Adobe Premiere & Premiere Pro discussions from 2005 - Page 49 at DVinfo.net
Adobe Creative Suite
Old April 20th, 2005, 11:27 PM   #721
I bought Premiere Pro recently too, was using Premiere 6.5
What a difference! It's way better... Check out the 'Attend the world Premiere' in this forum. There's loads of useful info there.
Do or do not, there is no try.
Dave Ferdinand is offline
Old April 22nd, 2005, 07:45 AM   #722
So whats teh go with Axio.. ??
did matrox show off a working unit at NAB??
Im just curious coz it seems (as far as spec is concerned) to be the bees knees.. and the fact that its only a PremPro HW unit makes me ask this question here..
being that its supposed to be the replacement for the DigiSuite, im hoping that $$ wise its not as ridiculous..
Obviously we have to wait and see, but what r ur thoughts on this??
Peter Jefferson is offline
Old April 22nd, 2005, 09:10 AM   #723
Auto Color flicker....what the flicker is going on?
Hello editing folks!
I'm just exploring PPro's more "exotic" features (or the ones I’ve always looked at and scratched my head), and I’m having problems with some of the “Auto” correction features in the "Adjust" video effects menu. For example, if I apply the default “Auto Color” video effect to my clip, the rendered version will often appear to “flicker” (this seems to happen even if I apply “flicker removal” under field options). It appears as if the color correction is different for each frame of the clip, producing slightly different color hues from one frame to the next (?). This same phenomena occurs with some of the other video correction effects as well. Has anyone experienced this before? Any advice? suggestions?
Cheers!
Andrew Stone
A. Stone is offline
Old April 22nd, 2005, 11:40 AM   #724
Hi Peter,
The Axio does look like a really cool HD/ SD solution. They have been promising it for quite a while now... And you know what I think they are pretty close to releasing it fully. Probably expect something around May/ June (Possibly).
They have been showing it at shows throughout the past year...
From my understanding, if you are a previous digisuite user, you'll get quite a good discount.
I’ve seen it working and it looks pretty decent.
Cheers,
Ed Smith
Hampshire, UK
Good things come to those who wait
My Skiing web www.Frostytour.co.uk
For quick answers Search dvinfo.net | The best in the business: dvinfo.net Sponsors
Ed Smith is offline
Old April 22nd, 2005, 03:20 PM   #725
Andrew Stone
I am having the same problem with auto-color. I am trying to use it to correct a long video where I didn't white balance properly and I had colored gels on my lights. I can't get the rendered video to stop flickering, even when I changed some of the settings. Seems like auto-color in Premiere isn't going to work for me :-(
Jim Gunn is offline
Old April 22nd, 2005, 04:26 PM   #726
Images: 32
Sounds like it might be a problem with the method being used rather than Premiere. I get the same flickering with the auto level plug-in Vegas (click here). See the video with "changing lighting conditions" for the most severe flickering.
"Ultimately, the most extraordinary thing, in a frame, is a human being." - Martin Scorsese
Michael Wisniewski is offline
Old April 23rd, 2005, 06:21 AM   #727
By any chance were you guys shooting 24pN (2:3) video? There's a known issue with rendered "superwhite" areas, eg pixels with birghtness beyond NTSC standards...maybe this is related?
http://www.dvinfo.net/conf/showthread.php?t=37100
Pete Bauer
Pete Bauer is offline
Old April 23rd, 2005, 08:32 AM   #728
Nope...I shot Sp DV at 60i with the Sony Z1
A. Stone is offline
Old April 23rd, 2005, 09:44 AM   #729
I filmed regular NTSC DV with a VX-2100. It seems that the auto-color works "ok" for 80% of the clip or so, but it flickers often during a clip for no discernable reason and especially when there is a zoom in or other large change in the picture, so that it thinks the color needs to be adjusted.
Jim Gunn is offline
Old April 23rd, 2005, 02:38 PM   #730
HDV Preview with premiere?
hello all...
