NLE Mac / Final Cut questions from 2004 - Page 58 at DVinfo.net
Final Cut Suite
Old June 29th, 2004, 07:50 PM   #856
Audio While Capturing
Sorry for all the questions, I really am. This is my first few days on a mac/fcp and I want to get all my major gripes worked out so I can be happy. This is my last question for a while, I promise.
Ok when I have the capture window open it doesn't play any audio, but it captures it as normal. Is there anyway to get it to play the audio while you have the capture window open? Because I kind of need that.
Steve LaClair is offline   Reply With Quote
Old June 29th, 2004, 09:02 PM   #857
Re: Audio While Capturing
<<<-- Originally posted by Steve LaClair : Sorry for all the questions, I really am. This is my first few days on a mac/fcp and I want to get all my major gripes worked out so I can be happy. This is my last question for a while, I promise.
Ok when I have the capture window open it doesn't play any audio, but it captures it as normal. Is there anyway to get it to play the audio while you have the capture window open? Because I kind of need that. -->>>
You would need to plug in the audio rca inputs (white and red) from the camera to the computer.
Or you can do what I do, if you have a camera with a LCD screen that plays back the audio too, use it as your audio source.
Sony VX-1000
G5 1.8 dual
91 Turbo MR2
Ray Echevers is offline   Reply With Quote
Old June 29th, 2004, 09:20 PM   #858
Oh damn, I thought it was just something I was missing, Or could I even get the left and right stereo cables that turn into the headphone jack at the end and just shove them in the audio in jack. But thanks for letting me know I didn't screw anything up, I have a lcd on my vx2100 but I don't think i'm going to be using that much longer for capturing footage. But most one chips have lcd's anyways, so I'll be in good shape either way. Thanks.
Old June 29th, 2004, 09:30 PM   #859
Check out this thread. Your questions should be answered.
http://www.dvinfo.net/conf/showthread.php?s=&threadid=28215
Sony VX-1000
G5 1.8 dual
91 Turbo MR2
Old June 29th, 2004, 10:27 PM   #860
Retired DV Info Net Almunus
You can try using the "SMPTE-C" or "NTSC (1953)" profiles. Alternately, if you have access to a monitor color calibration system you'll want to create a custom profile for your monitor.
But, honestly, no matter what you do the color space on your Mac's monitor will not really match that of your video's true color space. So be cautious of attempting to make accurate color corrections if you need to do so.
Old June 29th, 2004, 10:31 PM   #861
THanks Ken, maybe i should consider a monitor. Is there an inexpensive monitor that you can recommend that can output from FCP firewire?
Joe Cirino is offline   Reply With Quote
Old June 29th, 2004, 11:36 PM   #862
No production monitors (that I know of) will take Firewire input. All will require an analog signal, such as a composite. That means you'll have to come out of a deck, your camera or some type of a/d converter.
There are many good production monitors. Browse through B&H's site. Sony is the gold standard, but JVC and Panasonic have very good units, too. A 13" is a good, economical size. 9" is just a bit small and generally a bit too low of resolution for desktop color work, in my experience.
Old June 30th, 2004, 12:45 AM   #863
fcp4 viewer glithches w/apple's 17" cinema display
i just replaced my old viewsonic crt with a 17" apple cd. i've found and annoying bug it has while playing back footage in the FCP4 viewer windows. i see a strange ripple effect (on/off) that doesn't show up in the quicktime clips in my scratch disk and isn't on the original footage. my "system settings" for playback are rt unlimited ~ high etc.. i've moved them all around and the bug remains. i've also laid it back to tape (from FCP4) and the image is clean. it appears as if it some playback conflict/refresh rate issue the 17" apple cd has with final cut. any advice or tips? if it were a slow refresh rate issue (tearing) wouldn't it appear in my quicktime viewer or when i view a dvd with idvd? i can't figure out why it only appears in the fcp4 viewer windows! what gives......
