a monitor, you will get the interlacing look, but once you render it out and onto a DVD, it should be fine. You should also be able to test this by displaying the footage on a TV screen. Just make sure your timeline (24p, 30p )and size (4:3 or 16:9) is correct, anamorphic is checked for 16:9, 2:3:3:2 pulldown removal is checked (if used) during capture. My understanding is that it's best to use 2:3:3:2 removal, especially if you desire to eventually output to film. There have been posts in the past that cover 2:3:3:2 more in depth.
Geoff Voorhees is offline   Reply With Quote
Old February 27th, 2006, 03:48 PM   #428
24p Advanced (2:3:3:2 pulldown) is more efficient for dvd-end applications as well, and really should be the preferred cadence if your NLE can handle it.
Jeff McElroy is offline   Reply With Quote
Old February 27th, 2006, 10:00 PM   #429
Matter of preference but for DVD I prefer 30P. Smoother motion but still progressive.
ash =o)
Old February 28th, 2006, 09:43 AM   #430
The whole 24p thing has been the source of much disagreement.
in 24p 2:3 you get a 24p look that is useable in 60i timeline. Yes there are interlaced frames, but when viewed on a TV it plays back looking like 24p. Jsut don't pause!@ 24p 2:3:3:2 is if you are planning on exporting to a 24p DVD (progressive!!!) or back to film (a transfer to 16 or 35). The 2:3:3:2 cadence can be removed with your NLE to give a TRUE 24 fps. The 24p 2:3 cannot (wihtout some loss of frames). However, I usually shoot 2:3 cause I know I am not going back out to film or progressive DVD so the choice is yours. 30p looks too fake to me (videoish) and, if you did want to do out to film, you pretty much can't.
Matthew Nayman is offline   Reply With Quote
Old February 28th, 2006, 01:23 PM   #431
Matter of taste, 30p for action is recommended by myself and others. 30P does limit a film out and a Pal conversion. IMHO the film out thing comes up WAY too often for something that is, at best, a gigantic longshot.
ash =o)
Old March 3rd, 2006, 12:46 AM   #432
Delusions of Grandeur
It's funny how much time people waste worrying about filmout. How many shorts or features shot on the XLs have ever been transferred to film? I know of 2. It's like the buzz surrounding HDV. I mean it's great that the sub 10G market is heading that direction but right now what's the deliverable? HDCam? Film? HDDVD will probably answer these questions but those jerks are still fighting over media/codecs. And another thing........Oh sorry about that I'm ranting. I like 30p it's nice. To me its looks more like film than 24p because of it's smoother cadence. The first time I saw 24p (on the canon) it looked like I was capturing. Once you get used to it it disappears but you never never get a second chance to make a first impression. Good Luck, Jason.
Jason Varner is offline   Reply With Quote
Old March 6th, 2006, 10:38 PM   #433
ill just stick with 30p
im used to it from my gl2, and its not like it looks bad.
Old March 7th, 2006, 06:55 AM   #434
If you shoot a few things in 24p 2:3 (not 2:3:3:2) and burn them to a DVD and watch them on a TV (not a 24p DVD, just regualr 29.97 DVD), you will see how great 24p looks. On a moniter (expecially LCD) it can look strobey and boring, but on a CRT it looks great.
Old April 6th, 2006, 01:53 PM   #435
Recording 24p footage of a TV screen
To All:
I'm shooting a short film this weekend and there are a few shots that require me to point the camera at a TV playing video. I'm shooting the rest of the film 24p w/ a 1/48 shutter - will this cause flickering on the screen?
Please offer suggestions.
Eric
Eric Powell is offline   Reply