Just wondering if there was a way to preview my HDV Video on a computer monitor fullscreen off of premiere pro. A little info on my pc, I have the Ge-force fx-5200 128mb video AGP card, with dual monitor outputs. I plan on using a crt monitor to preview, but is there a way to set it up in premiere to preview my video out on a second monitor? will a CRT support it well enough? Any input would be appreciated. Thanks Much
Carlos Rodriguez III
Carlos Rodriguez is offline
Old April 23rd, 2005, 05:52 PM   #731
Doing it is easy enough, but is it a valid option? Does it provide the same information as an HD monitor? No. It doesn't.
But it can be done. One of the SP2 functions is to allow a second monitor to play the overlay full screen.
It goes something like this for a GeForce I believe:
1. In Windows Display Properties Click on the ‘Settings’ Tab
2. Select the second monitor in the ‘Display’ drop down menu
3. Be sure that the check box “Extend My Windows Desktop onto This Monitor”
is CHECKED.
4. Click on the ‘Advanced’ button to view the nVidia Card
5. Click on the Tab with the nVidia Logo and the model name/number of the card.
6. In the side menu that pops out select ‘Full Screen Video’
7. In the ‘Full Screen Device’ drop down menu, select ‘Auto-Select’
8. Apply the settings
Steven Gotz
http://www.stevengotz.com
Steven Gotz is offline
Old April 23rd, 2005, 09:52 PM   #732
Hi Steven, can you say more about why this does not provide the same information as a HD monitor - and are there ways to improve on that situation still using a PC CRT for video. I would be interested in any references to read on CRT color vs HDV / HD TV color.
On a related theme I have thought about using an ordinary SD TV to monitor color adjustments etc - is that a workable approach - not sure one can even output the right signal if Premiere is working with HD but the fundamental idea is 'use SD TV for color adjustment, use PC CRT for everything else'. Any thoughts (maybe very stupid, like many others I am still working into the ins and outs of HD editing on a budget that is not limitless).
Andrew Hall
http://www.ps-scripts.com/
Intel Core2 Quad Q6600 2.4GHz, 2x 2Gb Ram, ATI Radeon HD 3850
Andrew J Hall is offline
Old April 23rd, 2005, 10:41 PM   #733
Sorry Andrew, but I am not an expert in this area. I know that the way a PC screen displays colors and the way a television displays colors are different. I merely trust the people who told me that I needed a monitor to color correct, not a PC screen. I always thought that there should be something that software could do to deal with this, but apparently not. The gamma being different is readily apparent though.
Worse yet, I have to trust them when they discuss color spaces. With SD and HD being different for reasons beyond my understanding.
Not that I couldn't learn I suppose, just that I trust the folks who explained it to me and have never needed to dig in.
I have found that my LCD monitor is extremely close to my LCD HDTV. Which is good enough for me because my stuff is shot and edited to be shown on that TV, or televisions pretty much just like it. If my stuff was designed to be broadcast, my guess is that I would be in for a rude shock.
So if anyone with the right answers happens to be hanging around, a short explanation of why Andrew needs, or doesn't need, an HD monitor would be welcome.
Steven Gotz
Old April 24th, 2005, 12:12 AM   #734
hd previewing
I just posted a new thread on this subject. Like andrew my budget has limitations. I am curious to know the differences as well.
Lewis
Lewis Lehman is offline
Old April 24th, 2005, 12:30 AM   #735
Hmmm.... thanks for the tips guys, I'll give it a try. The reason I thought I would have better luck with a second CRT monitor is because I figured there would be no way to get the hdv signal out through the firewire realtime. Or is there? I have the JVC 30k deck hooked up through firewire to my pc, and that has component outputs for and hd monitor, would that work out through the firewire realtime? I also have a dazzle dv hollywood bridge i was considering connecting through firewire to get a picture on a television, but that only has a composite out. I figured that wouldn't work.
So, if I go through the advanced settings you mentioned before, my premiere timeline will preview fullscreen on the second crt?
Thanks again!