powermac g4 1.25 ghz (sp) ~ 1.25 RAM ~ os x (10.3.4)
200 gb western digital firewire drive ata 100
Michael Buendia is offline   Reply With Quote
Old June 30th, 2004, 07:09 AM   #864
Sorry, I thought I'd posted my solution. I put the Qt file in the trash then clicked into FCP and when it cried 'missing file', I brought the file out of the trash and reconnected it and everything was wonderful.
elmer
Elmer Lang is offline   Reply With Quote
Old June 30th, 2004, 07:21 AM   #865
Warden
Lowering the quality setting didn't help? Do you have the latest video drivers installed?
Jeff Donald
Carpe Diem
Old June 30th, 2004, 02:29 PM   #866
question about DVDSP2 (for Jeff Donald)
Jeff, you always seem to be able to answer the questions i have about DVDSP2 very quickly. Have you ever built a DVD9 or anything bigger? I have heard that there are now dual layer DVD10 and DVD11. can DVDSP2 or 3 handle burning the image of a DVD10 (dual layer) or a DVD11 to a hard drive? All i know is that it can handle DVD9s. If you have can you shoot me an email to alfredbot9000@yahoo.com becuase i was wondering if it would be possilbe to give you a call or have you call me because we are in a slump with making a dvd9 for a band because of size constraints we may have to go to a dvd10 or 11.
thanks much.
Alfred Tomaszewski
(Scrambled Visual Entertainment)
Scrambled Visual
Alfred Tomaszewski is offline   Reply With Quote
Old June 30th, 2004, 02:59 PM   #867
Warden
I'm still using DVD SP 2 and as far as I know DVD9 is it for this version. DVD SP 3 might do DVD10 or 11, but I doubt it. It will do a Video_TS file to a hard drive and your replicator may be able to do a DVD10 or 11 from the HD. You might also want to ask on the Apple support forum here.
I would think that you could author two separate projects and burn each to a side of the DVD10. I don't see why that wouldn't work.
Jeff Donald
Carpe Diem
Old June 30th, 2004, 03:26 PM   #868
Hard drive problems after FCP re-install
After re-installing FCP 4.0 (to fix other problems involving inability to export to Compressor) on my G4 (have OS X 10.3.4, and two external hard drives), I tried to open projects that I had worked on before, and got the message: "Cannot read file. It appears to be corrupted." Tried multiple projects that had been on other drives, same answer. Then, I download the FCP HD upgrade, restart my computer, and try to launch it from my dock, but it won't launch. Other programs will launch, though. Closest I can get into my FCP projects is to launch the project's shortcut off my desktop, and then FCP 4.0 opens, with the "corrupted file" message.
Can anyone help me? To see what else I've already tried, go to the thread at: http://www.dvinfo.net/conf/showthread.php?threadid=28158&goto=newpost
Thanks for any help you can give.
Sharon Lawler
Visit www.picturethisvideo.net for rates and availability!
Sharon Lawler is offline   Reply With Quote
Old June 30th, 2004, 08:31 PM   #869
Guest
Posts: n/a
hmm thanks for the link ray but thats not the same problem i am having.
FCP is taking the quality out of my audio track - i can still hear the music but it sounds much worse than in iTunes
Old June 30th, 2004, 08:39 PM   #870
Possibly your memory - be sure you have at least 1 to 1.5 gig of ram. I had the same problem where I thought the music (which was an imported MP3) was cutting in and out but only marginally. When I actually exported it, it was fine, but while previewing edits it seemed skippy (like it was choppy) so to speak. Also when I exported it to a Quicktime Movie, the audio did seem to be the same. Memory should solve that issue.
After you let us know about the memory config your using, maybe someone else can chime in with some advise.
Good luck.
Camera: Panasonic DV953
PC: Apple Aluminum G4 Powerbook - 15 inch
Final Cut Pro 4 and other assorted goodies!
Rick Tugman is offline   Reply
