Red problem ! - Page 7 at DVinfo.net
Old April 5th, 2008, 03:19 AM   #91
In Adam Wilt's test he saw this on both the F-23 and the Ex-1.
Can I put the 486 over my Ex-1 lens then add a 35mm adapter over it, or do I always want the 486 to be on the front?
I second that question!
Also, I believe Sean is right - we should all complain to Sony about the red problem; realy don't see a reason for $200 expenditure and hassle with additional filter just to get right colours from a CineAlta, "professional" camera...
Old April 5th, 2008, 07:55 AM   #92
Is my problem the same? My reds are too orange. When I put up my color bars my red bar is orange. I take a cherry red jacket and I can not get the color right unless I color correct. This turns my orange colors pink. I am getting much better reds with my Canon A1. What can I do?
Don Deignan
Don Deignan is offline   Reply With Quote
Old April 5th, 2008, 09:39 AM   #93
that sounds different. This problem is really only visible on black subjects with certain dyes in them that reflect IR light. Sounds like a processing problem, although I don't think it's related to this. It does seem like it is a processing problem, and we should start a new thread about it so as not to hijack this one.
-Sean
Sean Donnelly is offline   Reply With Quote
Old April 8th, 2008, 06:07 AM   #94
Originally Posted by Brian Carrell View Post
I have a 77mm B+W 486 IR Cut (blocking) filter, I can't remember who else makes them (at the time I was looking for this solution, all I could find in the States, was this filter by B+W, which I got from B&H)
http://www.bhphotovideo.com/c/produc...tal_UV_IR.html
I'm wondering if this is how this particular sensor reacts to differing wavelengths. As I did not encounter this with my Canon XHA1 or older Sony DV camcorders.
Outdoor use in San Diego, I can't see much noticeable difference. Outdoor use when I was up north closer to the Arctic in Canada, I really could see a difference, especially in Reds, Greens and Blacks. I manually white balanced and included a white/gray reference in the beginning of each shot, so I know the balance was correct. I also noticed a difference in this situation with my Canon HV20 as well as the PMW-EX1.
Then indoors under various types of indoor lighting I started noticing this effect as well by using and not using the filter, which varied under different types of lighting. Again this effect is stronger than with the Canon XHAI in the same setup.
I stumbled on a few German sites that discussed this type of filter and there were actually stronger ones mentioned, that I have been unable to find here, one was darker in color and reduced light by about 2-stops.
Maybe one of our more tech savvy engineer memebers can shed some more light on this. But this filter does help a lot with this camera's sensor, I'd still like to find even a stronger one. Of course I haven't shot in a red room or set yet.
Brian - or anyone else - does this filter fit under the EX1 hood? I would prefer it to the slimline version as I can attach things to the external thread if necessary. I know that the slimline version does fit.
Graeme
Graeme Fullick is offline   Reply With Quote
Old April 8th, 2008, 06:22 AM   #95
I ended up buying the B+W 489 instead of the 486 as the 486 did not work with 35mm adapters because it has to reflect the light back and it would be behind the adapter. The 489 absorbs it instead of reflecting it and it works great with the Mini35 for example.
Michael Maier is offline   Reply With Quote
Old April 8th, 2008, 06:30 AM   #96
Michael,
Does the 489 fit under the hood, and does it have a thread on the outside?
Graeme
Old April 8th, 2008, 11:38 AM   #97
Originally Posted by Graeme Fullick View Post
Michael,
If it fits under the hood I have no idea, as I haven't tried that yet. I always use a mattebox. But it does have a thread on the outside.
Old April 9th, 2008, 03:18 AM   #98
Do I understand it right, that you will need one such filter for each lense you're using with your 35mm adapter (if they are different filter thread size, of course)?
Old April 9th, 2008, 05:10 AM   #99
there is so many glass in a mini35 adapter , i doubt a filter would still be necessary.
imagine that you add , the lens, the gg screen, the condenser, the macro lens. and you still need to go through the camera lens.
Old April 9th, 2008, 05:23 AM   #100
And yet, even with the Letus and a 50mm Canon lense, the black clothes are still brownish when shot in artificial light.
Old April 9th, 2008, 07:08 AM   #101
IR passes through many things that visible light does not. The 1 1/2 stops of light loss from the mini35 doesn't really matter, this problem is seen with the RED camera when using heavy ND's like 1.5 and 1.8 (5 and 6 stops!). I used to shoot infrared ektrachrome, and I'd use an opaque filter which blocked all visible light and only transmitted infrared. As far as the 486 behind or in front of the adapter, I'm thinking it doesn't matter. First off, the 486 doesn't reflect the IR light outward like a mirror, it dissipates it between the layers of the filter coating. Also, even if it did reflect the light, why should that matter? The camera won't see it anyway, the filter still blocks it even if it's not traveling straight in. The amount of IR and wavelength we're talking about isn't like a heat lamp, so you won't melt your lens. Later this week I'm going to try a 486 with a mini 35 and cooke S4's. I'll keep everyone informed.
-Sean
Old April 9th, 2008, 07:53 AM   #102
That's why we buy matte boxes. They might seem expensive but compared to a set of screw on filters for every lens thread they start to become cheap.
Old April 11th, 2008, 10:34 AM   #103
The 486 filter does work to solve the problem, but it really shouldn't have to be there. I ran into a situation today where I needed the filter, but also a wide angle adapter. Even if I could find a filter in the approriate size, the wide angle doesn't have threads, and I can't put it behind since it mounts to the bayonet. In this case I wouldn't be able to do the shot. I spoke to someone named Lou at Sony support again today, to express my displeasure in the camera not performing as it should. He said he had heard of this earlier in the week from someone who saw it only in certain lighting conditions. He sounded genuinely concerned about the problem and said he would have the engineering team investigate at the beginning of next week. I referred him to this thread, but I think if we all call and complain maybe we can force Sony to step up and fix this. I don't like having to put extra glass in front of the lens.
-Sean
Old April 16th, 2008, 06:21 AM   #104
B&W 486 works fine, when you put it directly on the cameralens there is only a very very slight green coloring of the extreme corners when you zoom out all the way.
The Heliopan UV/IR cut filters give a greenish cast all over the frame and even more so in the corners when zoomed out.
Peter Brugman is offline   Reply With Quote
Old April 16th, 2008, 06:57 AM   #105
Peter, while the 486 does work fine and I haven't seen any green cast (unlike the 489) I still maintain that it shouldn't have to be there. This is a design problem. A lot of companies use a weaker IR filter to increase sensitivity, but just like they did with a batch of F23's, Sony used one that allows a couple of wavelengths to pass that shouldn't.
