NLE Mac / Final Cut questions from 2004 - Page 32 at DVinfo.net
Final Cut Suite
Old April 12th, 2004, 07:08 AM   #466
RED Code Chef
My first suspect would be incompatible media. Please take a look
at the following site as well.
Rob Lohman, visuar@iname.com
Old April 12th, 2004, 10:59 AM   #467
the article that Travis mentions at Ken Stone's site is written by the person who wrote the CC section for the massive Apple FCP4 Advanced Editing and Finishing book... which he mentions in the end of the article and is WELL worth the price.
Kevin Burnfield is offline   Reply With Quote
Old April 12th, 2004, 12:02 PM   #468
RED Problem Solver
My G Levels in Set 1 www.nattress.com will do the s shaped curves you require. I also incorporated the code into Film Effects, which as the name implies does this and a whole lot more.
Graeme
Graeme Nattress is offline   Reply With Quote
Old April 12th, 2004, 12:48 PM   #469
Dear Rob,
Thanks, I'd begun to lose hope. I'll see what versions of OS amd Idvd I'm running.
If I understood the post correctly, the person upgraded the OS and than it stopped working, so he went back to the old version and it worked.
FWIT I'm running and AO6 and it worked fine with imovie.
It looks like I've go some digging ahead.
Thanks for giving me something to go on.
I'll post if I make progress.
Joe
Why ask me? I thought you were in charge!
Joe Gioielli is offline   Reply With Quote
Old April 13th, 2004, 08:53 AM   #470
Filesystems on OSX
Hi... me again.
My partner is a MACette and I'm a PC person so I'm wondering if there's a longer term solution to our compatibility issues.
Can any of you MAC-ites out there confirm what file systems OSX can read? My firewire drive is formatted to NTFS and I thought I read that OSX MACs can READ but not WRITE to NTFS.
So I can convert it to FAT32 for READ and WRITE but then I'm going to get hit with the 2Gig file size limit.
Does this all sound correct?
Kevin
Kevin Kimmell is offline   Reply With Quote
Old April 13th, 2004, 08:59 AM   #471
got a doozie for yall (long)
ok, my uncle is a human factors research scientist for an auto maker.
his team used a static dash mounted lipstick cam to record the eye movements of subjects in a vehicle.
hundreds of subjects, 4 hour tests.
as you can imagine, they reeled at the thought of collecting and archiving all that tape. the purpose of the video is..get this.. to plot eye movement by a assigning a numeric value to the parameters set for each different eye position. this is done manually, frame by frame. those value are then charted on a graph that corresponds with the vehicle behavior at the exact same point in time. so actually the video is just a means to an end. after humans, yes humans, (students really) evaluate each test frame by frame to assign the values.
they recorded direct to a hard drive, bypassing the tape problem. as they recorded/digitized video it was encoded to MPEG 2. (no audio needed.)
in order to sync the eye movement with the vehicle behavior, they sync all vehicle behavior to 30 seconds a frame.
I have no idea what he was talking about at this point as to how they did that...something about recording tire movement at 30Khz...
Here comes the question-
they have discovered that MPEG 2 does not necessarily render 30 frames a second. not rendering each frame if the background does not change.
and it doesn't due to the nature of the study.
Is there any way to recode the video from an MPEG back to raw 1s & 0s so that they may re-encode in a more suitable format?
raw digital information is long gone. have only MPEGs at this point.
Gary Chavez is offline   Reply With Quote
Old April 13th, 2004, 12:47 PM   #472
Doubling and smoothing footage
In AfterEffects, I often find it more effective to double the size of my footage when doing keying or other effects work and then reduce it by half afterward. The result is often better than had I attempted it at 100%.
My question: is it possible to use the interpolation power of RE:Fill or Twixtor (or is there some other product out there?) to smooth out that doubled footage? AfterEffects is really only turning one pixel into four but there should be some way to estimate curves and such to reduce the stairstepping, particularly with in-motion footage.
Handy Diagram
Any input?
-j
I apologize if this has come up before, I couldn't find it.
Jay Silver is offline   Reply With Quote
Old April 13th, 2004, 12:55 PM   #473
RED Problem Solver
After Effects uses bicubic interpolation, as does Photoshop. This is good, but not best.
