Vegas Video discussions from 2004 (Q3Q4) - Page 23 at DVinfo.net
Old July 28th, 2004, 08:18 PM   #331
Sponsor: JET DV
I believe Scenarist requires an elementary stream. You would need to check the "elementary stream" checkbox when encoding the MPEG2 file.
Edward Troxel is offline
Old July 28th, 2004, 08:21 PM   #332
Sponsor: JET DV
The undersample rate allows you to simulate a lower framerate. Should not be needed for slowmotion, though.
Old July 28th, 2004, 08:46 PM   #333
Charlie- move the footage and Veg files to the IOMEGA drive and bring it over. I'll hook it up and see if I can't figure something out. Maybe thursday or friday night. Call me and let me know.
Glen Elliott is offline
Old July 28th, 2004, 11:17 PM   #334
Adi, why don't you simply give DVA the avi file without rendering to mpeg in Vegas?
Prepare and burn should work fine in DVA and you'll have the mpeg file for future copies. This way you are also flexible to adjust the bitrate. If you give Architect too big mpeg file it might reencode.
Bogdan Vaglarov is offline
Old July 28th, 2004, 11:30 PM   #335
I will be able to see later this week If I have the same trouble and check back in, I wish i wasnt so busy I would try it tonight.
I am not sure I ever used 120 files (are you talking transitions, music, filters and such or just mT2s?) even for a 1 hour + wedding film but I will be sure to keep track when I finish
Mark Paschke is offline
Old July 29th, 2004, 01:18 AM   #336
edward, you were on the money!!! i checked "elementary stream", sent a sample mpeg-2 to the studio and now scenarist recognizes the file. thanks!!!
now, i can check to see if my problem is software based or not.
thanks again!
Adi Head is offline
Old July 29th, 2004, 07:14 AM   #337
Sponsor: JET DV
DVDA 2 will also recognize elementary streams. DVDA 1 would not. So it is possible that you could simply use elementary streams for both.
Old July 29th, 2004, 08:29 AM   #338
Hi Mark.
No transitions. Not sound yet just clips. No color corrections or any sort of filters. I can imagine what is going to happen with all this stuff. By the way my computer is now slouch ether. Pentium 4, 3.4. Raid 2 HD Western Digital Raptor 74 gig each. 2 gig 2 channels ram. Radeon 9800 Pro. I think it’s limitation of Vegas. But i would be appreciated for any type of help and suggestion. Thanks.
MikeM1965
Michael Mirochnik is offline
Old July 29th, 2004, 08:59 AM   #339
Images: 10
Much more RAM is needed when processing HD, else the system spends all its time paging data into and out of the pagefile. 2 Gigs is the minimum recommended!
Bill Ravens is offline
Old July 29th, 2004, 07:07 PM   #340
wowsers, I am in trouble to start with, I am running 1 gig Ram with almost the same CPU as Michael ( with a Abit IC7 Max3 motherboard, 74 gig Raid Rapters, crappy ole GeForce 5200 and Sound Audigy) , with little troubles upto 20 minutes on the timeline now with multiple transitions and even some color correction experimentation.
whats the largest RAM you can buy? I guess Im gonna need more when its render time
Old July 30th, 2004, 01:41 PM   #341
I have solved my problem; this is not the easiest way, but its work for me. I use Vegas foe smaller number of clips 15-20, I do everything what is necessary, composing, color correction etc. Then I render them in transport stream, and combine in MPEG editor, I forgot the name, which came with JVC. This program handle transport files very well. But still maybe buying Aspect HD not a bad solution either.
MikeM1965
Old July 31st, 2004, 01:45 AM   #342
Mark,
How do I manually change .mpg to .m2t?
Old July 31st, 2004, 03:36 PM   #343
after you cut does vegas automatically auto-crossfade both clips?
it's getting quite annoying. after time i would highlight a section of a clip i want to cut vegas crossfades the end result. how do i turn this off?
bow wow wow
Yi Fong Yu is offline
Old July 31st, 2004, 04:23 PM   #344
Turn the auto-crossfade on/off by hitting ctrl+shift+X.
There is also a button for it - usually at the top - looks kind of like bunny ears (or an "X")
peace
jes
Jesse Rosten is offline
Old July 31st, 2004, 05:54 PM   #345
Need your workflow
Could you help me, telling me what workflow do you use in Vegas?
Gustavo Nardelli is offline
