Vegas Video discussions from 2003 - Page 13 at DVinfo.net
Old April 10th, 2003, 06:22 PM   #181
Vegas and MPG2 rendering issue.
Hi all, was wanting to convert some footage taken from TV (standard VHs, crappy res) into a DVD. When I rendered the thing out using the MainConcept codec though, the artifacts that appear were astonishing and unacceptably bad to watch on a TV, especially in high speed footage. I then rendered the thing out as 352x288 and the quality was far superior. Does anyone know if there is a way to get the MPG2 renderer that comes with Vegas to do a better job with TV footage? Someone mentioned to me that deinterlacing first might help but can't see an option in the Main Concept codec rendering options. Would it be best to render to AVI and then go through TMPEGENC?
Cheers
Aaron
Aaron Koolen is offline
Old April 10th, 2003, 07:27 PM   #182
If you are starting with crappy, crappy is pretty much all you'll get.
"DOH"!!!
Harry Settle is offline
Old April 10th, 2003, 11:24 PM   #183
By crappy I meant typical VHS resolution from a video player. That I can live with on my TV but I don't expect to get crappier ;) The artifacts were astonishingly noticable. and looked like a madly encoded VCD.
Cheers
Aaron
Old April 11th, 2003, 10:54 AM   #184
I've done a lot of analog work over the past 6 or 7 years, with limited success. (mostly because I was unwilling to put out the dollars necessary to get the job done, properly)
I started out using one of the Dazzle products to capture to the computer, worked fairly well, but, output had lots of problems. I finaly switched to using the Canopus ADVC-100 for input, analog to digital, and output, digital back out to analog, with outstanding success. Simple matter of plugging it in to the computer with a firewire, and plugging the vhs or camera in to the ADVC. Edit, or whatever, and output back to vhs, if I choose. I get at least the same quality going out, as I got coming in. NO ARTIFACTS.
Also, you need to look carefully at your system. . . fast computer, more ram, fast hard drives and if possible keep your video on the drive separate from you operating system. Defrag etc. . .
One more thing about Canopus products. Go to their forum, you will notice that their users are having fewer problems than users of other systems.
"DOH"!!!
Old April 11th, 2003, 11:27 AM   #185
Pinnacle DV 300 and Vegas 4
Just downloaded the demo of Vegas 4 to try it out but.. beginners trouble...
I cannot capture from my camera, Vegas just says "please connect a device".
I am using my old Pinnacle DV300 (same as the DV200) could it be that firewire on a video card is not the same as a cheapo firewire?
Maybe someone had the same problem and can help me, I have 16 tapes that should get on my harddisk better sooner than later.
Cheers, Peter
Win2000, 512mb RAM, plenty of HD and all works fine with Premiere.. BUT I WANT TO TRY VEGAS!!!
Peter Koller
Vienna, Austria http://www.kop11.com
Peter Koller is offline
Old April 11th, 2003, 11:54 AM   #186
The best way to troubleshoot this would be to disconnect the firewire cable, reconnect and turn the camera on and VTR mode and see if My Computer sees the DV Complaint Device or DV camera. Then try capturing in Vegas. If it does not work check your Firewire drivers and very that they are NEC or TI complaint drivers. If the camera is not found in my computer or Movie Maker 2, then you have a problem with either the firewire card or the camera. I've read in some forums before that because of the physical pin-out of firewire, it is easy to short out the firewire port in either the device or the card or both. This is usually caused by a slight wiggle or movement causing the wrong pins to touch in the firewire ports. If this is the scenario, then you need to know which went bad or maybe both. I don't know what you have in respect to hardware but this is how I determined that my TRV11's firewire port was burnt out. I took the camera to another firewire PC and a firewire Mac and plugged it in to see if I can get the system to recognize it. No go. I then took another Firewire device (Maxtor 80GB firewire HDD) and check to see if it is working, sure enough it came up right away. Then I knew that the firewire circuitry in the camera was fried.
"USA Today has come out with a new survey - apparently, three out of every four people make up 75% of the population." -David Letterman
Garret Ambrosio is offline
Old April 11th, 2003, 12:15 PM   #187
Well, the capture works fine with Premiere.
I checked the Vegas website and they say to use an NEC, TI or some other default 1394-driver, unfortunately my DV300 does not like these generic 1394-drivers and won´t respond to them...
Hmmm, kinda stuck here... should I get a simple 1394 card for $30?
Peter Koller
Old April 11th, 2003, 02:25 PM   #188
Sponsor: JET DV
Get the simple OHCI card. The DV300 may not be fully compatible. Also, you MICROSOFT's driver - not TI, not NEC, not anyone else.
Edward Troxel is offline
Old April 11th, 2003, 04:03 PM   #189
I say get the $30 card or less I think I've seen them go for 19.99 at Fry's when using Vegas.
Old April 11th, 2003, 04:49 PM   #190
Another voice in the choir. Cards like the Pinnacle 300 you have came out before Premiere was OHCI compliant. It was designed to work with premiere and premiere alone. The 300 is not OHCI complient The Pinnacle DV 500 now has drivers that are OHCI compliant. You need and OHCI compliant card for Vegas.
Rob Easler is offline
Old April 11th, 2003, 08:19 PM   #191
Vegas video exporting for ReelDVD
I have VV4 and have created several MPEG2 files for DVD authoring. I want to get Sonic ReelDVD but while reading a review I discovered I have to be able to export the video and audio seperately from Vegas (it said as an m2v and wav file). I've never heard of an m2v file. Does anyone know if Vegas can do this? I checked and it wasn't an option under rendering.
Dan Measel is offline
Old April 11th, 2003, 11:50 PM   #192
Hawaiian Shirt Mogul
tried it BUT didn't use it ...
now depending on the area you might be able to use a cookie cutter on the area ? find a SHAPE in the cookie selection that fits the area you want to lighten then adjust SIZE so you only see the area you want lighter ..you might add some feathering ...then add CC fx and use gain to lighten area.. or for better control but higher learning curve use the Color Curves FX and only adjust the blacks ( put curser over the lower diamond shape which is up from bottom left corner ... curser will trun into double arrows .right click and drag diamond towards left bottom corner then left and up to your liking ... so now Video track one will have picture area that you want to correct and all other area will be blacked out
now from Vegas explorer add the same clip to Video track 2 ( if you copy video track one to video track 2 you must remove cookie and other fx after you add to track2 ) .. the 2 tracks positions must be exact so make sure the time codes are the same ( zoom into curser - under options /video select show time code or play and adjust till the 2 clips are in sync ..when you found sync then delete the the 2nd audio track) ... now the image from Video track 2 will only show thru the black area of Video 1 ...
Don Donatello is offline
Old April 12th, 2003, 02:08 AM   #193
I´m gonna bite the apple and buy a card and throw out the dv300.
Thank you guys for all the advice!
Cheers, Peter
Peter Koller
Old April 12th, 2003, 06:36 AM   #194
Sponsor: JET DV
When you go to the DVD rendering settings, UNCHECK the "Include Audio" box. Vegas is definitely able to create an elementary stream MPEG video file.
Old April 12th, 2003, 07:51 AM   #195
As always a great help. Thanks a lot.