The type of interpolation you want is content adaptive, I have an example here of some R&D code I'm working on which, although not currently perfect, does show you what will be possible soon:
http://www.nattress.com/scaling_test.jpg
The project I'm working on should eventually produce even better results that you're seeing in my early test, but as you can appreciate, it's not easy to do - or everyone would be doing it!!
Graeme
Old April 13th, 2004, 01:13 PM   #474
Cool stuff.
Would this "new project" be a part of Set 3? Are you developing with only FCP in mind, or do you forsee any AE functionality?
I'm going to try a couple of your free ones for FCP and see how they work for me. I can think of one suggestion right off the bat - a plug-in that will inpret the footage with the LAB colour model and allow separate blurring of the a & b channels to reduce the blockiness in DV footage.
Nice pics of Halifax, by the way!
-j
Old April 13th, 2004, 01:23 PM   #475
RED Problem Solver
No, the new R&D project is a stand-alone app, utilising cocoa, quicktime and open-gl acceleration of my unique algorithms for image upscaling and sharpening. It will hopefull do a lot more than scale up video, but that's the major component of it.
As for your plugin request - check out G Nicer as part of Film Effects - it's an intelligent chroma upsampler and works wonders with 4:1:1 footage, producing excellent results. I'll include this technology as part of the stand alone app mentioned above.
BYW, there's no need to convert DV to LAB because it's YUV native, with U & V being the downsampled colours. I work in YUV space to do the chroma upsample and it works a lot better than a blur!
Yes, that was a great trip to Halifax - really enjoyed it! Nice city and great fun.
Graeme
Old April 13th, 2004, 01:47 PM   #476
RED Code Chef
A little disclaimer: I don't have a Mac or have ever worked on
one (yeah yeah, I know). That link was basically the only thing
that came up when I did a google search on your problem.
On the PC different types of media can sometimes generate
burn errors. That's why I suggested trying a different brand.
Old April 13th, 2004, 02:43 PM   #477
Stuttering sound problem with my G5 2 dual
I am trying to put in sound from my Mini Disk. Earlier it worked but now I can't get a complete sound, it stutters. Now whenever I turn on my mini disk I constantly get stuttering. It could be in Garage Band, FCP, SoundTrack etc. But can't get a flowing sound. I am working with a USB audio interface, it is the US 122- by Tascam. I phone up their tec support and they said that it might be that their interface is not compatible with the Dual G5, maybe less powered duals but not the Dual G5 2 gig like mine. Their not sure. Any suggestions would greatly be appreciated.
Bill
Bill Furner is offline   Reply With Quote
Old April 13th, 2004, 03:39 PM   #478
RED Code Chef
MPEG2 was definitely the wrong choice since MPEG2 works on
storing the individual changes between frames instead of full
frames (yes it stores full frames every so often). So looking at
individual frames is very hard (as you / they've found out). It
might even be that some information is lost if the compression
was high enough.
The best way would be to convert the footage to some other
format like DV so you can access it easier. There might be some
other Mac codecs you could use as well. Since I'm not a Mac user
myself I cannot tell you much more then this I'm afraid. Sorry.
Old April 14th, 2004, 09:29 AM   #479
New HD for a G4
I'm currently running a Adobe premiere on a G4 400 with a 20 gig hard drive, when I save video in premiere, it tells me it has dropped frames, does this mean my Hard drive is'nt fast enough? plus I only have 6gig left, I think it's time to install a second HD dedicated to video, how do I do this? what do I need? is a 7200rpm fast enough or something faster?
Thanks for any help.
Jonathan Posch is offline   Reply With Quote
Old April 14th, 2004, 11:36 AM   #480
static image import problems
On a typical project we get a mixed bag of .JPG, .TIFF files, 72dpi, 300dpi, you name it. Is there a standard file format and resolution to convert to that displays all the image quality for standard res DV projects. In many cases the large .TIFF files stall in the timeline, as well as causing noticeable moire patterns and bad jaggy edges. Anybody have a "rule of thumb" format, resolution that they convert import images to?? Thanks.
Jon Grimson is offline   Reply
