Remote Lens Control on the PDW-EX1 - Page 12 at DVinfo.net
Old November 19th, 2008, 07:37 AM   #166
No it doesn't.
Old November 19th, 2008, 12:28 PM   #167
Originally Posted by Vincent Oliver View Post
Doe the EX3 have a Lanc input port? I can't find this in the specs. or the PDF manual.
No the interface protocol is very different. If it was LANC we would most likely be using the Manfrotto 523PRO control arm which is way nicer than the slimmed down 521EX. Hopefully Manfrotto is working on an equivalent to the 523PRO for the EX series.
EDIT:
The 521EX does relatively controlled zooming. There is a little thumbwheel that allows you to dial up the zoom speed which is in some ways nicer than the 523PRO but it lacks the all important quick "auto focus" button.
Old November 19th, 2008, 12:36 PM   #168
Afaik, it's quite possible that Manfrotto "handle" version will be available for the EX cameras some day, but the Push Auto Focus will definitely not - as the EX zoom remote controller protocol doesn't provide this functionality.
Old November 19th, 2008, 12:59 PM   #169
libec told me today that the cable extension will be on sell within 2 weeks for £56.00
plus tax
regards Brian
Brian Rigler is offline   Reply With Quote
Old November 19th, 2008, 01:56 PM   #170
Is it possible to control focus with remote?
Tuomas Sebastien is offline   Reply With Quote
Old November 23rd, 2008, 10:17 PM   #171
Well after reading this whole thread im still not sure which remote i want.
Its a toss up between the Bebob Zoe Ex and the VariZoom VZ Rock EX.
Now i currently have a Varizoom Rock for my HVX and love it.
Im currently learning more towards the Varizoom as im use to the pressure sensitive rocker and its also cheaper (exchange rate is currently awful)
Am i making a big mistake going with the Varizoom? is the speed control dial on the Bebob worth the extra money?
It sounded like the original Varizooms on the market had some issues but then were later fixed..
Joe Lawry is offline   Reply With Quote
Old November 25th, 2008, 03:16 PM   #172
Anyone knows if it is possible, even theorically, to control focus like controlling the zoom with remote lens control?
Old November 26th, 2008, 08:53 AM   #173
not for EX1, EX3 only
Old November 26th, 2008, 09:14 AM   #174
Tuomas I have been researching this since I need this options to go from EX1 to EX3. And yes you can control focus with optional Fujinon and Canon lens but you have to buy their controllers that attach to their lens. You cannot remotely control focus with the stock EX3 lens. But then again why not buy the EX1 if you are not going to use better glass on the EX3?
Paul Cronin
www.paulcroninstudios.com
Old November 26th, 2008, 02:19 PM   #175
Tuomas I found this for the stock lens to control focus by remote.
VariZoom Lens Controls - Zoom &amp Focus Controls, Camera Stabilizers & Supports, Batteries, Monitor Kits
Paul Cronin
Old November 26th, 2008, 02:31 PM   #176
I don't quite understand this.
EX1 does electronically control focus in auto-focus mode.
So what could possibly prevent from doing so remotely as well?
Alex Raskin is offline   Reply With Quote
Old November 26th, 2008, 02:37 PM   #177
Just the fact that no one has built the control for the EX1. Sony must have their reasons.
Paul Cronin
Old February 27th, 2009, 02:36 PM   #178
Remote focus and zoom
Anybody know if these focus controllers would be a good solution to using the EX 1 on a jib?
I think the zoom control would work but not sure about the cable version.
The Zoe zoom control would work provided I can get a long enough cable to the camera.
16x9 | Distributor of Film & Digital Products
Also this wireless solution from varizoom....does this even work on the EX1?
VariZoom Lens Controls, monitors, Camera Stabilizers & Supports, Batteries, Monitor Kits Phone: 512-219-7722
thanks for the feedback in advance
Steve
Steve Minnick is offline   Reply With Quote
Old April 13th, 2009, 07:21 AM   #179
Variable speed control
I've read several comments about some of the remote zoom controllers having a variable speed control.
Is this redundant to the varible speed control on the camera? do you get anything extra out of the speed control on the external zoom controller?
Ed Kukla is offline   Reply With Quote
Old April 13th, 2009, 08:33 AM   #180
Sponsor: VariZoom
EX Zoom
Yes it is redundant. The extra is just the benefits of remote control and maybe a little better control over speed because of ergonomics. The slowest speed will still be the same and the fastest speeds will vary little if at all.
Thomas McKay is offline   Reply
