NLE Mac / Final Cut questions from 2004 - Page 64 at DVinfo.net
Final Cut Suite
Old July 13th, 2004, 02:57 PM   #946
Quick Storage Question
Hello, right now i'm torn between a 2nd Serial ATA drive or external firewire800. I'm leaning more towards the firewire800 due to portability, but my main concern is that does it move data quick enough where I can edit dv projects off that drive without moving them over to my primary Serial ATA drive?
-Steve LaClair
http://www.skateperception.com/
Steve LaClair is offline   Reply With Quote
Old July 13th, 2004, 03:49 PM   #947
Word going around is that an external 7200RPM Firewire 800 drive will give you equivalent to an internal ATA/133. This site has some stats:
http://barefeats.com/fire37b.html
Firewire 800 was getting sustained read/writes of 54/50 megabytes per second. Manufacturer mattered very little.
Mark Sloan is offline   Reply With Quote
Old July 13th, 2004, 03:53 PM   #948
Was your clip captured in 12 bit audio? That might be the cause. Check the clip's audio profile (bits, hz) and see if it matches your setup.
Old July 13th, 2004, 04:21 PM   #949
No. 16 bit
It is in 16 bit. For some reason when I capture long clips, it beeps loudly, like it needs to be rendered.
Tyler Spiers is offline   Reply With Quote
Old July 13th, 2004, 04:21 PM   #950
Warden
Is there a red bar in the timeline? Render you audio.
Jeff Donald
Carpe Diem
Old July 13th, 2004, 04:41 PM   #951
Erik Olsen
Posts: n/a
Steve,
A FireWire800 drive would be more than fast enough to handle DV editing.
I use a FireWire 400 drive and haven't had any problems.
Old July 13th, 2004, 05:58 PM   #952
Yes, the beeping is definitely telling you that audio needs to be rendered, but I can't see how that is related to the length of the clip. I captured a full hour several times and never ran into that.
The only thing I can think of is the capture settings are set for something other than two channels of 48k hz, 16 bit sound and this is causing a problem.
Of course you can always throw away your preferences and see if it persists.
Mike.
Mike Hanlon is offline   Reply With Quote
Old July 13th, 2004, 06:00 PM   #953
Warden
It may have to do what amount of ram and other system parameters.
Jeff Donald
Carpe Diem
Old July 13th, 2004, 08:06 PM   #954
Thanks for all the quick replies guys! I'll definitely be picking up a Lacie drive this week.
-Steve LaClair
Old July 14th, 2004, 03:22 PM   #955
New sancubes shared fw800 arrays...
http://www.sancube.com/sc800specs.htm
pretty sweet... I have 2 of the older ones fs... but these new ones work in OSX.
Josh Brusin is offline   Reply With Quote
Old July 14th, 2004, 09:36 PM   #956
I too am looking to get either an internal SATA drive 250GB or a Lacie external 250GB drive.
I'm leaning towards the SATA internal, cuz i would not need to share a drive between computers or need the drive to be mobile.
The SATA is faster and more reliable?
Sony VX-1000
G5 1.8 dual
91 Turbo MR2
Ray Echevers is offline   Reply With Quote
Old July 15th, 2004, 08:27 AM   #957
Mac and 24p
What do you use to edit 24p on your macs? What are the options of editing software for macs?
Thanks.
Chet Hardin is offline   Reply With Quote
Old July 15th, 2004, 09:11 AM   #958
Warden
FCP HD and the included Cinema Tools. That's all you'll need.
Jeff Donald
Carpe Diem
Old July 15th, 2004, 09:22 AM   #959
RED Problem Solver
Final Cut Pro works great for 24p editing.
Graeme
Graeme Nattress is offline   Reply With Quote
Old July 15th, 2004, 11:26 AM   #960
Newb question : what software can do this?
http://uk.download.yahoo.com/ne/fu/a...s/formula1.wmv
I'm sort of a car enthusiast and I thought this clip was pretty funny! Does anyone know of a software that can do this? I'm new at this video editing thing. Thanks.
"My lug nuts have more torque than your Civic". *winks*
Joe Calalang is offline   Reply
